Question about Summit Commercial Refrigerators
Summit FF874W 8.8 freezes but fridge doesn't get cold. Doesn't seem to have a fan running?
  • 358 Answers
If the fan doesn't work the cold air won't go to the fridge.
Posted on Sep 25, 2009
My Mini fridge Doesn't Get Cold, it's running, I've tried unplugging it for a day and then plugging it back in , still not getting cold..Looked at back and everything looks fine..Except..T
Replace the fridge compressor with another one, try a Google search and maybe you'll find result's for your specific fridge. If all else fails, then ring up your fridge manufacturer and talk to them about your fridge, and if you still have warranty and you complain hard enough, they might just send in a new compressor.
Dec 10, 2012 | Haier HSB03 Compact Refrigerator
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
G,DAY. my fridge which is a hff518w does not get cold in the fridge compartment, the freezer works well.I have tested the fan on the bench and it works well but it wont run when hooked up to the fridge.I...
I think that now that the timer has been opened it needs to be replaced. However the timer doesn't generally shut of just the fan, it's designed to stop the compressor from running and turn on the electric defroster.
Most of the time that a freezer gets cold and the fridge doesn't means that you either have a bad cooling fan or a blockage from ice. A complete defrost will ensure it's not a clog.
Even bench testing the fan is not a full proof test. Usually when you test the fan its in room temperature air and most people test the fan laying down.
The fan operate on very small bearings which are very sensitive to temperature, so testing a fan outside the fridge, you would need to test it in a cold environment and move the fan in multiple directions.
I would suggest that you purchase both a new timer and a new fan.
These items can be purchased at your local appliance dealer or online at applianceparts.com.
Thanks for your question.
Aug 24, 2011 | Refrigerators
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
Refrigerator 795 69292.901 built 8/09 refrigerator is very cold. temperature adjustment does not seem to work. All of the five circles to indicate temperature look alike. None is lit up or is marked,
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this will help in solving the fault.....
May 14, 2011 | Kenmore Refrigerators
Freezer works, it's cool nolt cold in the refrigerator, fan motor doesn;t seem to be working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 19, 2010 | Roper RT14DKX Top Freezer Refrigerator
I have whirlpoll side by side model gd25dfxfh182 and it stopped getting cold enough so i cleaned the coil that was extremly dirty thinking that might help it took good 8 hours to get fridge side down to 38...
IS THE FANS WORKING? DEFROST IT GOOD WITH A FAN BLOWING IN THE FREEZER SIDE FOR A HOUR, IF YOU SEE A BUNCH OF WATER ON FREEZER SIDE BOTTOM , YOU KNOW IT WAS THE PROB. LISTEN CLOSE FOR FAN WHEN YOU OPEN FRIDGE SIDE DOOR.. #2 DEFROST TIMER
May 25, 2010 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
236 people viewed this question
Top Summit Commercial Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Summit Commercial Refrigerator Expert? Answer questions, earn points and help others
