Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Our tv has bent focus lines and the colors are distorted. The upper and lower portions of the screen are distorted. Magic focus did nothing?
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
1.) Based on your description one or both of the two STK-392-110 OR STK-392-150 (SET MAY USE EITHER OF THESE) chips is bad.
2.) If you can do this you can save a lot of money as most TV repair shops charge 300-400 for this kind of repair----you can buy the chips on Ebay for under 20 dollars for a pair OR THERE are several sites on the internet that sell "kits" which include the chips and several resistors that may be needed(they are located around the two chips and sometimes one of them gets taken out when a chip fails---these kits seem to average 40-80 dollars----
3.) The reason this problem happens is the chips are black and about 2 1/2 inches wide and 1 1/2 inches tall with 18 pins each---- the back of each chip is metal and a white grease called heat sink compound is applied to each chip that transfers heat quickly to the heat sink---after 5-8 years the grease dries out and one of the chips gets to hot and fails. You can look inside the set and see them on metal heat sinks with fins---they will have the STK number printed on them in white.
If you unplug the set and remove the back cover look for them and take a close look at all the resistors----most of the time they will look discolored in the middle if they are bad---all have a location number printed on top of the board---if you need more information about this let me know.
4.) If I remember this 2003 model set---the chips will be on the large board on the right(as you look from the back of the set) and if this is what you have I can tell the best way to get at them.
I hope this information was helpful and if you have any questions or want advice let me know.
SD TECH
Posted on Sep 25, 2009
I have a 65 inch Hitachi projection TV and all of a sudden lines apperaed on the screen that runs across the upper part of screen. I tried using the"Magic Focus" setting to get rid of these lines...
The tv Magic Focus button don't solved these R,G,B colors lines mis alignments problems.Mean ur tv have a convergence pictures problems,it is dead.Ur tv now have any colors lines like R,G,B mis alignments,have a colors shadows picture or a 3D pictures look alike?Yes,mean ur tv convergence board it is dead to causes all of these pictures problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 24, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
Convergence
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 06, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Video display is concave-distorted in upper and lower portions of screen. Problem is intermittent in nature and occurs whether watching cable or dvd. audio and everything else works fine. Any gurus out...
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 30, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Upper left corner is distorted and neon green
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 06, 2010 | Hitachi 43UWX10B 43" Rear Projection...
There is a yellow ''swoop'' in the upper left portion of the tv and shadowing. The ''magic focus'' does not resolve the problem. When I try to adjust manually, the grid shows arched lines (''swoops'' along...
Sounds like you have a bad convergence circuit, it's what lines up your picture so the colors are correct. Most brands (excluding RCA) use the same basic design. There are 2 big ICs called STKs that normally fail, some resistors or fuses may also go. Its about $300-$400 bucks to have someone repair it. If you want to try it yourself, this link TVrepair will take you to a site that sells kits with the parts and step by step instructions on how to fix it. Good luck
Mar 06, 2010 | Televison & Video
Hitachi 43fwx20b Convergence Problems
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 25, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Faint lines show up when i get dark screens in movies
First check what color of faint lines comes then reduce Screen Volts in TV of that CRT (tube)
Take off lower front cover, speaker grille of TV, there you will see focus control block that has 6 control knobs, upper 3 knobs are focus adjustment of red-green-blue CRTs and lower 3 knobs are screen volt controls for red-green-blue CRTs. Turn screen volt control knob CCW to reduce screen volts of desired CRT.
Put TV on any free AV input so screen will be dark enough to adjust screen volts.
Thanks.
Aug 28, 2009 | Sony KP-57WS500 57" Rear Projection...
Hitachi tv magic focus does not work
Your problem is the convergence circuit. This is very common in CRT projection sets like yours. There are a couple of IC's that need to be changed and possibly some resistors. A good repair shop will run you $400-$500 to do the repair.
Oct 28, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Color distortion
Move any speakers or electrical devices away from the set. It could also be anything electronic or magnetic. Anything near the set that generates a magnetic or electromagnetic field could be causing the distortion.
Jun 04, 2008 | Zenith A36B41W 36" TV
Color convergence?
Can anyone give me the resistor values for location RK 42, RK 46 and RK 62? Hitachi 46F500 TV. Or can I be pointed to the location of a service manual?
Tony
Sep 13, 2007 | Hitachi 46F500 46" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
136 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
