Question about Plumbing
PROBLEM; Aqua Brass faucet that controls water to either the tube or shower has come apart. The problem is that the metal pull lever that is situated on the top of the faucet has come off. With that, the internal plastic piece also has come off the pull piece that was located interally inside the faucet. I tried to place it back inside the faucet however it appears there is something missing and the parts will not stay inside.Question, is there just the one plastic piece with the small washer that fits inside the faucet or is there something else that I am missing. If not, why can't I connect the control metal arm to the plastic piece back in place inside the faucet?
  • 334 Answers
You are probably missing the clip that holds it together.
It may be easier to just replace the tubspout/diverter with a new one.
Most just screw off, some are mounted with an allen screw on the underside and use washers to prevent leakage.
Replacement time 15 min. Cost 12 bucks.
Rebuild the diverter and you may make several trips to the stor just to find tyhe right parts. You will still have an old diverter/spout. and take just as much time repairing it.
Posted on Sep 25, 2009
We need to replace the 4 way valve for our bath tub/shower faucets. Parts from the schematic "101 - CENTRALE 4 VIE C/PROLUNGA CM.4" (Rubinetteria "SIMBOLO" Aqua Brass faucets
take the details along to a plumber supply shop ( not a hardware shop or mart) and there will be some one there that will be able to advise on parts , problems or replacement equipment
Dec 11, 2015 | Aqua Brass Home
Thermostatic valve does not turn
followt this steps and fix it. God bless you
  1. Turn off the water supply and open the faucet handle to relieve water pressure.
  2. Carefully pry off the trim cap with a small screwdriver or putty knife.
  3. Remove the locknut with an adjustable wrench, then lift the spindle out of the faucet.
  4. As needed, remove and replace the O-ring. Before reinstalling, coat the stem lightly with plumber's grease.
  5. As needed, remove the retaining screw and pry out the washer. Install an exact-replacement washer and tighten it.
  6. As needed, inspect the seat and replace if damaged.
  7. Install the valve and tighten, then reinstall the handle and test.
Nov 28, 2013 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
Aquabrass tub drain control lever cover separated from nut
lock tight red or stronger will bond it together . but forget remove it after
Nov 16, 2013 | Aqua Brass Deckmount 5 pc tub set with...
Aquabrass tub drain control: cover separated from nut
Try using jb weld or another type of epoxy that is water proof. 100% silicone caulk may also be worth a try.
No water coming out of spout even though water enters system up to and beyond distribution valve.
this may sound stupid but i resently installed one and if then water pressure was not balanced between the hot and cold the unit would not work
Oct 30, 2011 | Aqua Brass Single lever faucet AQUA BRASS...
Why is there restricted water flow
It may be as simple as cleaning the aerator out. If that is not the case then you will need to disassemble the faucet and investigate.
Feb 06, 2011 | Aqua Brass AquaBrass 10317 1/2...
8" shower head with thermostatic
your litre per minute usage is probley greater than the recovery time on the cylinder..install a dual coil cylinder and pipe a heat exchanger off central heating system through second coil and you shall double the recovery time on tank,both coils should be controlled through pipe stats for effiency purposes
Jan 15, 2011 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
Rusty water comes out of cold water faucet
Rust is usually a sign of galvanized pipe mixed with copper pipe incorrectly.Could be the pipe nipple used for the tub spout connection to the valve.You could change it to a brass nipple might be the problem
Jun 24, 2010 | Moen 1 Handle Lever Shower Faucet With...
Have single handle lever delta shower faucet which is leaking--am trying to replace parts -- cannot find how to description......
Try this link, it should get you to where you can find yours, if this isn't it. Then you can view parts, installation etc.
http://www.deltafaucet.com/customersupport/documentation/1343.html?document=pd
Apr 29, 2010 | Delta & Single Handle Shower Faucet
Plumbing Logo
75 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
