Question about Samsung DLP HL-P5663W 56" TV
Have the picture but no color on my SAMSUNG DLP. What is causing it and how do I fix it?
Was it turning itself off just before it lost color? I have the same problem and my tech told me it was the DMD board, a pricey repair.
Posted on Sep 25, 2009
Need help fixing the picture on an older Samsung dlp tv
You need to replace your color wheel. Part# BP96-00674A. This has been a common problem with the samsung dlp's. I hope this helps.
Apr 23, 2016 | Samsung HLR4667W 46" DLP- DIGITAL LIGHT...
Have a 61" dlp samsung tv, making a humming sound
Bad Color Wheel.will cause this and it is a common problem for DLP Samsungs.
Part number is BP96-01103A
Samsung Parts 1-800-627-4368
Jun 24, 2011 | Samsung HLR6178W 61" HDTV
Have a Samsung HLR5067Wax, I replaced the bulb, however when the TV turns on the picture is distorted and pixelated. What can cause this?
U recheck all the input and output wires connections take out and put back in for the replacement of the projection lamp?The tv colors wheel might be also dead too.Picture now,flashes colors or black&white within the picture itself?Any humming or motor noises,any these causes are the colors wheel is dying,require replacement of the tv colors wheel.
Dec 15, 2010 | Samsung DLP HL-P5663W 56" TV
We have 50" Samsung DLP
Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
Nov 06, 2010 | Samsung DLP HL-P5663W 56" TV
I've a Samsung DLP Model HLR-4266WX that has started to hum and is distorting the picture. I've replaced the cooling fan on the heat sink in the back and that didn't work. Is there another fan in the set...
Color wheel would be cause of hum noise and distorted picture on screen.
Please note that color wheel is not user level repair and requires expertise because it is located in light engine, the most sensitive and expensive part of dlp tv.
If you are good with electronics stuff fix then have service manual copy in hand to start inspecting color wheel.
Aug 26, 2010 | Samsung DLP HL-P5663W 56" TV
My Samsung 61" DLP TV just keeps shutting off within 30 minutes. What is the problem and can it be fixed?
yes is easy to fix you need to replace the color wheel. some sensor in the color wheel cause this problem
Nov 06, 2009 | Samsung DLP HL-P5663W 56" TV
Speckles in dlp tv screen samsung 50" dlp
No they couldn't have replaced everything or did they Replace Light Engine? Because that is what is Bad on your TV if under warranty get it Fixed Now Light Engine is very COSTLY !!!!!!!!
Sep 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung 61' DLP Color problem.
If you are using Component inputs, check to make sure that the Blue Video Cable has not backed out of its connecting jack at either end or the cable it's self being bad. If you are using HDMI I would suspect that the Digital Board being bad. It would be odd for the Color Wheel to cause the problem but cannot eliminate it as a cause. The Lamp would cause the picture to be darker but not cause a color to drop out.
I would call a professional to trouble shoot it unless you have the knowledge and the tools to do so.
Hope this helps,
Skyassoc
Jul 04, 2009 | Samsung HL-P6163W 61" TV
Samsung DLP color has gone Muted...Color Wheel or Bulb???
The color wheel or lamp ballast needs replaced...it would be hard to know which without being there to look at to fix the humming problem, neither part is that is that expensive if you price shop, you may want to try one at a time ot save money. Also to fix the picture you need to realigh the DMD board with the help of another person watching the picture.Hope this helps.
Dec 30, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung 46 DLP buzzing noise dark picture flashing lamp did not turn off unpluged from wall outlet)
Sounds like you have a bad color wheel assembly which is located in your light engine assembly.
pt#BP96-00250A
Nov 26, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
190 people viewed this question
Jerry Greenberg
Jerry Greenberg
