Question about HP PSC 1610 All-In-One InkJet Printer
How do I fix a cartride jam?
How do I fix a cartridge jam? An error message reads: open cover, clear cartridge jame and press okay. How do I cler the cartridge?
  • 2 more comments
  • hl6892t Sep 25, 2009
    Is it okay to move the carriage?
    I have checked for jammed paper-there isn't any. I have moved carriage to the leftand pressed okay-it initializes then goes back to the error message
    yes-it initializes then goes back to the error message
  • A Miller May 11, 2010
    Have yo opened the cover and removed the paper or tried to move the carriage yet?
    Scholar:
  • 97 Answers
Have you tried
(1) running "print clean" or something like that?. (If you don't know how to do that, check your manual).
(2) Removing cartridge/s and installing again?
(3) Cleaning head by dabbing lightly with Q-tip in isopropyl alcohol?
Other possible solutions depend on answers.
Posted on Sep 25, 2009
Wat is an LSU error on a phaser 3200 MFP
Change the toner cartridge , i have many units phaser3200 and this is one of the problem , but only if the toner cartridge is very old and many time refilled , if not , change the Laser unit .
  1. Remove a misfed document if the copier displays a message reading "Document Jam." Lift up the document feeder cover and turn the roller to remove an Exit Misfed document. Lower the document feeder back into place and feed the document through again. If the document is jammed on the Input side, open the cover and gently pull the misfed document to the right and out of the feeder.
  2. Pull out the paper tray and lift the tray to release it from the copier if the copier displays a message reading "Paper Jam O." Remove the jammed document, and open and close the side panel of the copier to clear the error message.
  3. Unplug the power cord and plug it back in again if the copier displays a message reading "Fuser Error, Open Heat Error, Heating Error and Overheat." If the problem persists, call for a service.
  4. Remove the toner cartridge and shake it from side to side if the copier displays a message reading "No Developer Cartridge." If this does not do the trick, you may need to replace the cartridge. Pull the release latch to open the side cover, and open the front cover. Twist the cartridge locking-lever upwards and remove the toner cartridge. Insert the new cartridge and lock the lever into place. Shut the front cover and the side cover.
  5. Power off the unit and power it on again if the copier displays a message reading "LSU Error." A problem has occurred with the Laser Scanning Unit. If the problem persists, call for a service.
Jan 04, 2011 | Xerox Phaser 3200MFP/N Laser Printer
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
I have a paper jam and it says to open the front cover, put the front cover just shows the ink cartridges and there is no visible paper jam. how do i find the jam and remove it? It's a canon image...
The paper jam could be in three places.
First:
Open the cover of fixing section, its above bypass, and check for jamed paper
Second:
Open the transfer cover, these cover has handle and it goes by pulling toward you, and check for jamed paper.
Third:
In hight of first paper cassette, on left sideway of copier, beaneath the bypass are small door, open it and check for paper jams. Be sure that you closed them properly because if they arent closed the check printer cover message will arrise.
Hope that helped
Jul 07, 2010 | Canon ImageRunner 1600 Copier
HP C4385 display reads Paper Jam continuously
check the paper jamed or not other wise try to reset your printer
Oct 03, 2009 | HP LaserJet P2015dn Printer
Canon MX860 Rear Paper Jam
I have a small piece of paper jammed in my Canon MX-860 that Cannot be seen from anywhere. Can you help me find so I can clear it
Jun 27, 2009 | Canon Office Equipment & Supplies
Ink System Failure
I just had this problem with a HP C5150 and I found this bit of conversation on the web and it worked for me.
My error code was 0xc18a0501 and the following steps did resolve my issue, hope it helps you as well.
  • OK I had the hp error code 0xc18a0001 problem and here is the conversation I had with the tech.....
    james cowan: hp error code 0xc18a0001
    Earnest: I will assist you in this regard
    james cowan: great
    Earnest: I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
    james cowan: correct
    Earnest: Thank you for confirmation
    Earnest: May I have the model number of All-In-One you are using?
    james cowan: c6250
    Earnest: Thank you for information.
    Earnest: James, please let me know the room temperature in which printer is replaced
    james cowan: 67 degrees f
    Earnest: Okay
    Earnest: Please perform the below steps on the front panel of the printer to resolve the issue
    james cowan: ok
    Earnest: Press and hold the "left arrow" key.
    Press the "Setup" key and release both keys, Display should say "Enter Special Key Combo"
    Press and release the "OK" button.
    Earnest: Please ignore the above steps, James
    james cowan: ok yes nothing seemed to do anything
    Earnest: Press and Hold the "Print Photos" &"Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo"
    Press and release in sequence"Red Eye Removal","Print Photos","Red Eye Removal"
    Earnest: Display should say “Support” and display the FW rev (something like R0616R)
    james cowan: COxxFN0723BR j
    Earnest: Okay
    Earnest: 2. Press and release the right arrow button until the display says “System Configuration Menu
    james cowan: ok
    Earnest: 3. Press and release the "OK" button.
    james cowan: ok and it says hardware failure status
    Earnest: Display should say "Hardware failure status: Clear. Press OK to clear".
    Earnest: Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
    Earnest: Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    james cowan: ok
    Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    Earnest: Let me know once you are done with the above steps
    james cowan: ok its unplugged
    Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    Earnest: Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE".
    james cowan: ok
    Earnest: Let me know the message displaying on the front panel of the printer
    james cowan: printer preparation occuring - do not interrupt
    Earnest: Okay
    james cowan: ok its done
    Earnest: Let us print a self test page from the printer now
    james cowan: ok deal
    Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray.
    2) Make sure that the printer is on and loaded with unused plain, white paper.
    3) Press Setup . The Setup menu appears.
    4) Press the down arrow button to select Tools , and then press OK .
    5) Press the down arrow button to select Self-test Report , and press OK .
    james cowan: ok printing
    Earnest: Okay, please check whether all the colors pritned perfectly on the test page
    james cowan: perfect
    Earnest: Great..Cheers!!!
    james cowan: thank you very much
    Earnest: James, now you can continue using the printer
    Earnest: I appreciate your efforts and patience in trying to resolve the issue."
May 26, 2008 | HP Photosmart 3210 Printer
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
"Clear paper jam" error, but there is no jam!
Try cleaning the rollers, it's the maintenance tab on the printer's properties. Maybe this will help.
Feb 28, 2008 | Canon PIXMA MP130 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
90 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
