Question about Hitachi NR83A2 2" To 3 1/4" Full Head Framer with Depth of Drive
On the Hitachi NR83A2 nailer. Where does the end
On the Hitachi NR83A2 nailer. Where does the end of the ribbon spring connect to the magazine? Had nail jam and ribbon spring came loose.
    New Friend:
  • 131 Answers
It goes thru the same hole as the magazine bolt on the nose. Sounds like yours is broken.
Posted on Oct 10, 2009
My nt50ae2 brad nailer jams in the magazine. the feeder rides on top of the nails.
This happens. The follower jumps over the nails and the magazine binds.
Step 1. Remove nails, unplug hose.
Step 2. Remove the bolt at the bottom of the magazine with a 2.5mm hex key.
Step 3. Remove the magazine while holding the nail follower in place to the magazine cover.
Step 4. Carefully remove the nail follower and gently extend the yellow warning indicator and follower spring.
Step 6. Inspect the nail follower. There should be 3 indentations that are stamped into nail follower face. This is the culprit.
Step 7. With a small punch, make these three indentations deeper.
Step 8. Assemble and test. Repeat if necessary.
Hope this helps.
Jul 28, 2012 | Hitachi Nt50ae2 18 Gauge 34" To 2" Brad...
AIR BLOWING OUT THE TOP AIR EXHAUST
you have a problem with a seal on the cylinder or an o ring that has gone bad. I would recommend replacing all of them.
Sep 02, 2011 | Nailers Hitachi Nr83a2 Flush Framing...
The spring that holds the nails in the firing position is loose
you can buy a new spring but its a lil tricky to install you have to remove the magazine to do it
Jun 25, 2011 | Hitachi 3 - 1/4" Framing Strip Nailer
Hitachi nailer does not sink nails completely, no matter what size nail.
You must have broken tip or out of adjustment. Easy to check. Remove nails, and push safety against scrap air hose or rubber to absorb blow and squeeze trigger. Piston will stay in the down position until your release safety (on some models you will need to pull back on feeder sligtly). While piston is down examine the end of the driver for nice squared off tip protruding about 1/4 inch beyond nose. If no tip or looks broken, replace driver. If tip looks complete, adjust for more depth. Good luck
Sep 07, 2010 | Hitachi NR83A2 2" To 3 1/4" Full Head...
I took my Hitachi NR83A apart to remove a jambed nail, and can not figure out how it goes back togeather. Where does the tension apparatice go inrelation to the shaft and slide handle? Thanks Vince
You do not need any special tools to assemble the pusher into the rails, however there is a trick to getting the spring in the proper position. I use a small pair of vice grips and a paper clip to hold the spring in position. The pusher slides into the rails easily. The back part of the pusher slides into the rails first. On the back part of the pusher there is a groove that accepts the spring, spring spool and pin. The pin will be in a vertical position and the spring will have the end tab with hole towards you. As you push this assembly into the rails you will loose sight of the spring end tab. You must hold the spring end tab at the bolt hole while you push in the assembly. This is done by bending the paperclip straight with very small hook on one end. Hook paperclip on spring tab hole and hold paperclip with vicegrip to position spring tab hole at bolt hole and push assembly all the way into rails untill it locks at rear or rails. This procedure can be varried with goal of holding spring tab at bolt hole. While holding tab in position insert rails into nose of gun and bolt rails. Just leave paper clip hook end there or pull out it does not matter. You are done. Good luck
Aug 05, 2010 | Hitachi NR83A2 2" To 3 1/4" Full Head...
Hitachi NR83A2 nailer pushes next nail down
Are you using full round head nails?
The hissing indicates your O-rings are worn out and need to be replaced. This is not covered by warrenty and is common for all nail guns. Lots of kits are available on Ebay or your local Hitachi service center should stock them.
Hope this helps,
Cheers
Jan 22, 2010 | Hitachi NR83A2 2" To 3 1/4" Full Head...
Reassembling the Hitachi NR 83A2 (S) magazine
The reason that you are having trouble re-assembling the ribbon spring is that you need three hands to complete the job. As you recall the nail pusher just slips into the front of the rails. The pusher has the spring and a pin to retain the spool in place. Install the spring with the bolt hole towards leaver and slip into the front of rails. Take a small paper clip and bend a small hook to catch the ribbon spring. Hook the springs bolt hole with the paper clip and hold the spring in the approximate position for bolt as you push the assembly into rails and use latch to hold. While holding spring with paperclip, insert bolt thru rails and spring into nosepiece. Just break off the paperclip at this point and you are almost done. Some nailers have a metal support clip that you would need to have in place on bolt before installing bolt thru spring. For a breakdown of the gun go to www.toolpartsdirect.com. The other bolt for rails has a support/guide for the safety foot. Good luck and email if you have questions.
Apr 11, 2009 | Hitachi NR83A2S Framing Nailer, Full Head,...
Hitachi NR83A2 2" To 3 1/4" Full Head Framer with Depth of Drive Logo
373 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
