Question about Maytag Neptune MAH5500B Front Load Washer
WHY WASHER LEAKS AND HUMMS WHEN WATER IS RELEASED BEFORE RINSE CYCLE AND LEAKS UNDER THE BOTTOM OF WASHER.
    Brigadier General:
  • 4,090 Answers
Possibly because the seal on the pump has been compromised. There may be a blockage( kids sock or smaller item that has been sucked into the pump. The humming is from overload in trying to **** water with air from the breachh of the seal.
Posted on Sep 25, 2009
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Washer is leaking during rinse/spin cycle
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
Start the wash cycle, water starts to run in,F21 displays and a humming noise begins and the door will not open no matter what effort you make to try and open. Reset cycle to rinse and water will not go...
f21 is no drain error code,you have to take off the bottom panel,you'll need a shop vac or something to catch water,put some towels down under the pump,the middle of the pump unscrews so you can clean it out,turn the center part counterclockwise slowly,when the water starts leaking out vac it up as it leaks out,doesn't take long to drain it,when it's drained remove the center piece and you'll find some lovely things in the catch,feel around inside the pump to make sure you get everything out and nothing is hitting the impeller or stuck on it,if it doesn't drain after that and the pump just humms you'll need a new pump,good luck,if i can help you with anything else let me know
Jan 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leaking from under washer
your rinse hose has a hole in it or has come loose from the pump
Sep 21, 2009 | LG WM0642H Front Load
Washing machine leaks from underneath after rinse cycle...wash cycle runs fine, but when it drains out after rinse cycle, it leaks from underneath
i would 1st look to make sure the drain hose is not loose or broken. be sure it is staying in the drain pipe in the wall.it could be a cracked housing on your pump. hope this helps
Jul 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer leaks from bottom during rinse cycle
Take the cover off the back, and look up, next to where you put the soap in, when it's filling/rinsing. There is (like) a (white) plastic valve body, and look to see if water is dripping out of it. I haven't figured out a solution to that yet, other than to replace it.
Also check the boot, coming off the pump. You could have a bad/dry boot, or a loose hose clamp.
Mar 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Jul 12, 2008 | Admiral AW22 Top Load Washer
Machine leaks at beginning of rinse cycle
have you checked the rubber seal round the door might be torn
Mar 03, 2008 | Samsung WF337AA Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
