Question about Frigidaire GLTF2940ES Front Load Washer
Washing machine Hi, I have my whole family coming this week to visit and my washing machine won't work. It won't do anything and has water in the bottom of it. I wasn't home the last time it was run but when I did arrive home the washer had been run and it did not finish its cycle and did not drain. It was unlocked and now it just buzzes really loud whenever I try to make it do a function. It won't do anything. Thanks!!
  • carrkatie Dec 18, 2007
    So, I had a service guy come to my house today and he found an underwire bra wire in the drum...so.. I guess ladies don't wash bra's in the wash.
  • Anonymous Dec 19, 2007
    I have the same exact problem. a wire from a bra made it down to the drain pump and was blocking the pump impellers. problem is that I removed the pump gaining access from the back of the washer. I'm having a really hard time re-attaching the hoses... I can't figure out how to take the from lower cover off like some people mention.
    Sergeant:
  • 272 Answers
If you take the clip down to your local hard ware shop they will find you a pair of pliers that will help you put it back on
Posted on Jan 05, 2008
Hi my machine will fill with water then doesn't do anything for the whole wash cycle then will dran and spin but will not wash in the wash cycle
Hi, it could be your heater element is not kicking in and so its not heating up the water and not moving on to the next stage of washing. Best get the unit checked out.
May 03, 2016 | Washing Machines
My washing machine is a whirpool stylemaster model no. LXR9245EQ2 and it will not do anything besides put the water into it and it will only halfway drain. It does not agitate at all.
If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically.
Here is the switch to order.
The part comes with a 365 day, any part, any reason return.
Nov 07, 2012 | Washing Machines
How to reset Beko wmb 91242 LC? Machine won't do
My washing machine beko WME7247W won't do anything it said C on it won't start change tem do anything can you help me
Apr 08, 2012 | Washing Machines
Whirlpool Sm8525079 Rev fills up with water, but won't agitate.
Your lid switch has a fault, Sometimes the switch can bend which means that it won't always operate.
Mar 08, 2012 | Washing Machines
The washer quit spinning, I can get it to work in wash mode but when it comes time to spin out it won't do anything,
themobilian_2472.jpgIf it won't puthemobilian_2473.jpgmp out the water or spin that is the lid switch. If it pumps out the water but does not spin then that is the motor coupling. How to get into the machine.
How it works: 4 videos and a service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 21, 2011 | Whirlpool LSR6334LQ Top Load Washer
Error code E320 appears and the machine has failed with this code
Go to the very bottom right of the washing machine, open up the flap; there is a round filter. Open up the nozzle and put a towl down underneath- once the water has stopped coming out, twist the whole filter until it lifts out. Clean this (there may be money and fluff in here) with water. Put it back in. Put the washing machine on a high temperature wash without anything in. This will give it a good clean, and get out any residue from products used. It should work okay after this.
May 10, 2011 | AEG Lavamat 72640 Front Load Washer
We have a load in....it is full of water....it wont drain and spin...the cancel button doesnt work and door wont open....I checked for kinks in drain hose...none. I took off top panel and front lower...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 12, 2010 | Kenmore Washing Machines
Wash machine pump doesnt work
Hiya,
some machines have a filter at the front of the machine it will be right down the bottom behind the trim this trim normally just pulls to open & if so you will see a small circle if you unscrew that some water will come out & if blocked will have some stuff in that you can remove,
Hope this helps
Apr 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Maytag Neptune MAH-1 won't stop filling with water
A couple things may be going on here... you may not want to hear, but the Neptune has a had many "consumer related problems".
If your complaint is "will not stop filling with water" I would access your inlet water-valve (typically blue with 2 black battery looking solenoids; where your water-lines connect directly), test for continuity and replace as necessary. Sometimes inlet-water valves also go bad where the complaint is: "no water comes in at all".
Jan 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
44 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
