Question about Samsung PN50B550 50 in. Plasma HDTV
Should i hook up my tv antenna to my sound system receiver or the tv itself?
  • 135 Answers
The freeview or digi boc is best for sound
Posted on Sep 25, 2009
No picture or sound
You need a antenna HD for air signals. I hope this helps. leave feedback and thank you
Jul 11, 2016 | Televison & Video
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Sep 14, 2011 | Denon DRA-37
Can my Panasonic TC-P42X1 receive digital channels without an antenna connected? It sounds like a stupid question considering its a high-def TV, but I'm having troubles getting the TV to pick up...
No.Tv can't pick up any reception or receive any free AIR broadcasting tv channels at all if tv have no antena hook up to a tv.Buy a better antena design to used like a Digital atenna,will solved this problems.
Aug 21, 2011 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
I cant get sound from my tv , dvd and vcr are fine.
Run the antenna cable to the VCR in antenna, then from the out antenna on the VCR to the TV in antenna. When turning on the system, turn on VCR and so audio from TV will be heard through the system.
Sep 19, 2010 | Pioneer VSX-D511 Receiver
No play back from HDTV to threater system
Do you have set-top-box or antenna-cable directly to TV?
You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output.
You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV.
But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound.
But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
Jan 25, 2009 | Sony STR-DG520 Receiver
No signal on dtv do I need a DTV antenna
You have an awesome antenna - every one should have one like it!
An antenna that used to work with the older analog signals will work with the digital ones. What you have to remember is that analog systems though subject to ghosting, were brutes signal wise ala the metal on older cars. Digital signals are frail and even tree leaves in between the antenna and transmitter can have adverse effect on signal received.
If the sound is weak on your set that is a function of your sets audio section. Somewhere you are losing gain and/or amplification. If you have an audio output you might consider hooking that up to one of the audio inputs on audio receiver. It will work fine and that is what I did with my unit.
Sep 05, 2017 | RCA HD52W59 HDTV Projection Television
HD Hookup on Dish Network 2nd Location
In order for you to receive HD broadcasting you must have a HD-TV, otherwise you wont get the picture in HD. Also I should point out that you need to make sure that the signal itself is being broadcast in HD.
Apr 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Teac Receiver lost AM and FM
Well, if your unit had that happen, it sounds like it is possible. ;)
I would imagine that the radio, like all the other inputs, is in itself a separate unit or circuit board. If something fails on it, it probably wouldn't harm other inputs or the actual amplification itself... just a guess on my but it makes sense. A repair shop could probably open up the case and visually inspect the tuner circuits to make sure there isn't a short or dead something somewhere.
If there is still sound in Jim's case, I would try a different antenna and/or make sure its hooked into the correct antenna hookup. if sound but antenna change doesnt help, it could still be an internal but maybe simply problem.
i'm no pro but that's my 2cents
Oct 29, 2007 | Teac AG-V8060 Receiver
Samsung PN50B550 50 in. Plasma HDTV Logo
50 people viewed this question
Henry  Thomas
Henry Thomas
