Question about Sony Playstation 3 (PS3) Console
PS3 wont turn on
My PS3 wont turn on at all?
Turned off and wont turn back on
Try going into Service Mode:
Hold Power button down for three beeps (while PS3 is off): Enter PS3 diagnostic mode (repeat procedure twice)
Apr 08, 2012 | Sony Playstation 3 (PS3) Console
My PS3 wont boot. Says "Correct hard drive not
I would suggest:
1) With PS3 off 2) Remove drive 3) Turn PS3 on 4) Let it complain about missing drive 5) Turn off PS3 6) Put drive back in 7) Turn on
If it still complains, try safe boot recovery mode again, choosing option 3, then again with option 4 -- If it still doesn't work, it's not looking good, bit hopefully those should sort it unless the drive really is kaput.
Dec 25, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont turn on at all.
maybe its the cable, or the power brick inside the ps3.
Jul 30, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on. light turns green, flashes
Needs to be serviced. All of the old PS3s seem to have a malfunction.
May 14, 2010 | Sony Playstation 3 (PS3) Console
PS3 wont stay on
Your PS3 may be overheating. Check the exhaust of the ps3 where the hot air comes out for any excessive dust. If you have a 60GB PS3, you can blow them out by turning off the PS3 by the back switch and then turning it on using the back switch with you finger on the eject button. The PS3 should beep 3 times and your fans should go at full tilt for about 30sec to 1 min.
Dec 28, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont turn on
  • ur ps3 overheated and burnt out you have to buy one or get it fixed for 150. It happened to me 3 times =/
Aug 24, 2009 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 the xmb menu wont show....
am sure about the computer part but for the xmb i can help reset ur ps3 by turning it on then turn it off by holding the buttonthen it back on by holding the power button it should beep pause and beep 2x this will reset ur display option back to normal then ur cables make a difference if ur using a SD TV use regular cables if HDTV use hd cables only on hdtv if use on SDtv it won't display or ur ps3 is set to an hd setting like 1080p it won't display on a sdtv so reset ur ps3 by holdin power button hope this help u
Jul 16, 2009 | Sony Playstation 3 (PS3) Console
It turns on but wont work
Turn off the PS3 from the power switch on the backside of the PS3, wait a minute and power back on.
May 25, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
186 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
