The tub on my whirlpool washer fills with water but will no spin
The tub on my whirlpool heavy duty super capacity plus washer model number lsr7233ezo fills with water and drains but won't spin. It makes a noise like something is spinning but when I looked under the washer I couldn't really see anything
I am not a appliance repair technician, but before one starts taking apart motors, and drives, it would be imparitive to simply check the lid switch I have repaired several washing machines by simply checking this part.
Posted on Jan 05, 2010
  • 5,911 Answers
If the washer will fill and drain, but won't agitate or spin, this is usually a sign that the motor coupling has broken. The noise of the motor engaging, lack of agitation and ability to still drain are common symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If you have questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
Posted on Sep 25, 2009
  • Jeff Rockwell
    Jeff Rockwell Jan 06, 2010
    NOTE: If this were a lid switch problem the washer would NOT drain. This is NOT a lid switch problem. The whirring noise you hear is a broken motor coupling which is used to transfer energy from the drive motor to the gearcase (transmission). Your drive motor is still spinning, but with the coupler broken, the gearcase is no longer connected to the motor. This is a very simple and inexpensive repair if you follow the steps in the link I provided.
Whirlpool heavy duty super capacity plus washer will not agitate or spin. I replaced the agitator dogs but still have the same problem, is this a transmission issue?
Your model may have a flexible (break able) drive component between the motor and the transmission. Check that, it is a pretty easy replacement.
Jan 22, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Whirlpool heavy duty super capacity plus machine. Does this model have an water input filter. Water flow is very low while filling.
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
May 18, 2010 | Washing Machines
Whirlpool Ultimate Care Heavy Duty Super Capacity Plus
clutch could be it check if nothing is jammed between tub andbasket. if u have an oily tranny i would replace it
Feb 12, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a model #LAT8714AAE Dependable care plus Heavy duty 2 speed super capacity washer. I replaced the timer and the unit will not start when dial is turn to 12 ( it will not start filling up) but if you...
CHECK THE FUSE ON THE LID SWITCH BELOW THE TIMER. IF ITS BLOWN YOU NEED THE LID SWITCH ***.SOMETIMES EVEN IF ITS NOT BLOWN THE SWITCH IS BAD
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 13, 2010 | Maytag Washing Machines
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Fill Cycle Won't Stop
heres hteaprt numbr for both the water level switch and the connecting tube, before i replace he switch make sure the tube is connected to rear of tub nad isnot cracked or kinked, and connected correctly to the switch for that matter. a hole in the tube would hamper he switches ability to sense when unit is full
3356466 water level switch,3347780 pressure switch tube
Mar 16, 2008 | Whirlpool LSQ9030P Top Load Washer
Washing Machines Logo
266 people viewed this question
Top Washing Machines Experts
