Question about SanDisk Sansa e250 MP3 Player
One day I got in trouble my dad took it away. Once I get it back a week or two later I put it on my moms laptop to charge but no computers are detecting the device or it wont charge. Can you help me to fix my Sansa Clip?
    Problem Solver:
  • 8 Answers
Download sansa updater then do what is says, it will work
Posted on Sep 25, 2009
  • 496 Answers
First off check the cable your using it might have gotten broken then check the mp3 player and see if theres anything blocking or wrong with the mp3 players charging port
How do I hack xbox live
  1. Don't follow these steps if you want to keep using your Xbox...
  2. Put your Xbox on the driveway.
  3. Put an Xbox live card on top of the Xbox.
  4. Take a hammer from the garage, or if you're underage, ask your dad or mom to borrow a hammer.
  5. Use the ax in a kindly manner to hit the Xbox.
  6. Do it multiple times.
  7. Make sure your cuts are super effective.
  8. Congrats. You're hacking away.
  9. If you're not old enough, make sure you give the tool back to your mom or dad when you're done.
Jan 31, 2015 | Miscellaneous
98 Montero sport idle drops at light than goes back up
Engine stalling and rough run issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Aug 26, 2012 | 1998 Mitsubishi Montero
Not turning on
try removing the battery and cleaning the contacts,,also check and make shure the charger is good
Jun 13, 2012 | LG KM555 Cell Phone
Water damaged Laptop
Attaching an external keyboard does not help because the keyboard controller is damaged.
I recommend you put your money towards a new laptop as the cost of repair maybe too expensive or beyond repair. Most computer repair shop charge for a quote and may drop this charge if you go ahead with the repair.
If the hard disk is OK then I suggest you remove it from the laptop and insert it into an USB hard drive adapter case and use it as an external USB hard drive for backups and data transfer etc.
Mar 04, 2012 | Toshiba Satellite C650 series C655S9520D
I bought a acer notebook on the 19th oct 2009 it was for a xmas present for my daughter i took it out off its box on 23rd dec 2009.In jan 2010 computer crashed took it back to currys they sent it away to...
1.Try to understand,without waranty not able to service your laptop without charge.
2.I thing you are not statisfing with acer service
3.In this scenario you go to consumer court with strong proof.(that means how many days of your laptop stay in service center only like that)
Nov 16, 2010 | Acer Computers & Internet
Ok. Here is my problem just got a laptop for birthday yesterday. And me and my mom, and dad were sitting around and me and my dad decided to download some stuff. And then an hour later my Internet/wireless...
ok here is what you need to do is type in the default ip access for your router to find this take a look at the label on the router its self once you find that you need to enter that into your browser window then a dialog box comes up asking for a username and password the default provided no one has changed it should be ether admin, administrator, no username (leave blank), or comcast. the passwords are blank, admin , or 1234. hope this helps. (note try on a different computer first)
Mar 07, 2010 | Toshiba Satellite A100-S8111TD Notebook
Radio CD not working & lights don't flash remote keylock
Sometime the computer in car will shut down a circuit when it sees a problem even if it only occure once. You can try to disconnect the battery for at least 2 min so all sys power off (some have capacitors that mantaine a charge for short time). If a battery disconnect does not clear problem you have go to dealer and have them to clear codes and reset you modules and your preferences
Feb 15, 2009 | 2004 Dodge Caravan
Toshiba Satellite A135 Battery Issues!!!
Here's what happened (The fix is at the end):
8 months after buying my Toshiba A135 the battery began charging only intermittently. It also would not run without the battery. I put up with it for a month then took it back to Best Buy to get it repaired under warranty. They kept it over 2 weeks then gave it back saying it was the battery, which they replaced. One week later I had the same problem again. Back to Best Buy. The guy at the counter said it was probably the battery, they had encountered a lot of that. I said no, explained it, and gave it over to be fixed. 2 weeks later I got it back. They had reset the BIOS, no hardware replacement. I got it home and it was not fixed. I took it back the next day. They kept it 2 more weeks. They replaced the motherboard. I took it home and...you guessed it the same problem on the day I got it home!!! I took it back with one week left on my warranty. I don't remember what they replaced the last time but I think it was the motherboard again. I got it home (2 weeks later) and THE SAME PROBLEM on the day I got it home. So, the lesson there is that Best Buy computer maintenance SUCKS!!
I called Toshiba to try to get them to fix it for free, and out of warranty. After several frustrating minutes of conversation with an accented person who just kept telling me that my warranty was up, I hung up and called back and got an English speaking person. SHE was very helpful, listened to my problem, agreed to give me a one-time fix ticket. They paid for the postage. When I got my computer back it was mostly fixed.
The problem was the module at the back of the computer where the power cord plugs in. It was defective. Some wire or solder had gotten loose. They replaced it and it worked fine after that, except that when it goes into sleep mode it will not wake up. I fixed that by turning off all the sleep mode options. BTW, a friend of mine with the same computer is now having the same problem.
Oct 17, 2008 | Toshiba Satellite A135-S2276 Notebook
BAD BUICK
chahge the battery, it is loosing charge.
Aug 14, 2008 | 1994 Buick LeSabre
Power down
I know the original post is over 2 years old but I had the same problem. Here's what happened:
The problem was the module at the back of the computer where the power cord plugs in. It was defective. They replaced it and it worked fine after that, except that when it goes into sleep mode it will not wake up. I fixed that by turning off all the sleep mode options. BTW, a friend of mine with the same computer is now having the same problem.
May 06, 2008 | Computers & Internet
SanDisk Sansa e250 MP3 Player Logo
121 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
