Question about John Deere 3-point Hitch Kit A,b,g,50,60 & 70 Tractors
John Deere 4410 three point hitch will not raise. All linkage is intact, no I believe that there may not be hydraulic pressure, although the front loader does work. Recently changed hydraulic oil and filters, screen was clean.
  • 1 more comment
  • prwelch58 Sep 25, 2009
    Why would it be air locked, there were no leaks,never low on oil, and no problems raising and lowering the hitch prior to this problem. The three point hitch was working fine, it was parked in the garage for a few days and when we went to raise the hitch it wouldn't go up.
  • A Miller May 11, 2010
    I think you are air locked. You should talk with the dealer about this. I think you can fix it
  • Anonymous Mar 31, 2014
    three point lift wont work oils good no discoloration and up to full
  • John Deere Master
  • 8,404 Answers
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
Posted on Sep 25, 2009
Low hydraulic pressure to raise implements 8650 john deere
Could be the charge lube in the rear differential. It supplies oil to main Hydraulic pump up front on engine. The charge pump drive can strip and not turn pump. To remove pump drive remove third link plate on rear frame, remove plug behind plate, pull out hex shaft, about 5 foot long and inspect.
Oct 01, 2016 | John Deere Garden
My steering on my 790 john deere tractiior wont work
ck your hydraulic oil tank level ? if ok ck that your three point hitch moves up/down ? this model uses the tractors hydraulics to steer , testing these things first helps to identify a bad steering valve
Sep 14, 2015 | John Deere Garden
Three point hitch when up all the way the pump continues to. Pump
Springs, or valve seats in the control valve need repair. Or at least my wild guess, with some understanding of hydraulics, in general.
Mar 25, 2015 | John Deere Garden
Three point hitch on John Deere 4005 not working right
I have 5310 this happened to me The control linkage pin broke by the valve. I'm sure you have checked fluid.Mine also has hydraulic filter that I serviced. good luck
Jun 15, 2014 | Garden
I have a 4310. The three point lifts only under high rpm and won't lift any weight at all. Cleaned screen and replaced suction and trans filters. Still have problem.
A 4310s 3-pt should be able to lift approx. 1-ton at 24inches on the 3-pt lifting arm. I thought there was a hydraulic reservoir and a transmission reservoir and it is not uncommon to put the wrong fluid in one of those You might check that transmission fluid didn't get in the hydraulic tank.
May 16, 2012 | John Deere Seat 4210 4310 4410 4510 4610...
I need to know where to add hydraulic fluid in a John Deere 2010
... should be between operators seat and 3rd link arm. A large nut/cap on top of the transmission cover, near the rockshaft of the 3-point hitch arms.
Nov 04, 2009 | John Deere 4000 201000-> Gas & Diesel...
John Deere Three Bottom Rollover Plow
Hey, the "round cylinder" is a power steering motor for a John Deere 630. If you start looking for one of those instead, I'll bet you'll have better luck. Deere dealerships tend to not care unless you're buying a half million dollars in equipment.
Sep 27, 2009 | John Deere 3 Pt. Hitch Moldboard Plow...
Three point hitch on 2020 Jogn Deere Tractor will not raise.
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
Jun 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 3-point Hitch Kit  A,b,g,50,60 & 70 Tractors Logo
848 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
