Question about Casio Exilim EX-Z750 Digital Camera
Stuck with lens out. Won't respond
Stuck with lens out. Won't respond. Battery is charged. There is no display
    President:
  • 1,197 Answers
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards
iversh
Posted on Sep 27, 2009
Lens won't close and On/Off button doesn't work
Even though the battery appears to be charging it may be shot. Some batteries if they run down too far can not be recharged. You need to try a new battery in the camera.
Jul 25, 2012 | Nikon COOLPIX S6000 Digital Camera
My olympus tg 310 is stuck with the lens open and won't come on at all even when a fresh battery is installed
If the camera is within warranty, return it to where you bought it. Common fault with a few different brands, to do with a lens open sensor within the lens assembly itself. Maybe allow the camera to dischage without the battery for a few hours and see does it power on with a new battery. Also chack the battery, if it has bubbled it a dud, and check the battery contacts within the battery compartment.
Jun 05, 2012 | Olympus TOUGH TG-310 Digital Camera
I deleted all pics from A540 but ended up with "no image" message on black screen. The shutter won't open either. It appears to be stuck in viewing mode.
hi,
first: be sure the battery is full charge.
second: by a compressor try to blow around the shatter and lens .
third : 3 or 4 times try to inflict a blow on the lens by your palm .
at the end see the result
good luck
gorbesia
Jun 15, 2011 | Canon PowerShot A540 Digital Camera
I have a Sony AX Digital 100 Camera. I used it yesterday and everything worked fine. Battery is fully charged. Tried to use it today and it won't start. I have taken the battery in and out and even...
Does there is something happened when you turn on the camera? If you can heard sound made by the len or the camera try to open but turn off in a second? If so, there is something wrong with the lens, and this how to fix camera lens error will be helpful. Else, if the camera are without any reaction you can check it the joint of the camera to battery is well.
May 20, 2011 | Cameras
Camera Lens Stuck Outside
power on while pushing on the lens smack the bottom of camera on table top (half hard)
Jul 29, 2010 | Sony Cybershot DSCW370 Digital Camera
The zoom does not respond
Hello. The stuck lens assembly is triggering an error condition--and you get the "press reset" to make you reset the internal computer in the cam. Was the unit dropped or did it have some sort of impact--this would cause the internal lens mechanism to become mis-aligned. Also, leaving the cam in a hot car can cause grease(or other lubricants) to flow to movement surfaces, thereby causing a "glue" effect. Look into the lens(cam off) under a bright light and try to determine if the internal lens assembly is crooked. Also, try to see if there is any "wet" area appearing anywhere(especially if the cam was exposed to heat--classic symptom) If the lens assembly is indeed mis-aligned, the cam must be sent to a repair facility. (Also, make sure the battery is fully charged as a weak charge will cause lens jamming(and a whole host of weird phenomenons)---Rick
Oct 11, 2009 | Panasonic SDR-H60 HDD Camcorder
Kodak M1093
It requires service or repair
Sep 05, 2017 | Kodak EasyShare M1093 IS Digital Camera
Olympus Mju mini - lens cover will not open
check out first if the battery is fully charged.and if the battery is very old.then prefer replacing the battery instead of charging.and if the battery is new,then the cover of the lens must be getting stuck up so try tapping the device from all the sides it will automatically get opened.also off the camera completely and try to move the lens door manually up and down.sometimes the gear assembly gets stucked and this makes it free to  move.
Nov 29, 2008 | Cameras
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Lens stuck
Hello, I have read other forums that suggest that quite literally rapping or swatting the unit on its bottom half can actually solve the problem and get things going again. I am going to try it with mine. I too have a stuck lens. Here is a link that details this crude method: http://www.pechorin.com/m/2005/09/10/Sony_DSC_MVC_camera_repairs-245400-11.html
Aug 05, 2007 | Sony Cybershot S650 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
189 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
