Question about Maytag Dryers
Dryer makes scraping sound when running - Maytag Dryers
  • Maytag Master
  • 8,404 Answers
You may have something stuck in the front bearing which is the front door. Alternatively, your felt bearing may be wearing out. You could pop the top and the front to check this out. Replacement is not too painful ... on the ohter hand, you could turn the radio up a little louder :-)
Let me know if this is useful
a
Posted on Sep 25, 2009
Testimonial: "the felt is falling apart i moved it to eliminate the noise and turned up the radio thanks"
  • A Miller Sep 25, 2009
    Im happy to hear this worked for you
    Enjoy the music.
How do I access the drum
you should always start with make and model of the dryer - you just said that your car is making scraping sound ...
sounds like you have worn out you DRUM SUPPORT ROLLERS
not too easy to replace if you are not familiar with dryers. if you venture to replace the rollers, be sure to study the way the belt is mounted before taking it off, it is a little tricky
Aug 01, 2015 | Dryers
Dryer drum makes a scraping metal sound
bushings at edges front and back are bad front ones are long and flat rear one is a small short plastic sleeve over center shaft. requires ordering parts from manufacturer and almost total disassembly
Dec 29, 2012 | Dryers
Ge DPSR483EA Electric Dryer was making a scraping sound when operating now a felt like belt has come out on the inside of the dryer. What do i do? Kris Long
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 11, 2010 | GE DPSR483EA Electric Dryer
Sounds like it is scraping when turned on
You've got some worn out friction pads, rollers, or bearings. Do not run the dryer in this condition... It will damage the drum (if it hasn't already).
You'll need to remove the front to look at the front drum supports and the rear support rollers. Once you are able to see inside the dryer, it should be pretty obvious which parts are defective.
Nov 19, 2009 | Kenmore 73952 Gas Dryer
GE GAS DRYER DDE7500G
Can you push the drum up and down. If so then the main bearing has gone bad and needs to be replaced. This is the only metal on metal rubbing you will get unless the machine is off balanced. This is caused usually by doing to heavy of loads and wearing out the bearing
May 22, 2009 | GE DPSR610GGWT Dryer
Hotpoint tuble dryer, Aquarius, VTD20 makes scraping sound
sounds like the back drum shaft has worn and dropped through back[plate ... there is a fix for this by buying a new drum shaft and support kit comes with front bearing also .. can be a tricky job tho ....
Mar 30, 2009 | Hotpoint NWXR473EV Dryer
Dryer making squeeking noise
Check the dryer belt tensioner and pulley assembly. It be wearing out. You'll need to remove the back cover of the dryer to do this. Turn off the gas and/or electric before working on the unit.
Mar 26, 2009 | Maytag MDE9316 Dryer
Old whirlpool mini dryer
Those are front tub supports that keep the tub from scraping.Unless you start hearing a rubbing or scraping sound your dryer is ok.Just keep a ear open for awhile for any scraping sound.If you need help in the future with anything ,Im more than happy to help you.
May 24, 2008 | Dryers
Dryer is shooting sparks and making a scraping sound
hoover washer drier is making a scraping noise and a spark from the bottom of the machine everytime the drum spins, does anyone know what this cold be. thanks.
Apr 05, 2008 | Kenmore 83142 Electric Dryer
Dryers Logo
62 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
