Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Mowing deck pullies, mounting and spring application.
  • 1 more comment
  • Chuck
    Chuck May 11, 2010
    IS THERE A QUESTION IN HERE SOMEWHERE??
  • ed in oregon May 11, 2010
    is this a question or a statement? if it is a question, what do you want to know? what is the model number? if it is a statement, i agree
  • Tedd Jul 29, 2013
    i have a 40" 12.5 murray riding mower Model # 40625A. When I engage the blades, the blades spin but the one side is wobbly, plus every 10 seconds or so it tries to conk out. If I diengage the blades, it runs like a champ! Is it my spindle, belt, or both?
  • 40 Answers
Download the product manual from the Sears website. Murray manufactured these tractors so you can download the manual from the Murray website also. Procedure for replacing the mower deck belt is quite simple. No need to remove the deck. Spring location also on diagrams. Mower deck parts diagram breaks down the whole assembly. Easier way to remove pulleys is using an impact wrench, otherwise hold the blade while removig the nut that holds the pulley in place. Use a heavy glove to hold the blade for safety!
Posted on Nov 01, 2009
Their's a 3.5mm jack hole on the deck what's that for.
is there a hose connection on the deck already
so it can be washed underneath after the days mowing
Jul 07, 2016 | Garden
Why do blades bog down when engaged?
I would take pictures of the mowing deck and then remove the the deck and do a cleaning on the bottom deck check each blade rounding pully to see if they move freely and would lubriate each of then blade pully assembly and then remount the deck back on tractor and check the belt tension and try it again.
Apr 04, 2016 | Garden
Why can't I raise or lower the deck?
Sounds like you have jammed linkages which raise and lower deck, you can try this which usually works best with assistant.
With engine off, shake the deck vigorously (up,down, back and forth) while try to raise deck with lever.
Check for worn or damaged arms, springs, deck mounting points, etc and repair or replace.
Sep 01, 2014 | Garden
Blade belt pullys, need diagram, picture.
Need to know what Model # you have?
Try going to www.precisionope.com and put your model number in there to see if it can give you what you need.
Oct 02, 2009 | Garden
When I engage mowing deck,the engine wants to stall.
sounds like deck froze up check the auto stop s thet stop the pullies from spinning see if they realease also check your blades for debres caught in them , then check deck pullies shhould spin freely when belt off and stops away ? cold also be and ajustment problem?
Aug 31, 2009 | Garden
I NEED TO SEE A DIAGRAM ON A JOHN DEERE 214 LAWN MOWER TO PUT THE BELTS ON THE DECK
Hi..my name is Keith..and you can go to an online lawn mower parts site and put in your model of lawn mower and search for the mowing deck..and they will have a diagram of the mowing deck with the belt on it..and there are several sites online but i'll give you the one i use www.outdoordistributers.com ...i hope this has helped
Jul 11, 2009 | Garden
Mowing deck makes ticking noise when blades are engaged.
A FEW THINGS TO LOOK AT ARE ,1THE PULLY SHIELDSMAKE SURE THEY AREN'T BENT TO CLOSE TO THE PULLEY'S.2 THE PULLEY BEARING'S MAY BE WORE OUT AND TO BREAK .3LOOK UNDER THE DECK TO MAKE SURE YOU DIDN'T GET SOMETHING TRAPED IN THE CUTTING DECK.HOPE THIS HELPED.
Jun 11, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman 18.5 riding mower when I engage the blades to cut the blades turn But they do not engage NO Power.Blades Turn But Not enough to cutthe grass.
Hi Jeff, If you look at the deck, one or more of those pulleys is a tensioner, It pushes against the belt to tighten it, The rest of the pulleys can be identified by the fact that they only have a bolt through the middle, whereas the tensioner is mounted on an adjustable arm with a slot to allow adjustment. It should also be the only one that the belt doesn't go around the pully it just pushes on one side.If the tensioner arm is all the way to the end of the slot, the belt is streched and will need replaced but sounds like it may have come loose. Some of these decks also have a spring on the tensioner arm and those come off from a stick or other debris. Check it out and if you have a problem let me know and I will try to come up with a diagram. If your mower is that new there should be a belt diagram on the deck. i will need a model number of the deck or mower for that. Good luck!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mowing
I did the same thing. I replace the belt that turns the blades. The pressure of the impact had stretched the belt and was slipping on the pully that engages the blades. Try that first and check the other belts for tension, wear and condition....Also make sure all springs are attached, not stretched, and in good shape...Hope this is helpful....Joe
Dec 08, 2008 | Husqvarna 22 Hp 46" Deck Yard Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
755 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
