Question about Whirlpool Dryers
Have a Whirlpool Gas Dryer - model # lgr7646a spins but no heat
Spins but no heat do i need to relight a pilot if it has one
    President:
  • 1,187 Answers
Thre is no pilot light. This dryer uses an ignitor (glow bar or coil).
Open the lower front "door" (small access door) and turn on dryer.
If the ignitor does not glow (bright orange), then the ignitor needs to be replaced ($60).
If it does glow, then the gas valve needs replacement ($60).
If it isd the valve, the internal spring is stuck. Do not try to repair it, you must replace it.
Posted on Sep 25, 2009
  • Larry
    Larry Aug 05, 2014
    You might want to check the thermal fuse on the back of your dryer its white plastic with two wires thats plugs into it ..if its open the dryer will not heat ..If it heats a little then quits thewn its in your gas pick up valves..Aslso check ignitor see if it glows.
I have a Whirlpool gas dryer, I can see through the hole that the piolet light is not lit. Model #LGR7646EQ3. It is not heating to dry clothes, can I just try & relight the pilot light?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Whirlpool Dryers
Maytag gas dryer not heating
First make sure you have gas, then open lower section of this dryer you shoul see screws you will see a place to relight the pilot , if you smell gas before doing anything then stop your repair, see if the pilot is lit then push the red button and hold it relight pilot hold this button for a few min's after it relights, if it dosent relight check power goign to gas valve near pilot . Gas units have very little problems you may have just lost gas pressure and need to relight it , let me no ! what you see and we wuill go from there
Jul 27, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
Apr 04, 2010 | Maytag Dryers
How do I relight the pilot light?
There is no pilot light on many of the dryers of today. They light with a hot surface ignitor.
Here is a tip that I wrote about dryers and no heat on gas dryers...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 01, 2010 | Kenmore 72802 Gas Dryer
My whirlpool gas dryer model no LGR7646A has no heat, not sure iof this has a pilot or not, if not could it be some sort of safety switch taht shut down the dryer
I am 99% sure it is electronic ignition. There a dryers that had pilots but those are very old. So what you can do is start with the basics. Make sure the gas valve for the dryer is on and there is gas pressure coming from the connector. Make sure there is no debris blocking gas flow in the gas line. If the dryer has a removable door or burner inspection hole on the bottom pull it loose with a screw driver otherwise you will need to remove the back cover of the dryer. Turn on the dryer and watch for the hot surface igniter to come on. It will glow very bright then you should hear the gas solenoid valve click and the burner should come on. If the solenoid opens and the igniter does not come on inspect the burner orfice for any blockage. If the igniter does not come on then you will need to test the igniter for the proper ohm reading with a fluke meter. You will need to verify the igniter is getting power. If the igniter tests good it might be a bad solenoid valve(there are two) or a grounding issue.
Sep 25, 2009 | Whirlpool Dryers
My GEW9250 gas Dryer suddenly has lost its heat. Could the pilot be out and if so how to relight? Or is it some other cause and solution? Thank you, Steve
Pilot? How old is this?
If you are not hearing a "Snap/Click when the dryer starts it could be the thermal fuse, the limit thermostat or bad coils on the burner. If you hear a buzzing sound I would check the ignitor and/or the coils. Process of elimination will find the culprit.
Jun 08, 2009 | Whirlpool GEW9250 Electric Dryer
No heat in gas dryer
Remove the front panel. Leave the door switch wires connected.
Turn the dryer on and look for the glow bar ignitor to glow red.
This may take a couple minutes.
No glow. Replace the ignitor.
Mar 05, 2009 | Whirlpool Dryers
Kenmore 97591220 gas dryer spins but won't heat...
you have to relight the pilot or clean the oriface were the gas shoots out of could be both one problem caused the other.
Jan 05, 2009 | Dryers
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
298 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
