Question about Zanussi ZWF1440 Front Load Washer
E40 error code
My washer started to really smellof burning and stopped mid cycle now it does nothing and has an error code of e40 any ideas?
  • Anonymous Mar 29, 2014
    machine sits and clicks but does nothing else
    ERROR CODE E40
  • 96 Answers
The E40 error code indicates a loss of electrical power usually but not always due to the door not shutting properly or not locking. But, since you smelled burning it could be any electrical short that blew a fuse and shut the machine down. It could also be the motor windings with the internal overload protector shutting it down.
Posted on Mar 07, 2008
  • edge_jones
    edge_jones Aug 23, 2012
    I have a simmilar issue the drium stopped working and I have an error 40 and a screeching sound. I have opened the back of the machine and the motor is not turning. I cant even turn the motor when the machine is off . I have seen your diagnosis. What do i do next. Chuck the machine or get an expert in to fix it?
How to fix the error code E40 on Electrolux EWF1073 Front Load Washer?
I don't have an electrolux, but I have an LG front loader. Mine was giving a simular error code, and I found the drain hose filter was clogged. Bee running fine since
May 07, 2014 | Zanussi ZWF1640 Front Load Washer
Turned off mid cycle. Tried putting back onfor drain, also rinse and restart. Each time get error E40.
Hi.
With AEG washers E40 means defective door lock. Since a faulty door lock switch may go out with vibration you often do not get the error all the time. The door lock switch must be tested and eventually replaced. Call the AEG number listed in the user manual if you want to get in touch with an authorized technician or if you need replacement parts for your washing machine.
Regards.
Ginko
Sep 18, 2011 | AEG Washing Machines
Machine stopping mid cycle
Count the number of green flashes(1st number of error code). count number of red flashes(2nd number of error code).
Common codes are:
E10 or 11 water pressure faults.
E20 filter/pump faults.
E30 pressure switch/heater faults.
E40 door switch faults.
E50 motor faults.
E60 Heater faults.
These are some of the error codes but there are many variations on some codes depending on the model.Hpoe this has been some help.
Apr 24, 2010 | Zanussi ZWF10070W Front Load Washer
Washer stalls mid-cycle and keeps running but doesn't progress
check to see if the water is warm if not the heater has gone or the thermistor is faulty
if warm i can be a dead spot on the timer where the contacts are worn if so needs new timer
Jul 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag performance series washer model mhwe500vp stops mid cycle
having the same problem found in side a small black hose with a small hole in it but have no idea what this hose is for. may be it is connected to some water sensor.
Jun 27, 2009 | Maytag Performa PAV2200
Whirlpool Duet Front loader mdl WFW8300SW00 will not start
I had a variety of error codes show up on my duet, and I'm not sure but I seem to recall a 31, but the most constant was 02. I took off the front cover, pulled the white plug out from the unit, put a bucket under it, unscrewed it and drained it. It may be the MCU is having problems because the washer got plugged up.
Apr 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Dec 11, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1440 Front Load Washer Logo
1,804 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
