Question about Lincoln Electric K1297 AC/DC 225/125 Stick Welder
Welder doesnt turn on...
Hi all i just hook up my 220v plug-in in my garage.. and when i turn my welder on "lincoln 225-s" it doesnt look like its getting any power, even then fan doesnt come on... i already check all my connection and they r all good... pls help.. thanks
  • edcel2000 Sep 25, 2009
    im pretty sure my connection is ok.... i got 8/3 wire and 40A breaker..... red and black on my breaker "double pole" white my neutral and jacket less cooper on ground.... welder was working couple weeks ago...for some reason welder doesnt work/turn on now.. thanks again
  • A Miller May 11, 2010
    Are you familiar with 220 connections? Are you certain yours are correct?
Where does green and white wire connect on old lincoln 220 stick welder it had no power cord when i got it,,
Posted on Mar 31, 2010
  • 5,603 Answers
Have you connected the feed from your breaker box to ADJACENT lugs on a dual pole breaker? By code you must use a ganged breaker.
You should use a voltmeter to verify the plug is getting power on teh desired pins.
Posted on Sep 26, 2009
Lincoln Arc Welder AC 225 Wiring Diagram
won't have reverse polarity. There are only 3 wires, 2 power and one ground. It does not matter what power lead goes to what side.
Apr 19, 2012 | Lincoln Electric K1170 AC-225 Stick Welder
Coming out of the breaker box going to the welder plug what size wire should i use to run a lincoln 225 welder
It depends on how far away you are going to be away from the breaker box, using a #2 wire should be fine for your welder.
Nov 04, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Whats making the fan on my welder not work
The fan motor has probably burnt out, i see this alot...make sure the connections are good....you can try putting 120v to it directly, if it doesnt run you need a new one...if it does then you need to check all your connections
Jul 22, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Where does the three power wires hook up to the off on switch. The diagram on my welder is faded. There are two gray wires and one green-yellow wire. I have a Lincoln 225 AC welder
The two gray wires are the Hot wires and the green-yellow is a ground/neutral wire. I hope this helps please rate if the answer helps in any way. Good Luck and have a great weekend.
Apr 03, 2010 | Lincoln AC-225 230V
I just got a Lincoln ac 225 welder , IT came with no stinger cable or no ground leads I NEED to know were to hook them on the inside?
the stinger is bolted to the amp dial inside the unit,there should be a ground terminal for the ground in same area.
Mar 07, 2010 | Lincoln AC-225 230V
I have a lincoln stick welder . want to know what it's worth
I bought a good working Lincoln 225 about 2 years ago with the extended leads for $ 35.00 at a garage sale
Mar 06, 2010 | Tools & Hardware - Others
Need the diagram for an old welder, ac/dc 125/225 need to find out how to hook the fan up
Usually the fan if it is, 112/225V. It simply connects across the Line, Phase to neutral, but AFTER the mains switch. So that it is "On" only after the Power has been switched on.
Feb 10, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
What gage should the input wire be? I got this welder used and the input power wire is #12-3. Is that correct?
This is a 220v welder and input is high power…12/3 does not sound good to me when I am working with anything over 12v LOL...y for 220/230v do not use the same wiring as the one was on but better I will go lower to 8/3 “safe than sorry” …Let me know if that work for you and please do not forget to rate my service so I can keep providing this service to everyone and improve on it. God bless
Sep 21, 2009 | Lincoln Electric K1170 AC-225 Stick Welder
ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
Jul 30, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln Electric K1297 AC/DC 225/125 Stick Welder Logo
770 people viewed this question
Top Lincoln Welding Tools Experts
Steve
joe2639
Level 1 Expert
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
