Question about GE WSXH208A Front Load Washer
I had stored my ge frontloader washer and dryers for about 4 months and reinstalled them i turn the washer on and it runs threw its cycle and does not spin so the close are soaked in the washer the model number is wbvh5200j3ww..
    President:
  • 1,015 Answers
I would remove the back and investigate for mouse/rat damage. If you had them in storage a rodent may have made himself a home. They like to chew thru wires and plastic components. Or a wire connection may have come loose when you moved them into storage or back from storage.
Posted on Sep 25, 2009
  • paulslowe Sep 04, 2011
    This is a joke. I have the same washer that does the same problem. I have read others that do as well. This problem is unique to GE but they will not own up to it. There is also a recall on this model. check it out.
Dryer not getting hot / washer won't run unless dryer on.
If these are separate units, you might have an electrical wiring problem in your house or apartment. If one unit (washer with dryer above), check to make sure the power cord is firmly attached to the terminals. Many other possible causes, too.
Apr 02, 2016 | GE Spacemaker GTUN275EMWW 27" Electric...
Ge profile front-load washer not draining
Firstly took the bottom front panel off and removed the drain plug/trap. Then the problem should be solved easily. For More information please visit Clothes Dryer Element .
Sep 22, 2012 | GE White Profile Series 15 Frontload...
My samsung frontload washer stopped steaming at the end of cycle
Is your hot water valve open all the way? If you run the washer on a hot cycle only, does it fill up?
Nov 17, 2011 | Washing Machines
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
Grease looking stains on clothing after washing in front load washer. Not on all clothing just certain items. Normally notice it on darker colored clothing.
that is leftover soad and down that is building up inbetween the inner and outer tub .....
frontload washer tend to wash in cold an d luke warm water down and most softner detergents are mader from animal fat means it not getting washed away so it cakes up and eventualy this cake deosit get heavy enouhk and fall and fet redeposited on yoour clothes ..... make sure you are using high efficiency soap and run a clean cycle every month with the hotest water cycle with a afrresh tablet for front load washers
Jan 24, 2011 | GE WSXH208A Front Load Washer
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
May 23, 2009 | GE WSXH208A Front Load Washer
GE Adora Frontload Washer shredding clothes
We were having the same problems with ripped clothing and longer cycles. Our rubber seal by the door has ripped twice now causing massive amounts of water to run out. I learned through other threads that many people are having these problems and was told that zipping up zippers and turning jackets and clothing with big heavy stuff on them in side out to protect from ripping the clothing and the rubber seal. I removed the panel on the front bottom of the machince and there is a small gray cover that housed the coin trap. Mine was clogged and once I cleared that out, my cycle times got better. I hope this was somewhat helpful. We definitely won't be purchasing another GE front loader!!
Mar 29, 2009 | GE WSXH208A Front Load Washer
Washer keeps pausing
you may have something in your drain pump.
1) Remove the three screws in the bottom remove bottom panel.
2) Remove drain pump cover (have towels or pan to catch water that comes out)
3) Remove any debris from pump, check that the impeller is not damaged and can be moved freely.
4) reinstall drain pump cover and bottom panel
Let me know if it helps
Sep 07, 2008 | GE WBVH6240F Front Load Washer
GE Frontload Washer Adora series duet pair
you may or may not hear clicking as it tries to start.
See this link for troubleshooting it. and to open door.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Feb 02, 2008 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
GE WSXH208A Front Load Washer Logo
220 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
