Question about HP LaserJet 4350 Printer
Cannot change printer paper size from A4 to letter through windows. it doesnt have [paper size] in paper/output in advance settings.
    Scholar:
  • 96 Answers
Check the tray and physically change the internal sizing tabs.
Posted on Sep 25, 2009
Kyocera Printer is not printing. Error is "Add Paper. Letter"
This is a common error due to many printers set default paper printing size as a letter size, and you don't have it in printer.
You need to set the output paper to the one that you have (I guess it is an A4) in advanced setting on the printer.
Hope this help!
May 20, 2011 | Office Equipment & Supplies
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
How do I change the default paper size from Letter to A4 in my HP Officejet Pro 8500 Wireless?
Don't set by using the "Print" option.
Go to [Start]
[Printers and Faxes]
right-click on the HP Printer entry
! Don't select "Printing Preferences"! from there
Select [properties]
Select [Advanced] tab
Select [Printing Defaults]
[Advanced}
(I know, the screen looks the same, but it functions differently this way)
Change paper size to "Letter"
[OK, OK, OK]
*done*
Sep 25, 2009 | Office Equipment & Supplies
Whenever i change paper size from A4 to letter,
Go to [Start]
right-click on the HP printer entry
Select [properties]
[Advanced}
[OK, OK, OK]
*done*
Sep 25, 2009 | HP LaserJet 4350 Printer
Load A4
A4 is for european size, if you are printing on a letter size this is a mismatched.
you need to change your files printer properties to A4 or letter size, or change your printer paper size.
better yet cancel this document and send it again , this time by checking the printer properties was set to your desired paper size
Jul 28, 2009 | HP LaserJet 2840 Printer
Pc load letter
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
May 28, 2009 | HP LaserJet 4 plus Printer
HP Laserjet 3050, need to press ok each time printing
did it work before? check paper size for trays - suspect it is set for a4, change to letter size
Mar 12, 2009 | HP LaserJet 3050 All-In-One Printer
Printer will not print: Canon imageCLASS D320
The paper size selected in the menu system must match the paper size in the rec. (recording) paper tray. If you have 'letter' size paper in the tray and the menu system is set for 'A4' paper you will get this message. Either put A4 size paper in the tray, or change the paper size in the menu system to 'letter'.
Oct 15, 2008 | Canon imageCLASS D320 All-In-One Laser...
My hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Sep 23, 2008 | HP LaserJet 4 plus Printer
Printer keeps saying change paper size
Go to Control Panel - Printers and on MF3310 right click and choose Default settings. I had to change page size from Letter to A4 and output size from Match page size to A4 as well. Finally, after 4 hours of investigations it worked.
Jan 30, 2007 | Canon MF3110 All-In-One Laser Printer
HP LaserJet 4350 Printer Logo
219 people viewed this question
Seeker5211
Seeker5211
