Question about Hitachi 53UDX10B 53" Rear Projection Television
Tuning picture green color on white colors; how do I tune the picture?
  • zodd999 Dec 29, 2007
    the image on the tv has a fish eye image just on the green light
    President:
  • 4,402 Answers
Is the picture wavy have you tried the magic focus?
Posted on Jan 04, 2008
No color blue
HOW DO YOU FINE TUNE THE FINE TUNING THE PICTHER
Nov 25, 2011 | RCA HD52W56 52" Rear Projection HDTV
Help
Hi, Flat panel television instruction manuals are not very easy reading material, there are many connections on the back-you need to plug in some sort of input-always coming from the " out to T.V." of another device. Cable coax's are most common-the cables aren't very flexible that's one way to tell them apart from an RCA cable-usually with red, white, yellow,green and blue colored ends. The red, white and yellows are what we'll focus on for now-the yellow's are for a picture-connect them from an " out to TV" to " video input" on the back of tv, then for sound likewise- red and white colored from an"audio out " to "audio in " if coming from a VCR-you may use the rather un-flexible " screw on" coax connector-same if coming from a satellite/cable box-some satellites require tuning tv channel to # 60 for a picture-other wise it's channel 3 or 4. although you will get a better picture using yellow, red & white rca cords. I hope this has been of some help, prodzilla
Mar 31, 2011 | Televison & Video
I have no color on my Samsung Flatscreen TV
This means absolutely no color - equivalent to a black and white picture. Not even a hint of color.
First, confirm that the source is actually in color - try another channel or input device.
Next, check the settings of the color control - it may have accidentally been turned down. If your TV has some kind of automatic picture mode, try turning if off and adjusting the color control. Try adjusting fine tuning if you have such a control and the problem is with a broadcast or cable transmission.
At this point with a confirmed color signal source, there is a problem with the chroma circuitry.
Note that to the average person, the obvious question becomes: is my color picture tube bad? The answer is a definitive NO. It is virtually impossible for a defective CRT to cause a total loss of color. A defective CRT can cause a lack of a primary color - R, G, or, B or a short between two colors which will mess up the color but is not likely to result in a black and white picture.
Some possibilities in no particular order:
Weak signal or defect in tuner/IF causing loss of signal strength.
Coler killer set too high (internal control) if it has one.
Defective part around the chroma chip/circuit. Faulty color oscillator.
Bad connections in area of chroma chip/circuit.
Defective chroma chip (don't suspect this first just because it is probably very expensive).
Try prodding the main board around the chroma chip with an insulated tool to see if you can make the color come and go.
I had one set where a $.02 resistor decided to open up causing just this problem - perfect BW picture, no color. Another had a coil with a broken wire.
Jun 14, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Doubled colors, fuzzy
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
My Tv has red light (color) out of focus..I've tried tuning the lance but it's not the problem in the lance..it's something else..don't know what..do you?
Your TV has three picture tubes which are aligned to properly converge the projected light beams on the screen. Each picture tube projects a single color of Blue Green or Red. During production your TV was carefully adjusted to properly align these colors. As a feature you have the ability to adjust these colors.thats called convergence.If you don't have a manual to show you how to adjust you can find one here http://www.mitsubishi-tv.com/support.html
Mar 03, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Screen looks like a picture negative, PIP works fine, sound fine
Sony's have dual tuning systems to allow for the separate PIP channel. The common problem on the Sony's is the circuit board and tuning module connections go bad. It is likely that the connections on the board or module were already in the decayed process and moving it just accelerated the issues that were inevitable.
The quick fix is to swap the PIP over to the main picture or to bus the antennae signal to the antennae B terminal thus bypassing the bad tuner module.
The recommended fix action is to have someone with soldering skills to remove the chassis, and locate all the cold and cracked solder joints, especially near the tuning modules. If this does not take care of the problem, the tuning modules will need to be removed for re-soldering on the actual tuner modules.
If none of the above works, then you can always use the audio/video outputs of a cable box or vcr to the a/v jacks of the tv, thus bypassing both tuners in the tv.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Zenith TV- greenish color
If you take off the back of the TV there are additional tuning buttons. One is for the focus. I have a model SY2551S and have the green tint problem. Have you resolved that?
Aug 28, 2008 | Zenith C27A24T 27" TV
Color problem
Please fine tune those B/W channels to obtain color picture. If TV is more then 4 - 5 years old, it needs resoldering in tuning area or might need replacement of IF block.
Aug 01, 2008 | JVC AV-21meu 21" TV
Hitachi 53UDX10B 53" Rear Projection Television Logo
55 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
