Question about Goodman Heating & Cooling
Bubbling water sound in AC. Water in the tray is cold. Unit continues to make a gurgling sound.
  • 358 Answers
The gurgling sound is the liquid refrigerant going through the refrigeration copper lines , it's normal. And the water in the tray is condensation and is cold because is from the circulating air that gets cold going through the air handler(inside unit) You only has to keep the drain clean ,by pouring 1/2 cup of clorox every 3 or 4 months.
Posted on Sep 25, 2009
Gurgling when engine is turned off
2005 Grand Caravan 2 Problems may be connected - DodgeForum.com
dodgeforum.com/.../dodge-caravan/328382-2005-grand-caravan-2-prob...
Jun 12, 2012 - Vehicle: 2005 Dodge Grand Caravan ... I noticed last week that when Ishut off the engine I could hear water bubbling on my side of the van. coolant vanishing and gurgling
Jul 20, 2013
coolant leaking into heater core?
May 13, 2009
More results from dodgeforum.com
chrysler - Bubbling sound from the cooliant area when I turn ...
mechanics.stackexchange.com/.../bubbling-sound-from-the-cooliant-area...
Aug 13, 2014 - I hear this bubbling sound when I turn the engine off. It occasionally ... When the engine is hot and the coolant is boiling, open your hood and have a look around. DO NOT try ... 2005 chrysler neon clunking noise from front end.Missing: dodge
Mystery of the Gurgling Heater Core - YouTube
? 7:04
https://www.youtube.com/watch?v=db2nR0EMOIs
Dec 28, 2015 | 2005 Dodge Grand Caravan
Gurgling sound
Refrigerant migration nothing can be done.
Apr 28, 2014 | Scotsman Kitchen Appliances - Others
Gurgling water noise
I would think that it is the ac evaporator unit and condensate in the ac box that is unable to get out the drain pipe from a blockage . It could be ice melting off the ac unit fins . check that the ac is operating properly
Apr 23, 2014 | 2001 Land Rover Discovery Series II
Sounds like water running
According to the manual for that model, this is normal. It says "bubbling or gurgling noises" which indicate that the refrigerant is moving about the lines to cool the unit.
Oct 23, 2013 | Magic Chef Chest Freezer MCCF5WBX
Sewer smell in house since installing the new toliet and the toliet gurgles when the washing machine is on. It started with the new toliet now the gurgling and smell is also present in another bathroom.
It sounds like a vent problem.
On top of each house is a vent stack.
There should be a vent stack above each toilet, and above kitchen sink.
Look for pipes sticking out of roof.
These pipes are open to the sewer line.
When you run a column of water down a drain, the vent stack lets air flow in front of and behind the column of water.
This air flow prevents the gurgling sound.
The gurgling sound is the drain water pushing air in front of it because of a clogged vent.
If you have a two story house, there are vents that run between floors to prevent the air flow from gurgling or bubbling sewer air into each drain as water column moves down pipe.
http://www.bradyinspects.com/plumbing-vents.html
http://chestofbooks.com/home-improvement/construction/plumbing/Standard-Practical/Venting-Part-3.html
Look for bird nest over vent pipe on top of house.
Run a snake down into pipe from roof and see if the is a stoppage.
You many need to call plumber to track down each vent and the cause.
For example if there are quick-vents installed inside a wall and the quick vent is no longer working.
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Dec 25, 2010 | Kohler Bath Highline K-11492-96 Biscuit...
My fridge randomly gurgles. no ryhme or reason. cant trace source other than somewhere sround the bottom---i think
This sound is caused by the drain tube. It has a U shape in it at the bottom. when water comes in it pushes the sittin water out, therefore making a bubbling sound. No problems:)
Nov 30, 2010 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Gurgling sound from Whirlpool Duet washer when not in use
Check your drain line. You may have a siphoning condition. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If you have the water source turned off, the only other way water gets into the washer is through the drainage system. If you do not have the proper air gap or placement on the drain line, it can create a vacuum and allow water to siphon back into the washer.
NOTE: Some residual water in the drain line is normal.
If you have any questions, please let me know. I hope this helps you.
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Window unit is not draining, tray is filling with water
Remove the unit from the housing. Using a special cleaner, called coil cleaner which you can purchase at any AC shop clean the coils, this should eleminate the problem.
Sep 08, 2009 | Kenmore 75085 Air Conditioner
Blowing cold air but making a bubbling sound
If there is water in your laptop then most likely it is dead.
Jun 24, 2009 | Acer Aspire One PC Notebook
Suddenly no filtered water comes out, but there are gurgling sounds inside
I guess make sure the filter didn't unseat itself first, also check the O-rings, etc. to make sure they didn't roll off their position on the filter. If that's all OK, you really need to find that gurgle sound cause that's likely the water you are missing going "somewhere" it's not supposed to go. Look all over for water leaks even if you have to pull the unit out from the wall... keep looking!
Dec 21, 2006 | Amana ARB1905C Bottom Freezer Refrigerator
Heating & Cooling Logo
653 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
