Question about HP Pavilion dv9000z Notebook
MY HP vs17x monitor is blank
I have Exactly the same problem as the other person. The computer was on when I came back home blue power light was flashing, ever since I cannot get it to turn on. Any thoughts??? Doesn’t this sound like there is a common manufacturing problem with the monitor?
  • 3 Answers
While the above solutions would work on 90% of the laptops with this problem, these model have a different problem I know I have repaired hundreds of these models along with tx1000, and dv6000 series........ here is your answer...the nvidia chip is coming loose from the motherboard. and needs to be "retacted" to the board.
Not is easy thing to do but can be done. Computer_solutions_2000@hotmail.com
Posted on Sep 25, 2009
    President:
  • 1,187 Answers
Please do not disable hibernate mode......
This is a common hibernation issue ... here is the fix:
Once you are able to get it to start up again (there is no sure fire way to do this, it just happens!).
The virtual memoryMY HP vs17x monitor is blank - 2.gif size is set too low! It must be set to an amount larger than your amount of physical memory. (If you have 2GB or memory, then Virtual memory must be more than 2048MB.
Right-click [My computer]
In the [General] tab, note the amount of RAM
Select the [Advanced] tab
Select the [Settings] button in the "Performance" section.
Click on the [Advanced] tab
Click on the [change] button in the "Virtual Memory" section
almost there!
Highlight the boot drive (C:)
Don't change the locartion of the VM file.
Select "Custom size" radial button.
Enter a number that ois larger than your physical memory from the General tab
1GB = 1024MB (plus 512MM or so) = 1536MB
2GB=2048MB (plus 512MB or so) = 2560MB
3GB=3072MB (plus 512MB or so) = 3584MB
[SET]
[OK]
[OK]
etc.....
    President:
  • 2,600 Answers
I don't believe this has anything to do with your monitor. I believe the computer went into hibernation mode and has gotten stuck there. Try to reboot the machine into the BIOS by tapping the delete key while rebooting. If you can, go to the last page in the BIOS and select reset to defaults. Hit the F10 key and reboot. Try to boot back normally, if you can, good, if it still won't go, try to boot into safe mode by tapping F8 during startup, if you can't see anything on the screen during this startup, you may be able to hear a tone when the BIOS starts, start tapping F8 at that point and see if the multi-boot menu comes up on the screen. If it does, choose safe mode with networking. When it boots up and you see the screen, go to control panel > power options > go to the hibernate tab and uncheck the box. reboot normally.
Polaroid TDAC-02212 will not turn on. The red light is on and turns to blue momentarily when the power button is pushed. The screen will flash a little then back to off, with the red stand by light.
It may fix it with a new power supply but personally I'd recycle it...that wasn't a good set when it was new, lots of issues, Ive personally never seen a good Polaroid TV, they should have stuck to cameras as they were great back in the day.
Dec 10, 2017 | Polaroid Televison & Video
The blue power light and the blue and red battery lights keep flashing and won't stop Why?
Sounds like the battery itself is going bad and needs to be replaced. The blinking lights are a code that you can find at the OEM website and it will tell you exactly what is going on..
Feb 01, 2014 | Acer C7 Chromebook
Monitor will not come on, blue light just
Check for leaking/bulging caps in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 02, 2010 | Samsung 204T 20" LCD Monitor
Monitor is on but stay black, blue light flashes, ...
Check out the power supply section first.
May 21, 2010 | Samsung SyncMaster 220WM Monitor
Power light is flashing blue but no pic
Please verify that it does the same with other PC also before taking it apart, if it still does not work, then please read below:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Apr 15, 2010 | Gateway FPD1975W 19" LCD Monitor
It takes an hour or two to come on blue light
Power supply caps should be checked out, look for caps with bulging top first, post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 26, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
Blank screen, flashing led power light
this sounds exactly like what happened to my 2232BW. I took screenshots of the fix and posted them on my webpage:
http://www.alexdemo.site90.com/#samsung2232bw_fix
Jun 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Jul 16, 2008 | HP Pavilion a1250n (EG194AA) PC Desktop
Blinking Blue Light.. >.>
check for loose connection of the video cable connection on the system unit (CPU). blinking may indicate that there is no signal transferred from the cpu to the monitor!
Nov 04, 2007 | Liquid Video L17LCD2 17" Flat Panel LCD...
HP Pavilion dv9000z Notebook Logo
517 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
