Question about Graco DuoGlider 7951 - G Collection Twin Seat Stroller
Graco Ultimate Nova 395 will not hold pressure. it was working fine today until the 5 gallon bucket got low. I tilted the bucket to cover the strainer, and reprimed the unit. After that it just kept hammering and would not hold pressure. what could have failed or gone wrong?
  • 15,935 Answers
Obviously this is not a stroller question??
This is a painter - correct???
(Discontinued)
Air has been introduced into the pump.... semi-hardened pait has gummed up the pump, tip, or strainer.
It must be cleaned and re-primed.
IF you haven't done damage to the pump already.
CLICK HERE for a parts listing.
Thanks for using FixYa!!
Posted on Sep 25, 2009
A graco ultra nova 395 stand model airless paint sprayer Will packing go bad after sitting an extended period of time ? It is not a tool I use very often but I do like to have a quality tool ready
yes
the gland packing will go hard from the paint contamination ( even though you washed the unit properly)
the secret is to get spares now before they become hard to get
talk with paint shops as there may be something you can spray through the system to keep the packing and seals supple
Jan 03, 2017 | Graco Air Tools & Compressors
Riddle solver
We'll call the 5 gallon bucket 5GB and the 6, 6GB
Fill 5GB and pour 5 gallons in 6GB.
Fill 5GB again and use that to top off 6GB, leaving 4 gallon in 5GB
Dump out 6GB and put the 4 gallons that are in 5GB into 6GB
Then fill 5GB and you have exactly 9 gallons of water.
Or bring him 11 gallons and tell him you did bring him 9 gallons and some extra!
Jan 08, 2014 | Office Equipment & Supplies
Trying to prime my 395 air assisted finish pro and I have fluid coming out of air holes in gun
I had the same problem. turned out I was using the rubber gasket on the tip saddle instead of the hard plastic one.
Aug 30, 2013 | GRACO INC FinishPro 395 Air-Assisted...
Water takes 30 sec to cover 10m from heater to tap
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } You are talking about length of time to get hot water from water heater.What diameter pipe are you talking about? What type of faucet do you have?
1/2" pipe has inside diameter of .54" and holds 1.2 gallons per 100 feet
10 meters is 32 feet and holds .4 gallons
Average faucet puts out 2 gallons per minute, so 30 seconds you should get 1 gallon of water.
Put a bucket under faucet and check amount of water flow.
Assuming you draw just hot water from the faucet, then 30 seconds is slow for receiving hot water.
If you have single-handle faucet and raise handle straight up in middle, then you are drawing half hot and half cold, so it would take 30 seconds for hot to arrive.
If hot water is slow, the problem might be crossover.
http://waterheatertimer.org/Crossover.html
or low water pressure due to clog in water line
http://waterheatertimer.org/Low-hot-water-pressure.html
Other problems could include clogged water filter, clogged water softener, defective pressure valve, and low water pressure.
Sources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/Water-heater-recirculation-system.html
Jul 10, 2011 | Bosch Outdoor Gas Tankless Water Heater...
Can you use a draper submersible pump for a garden irrigation system to use with several sprinklers, does it provide enough water pressure on the outlet?
Here's how to tell.
Connect a tee to the outlet of the pump.
Install a pressure gauge in the tee.
Install a valve after the gauge.
Open the valve and start the pump.
Once water flows, close the valve slowly until you get 50 psi on the gauge.
Have a 5 gallon bucket nearby and measure how long it takes to fill the bucket at 50 psi.
If it fills the bucket in 30 seconds, you can attach heads to the pump that combined consume 10 gallons per minute.
Let me know how you do.
Gary
May 29, 2011 | Garden
I am looking at buying a Wagner Max HLVP sprayer. The jobs are staining a modest stretch of fencng and a larger staining project of an overhead pagoda-type structure. Is this a good choice or would you...
I was a painting contractor for last 10 years of my work career.
If you are using HVLC cup gun, you will have to select correct tip,
You will need to thin the latex 50-50 with water, and keep paint strained to keep out all clogging.
If the tip is not reversible, then expect disassemble each time clog happens.
And you will be continually re-filling the cup.
And then if the surface is rough, the spray won't flow into the holes.
You have a mess coming your way.
Painting a fence: A roller is the only way to paint/stain rough surface.
Buy big hairy 1" roller cover from Sherwin Williams. Don't get the cheapo 1/4" thick roller cover because it doesn't hold any paint. The big roller holds a big volume of paint.
Now if fence is rough, like cedar, you need to thin the stain.
About 1.5 gallon water per 5 of stain ... and suddenly you have 6-1/2 gallons of stain which means you bought too many gallons of stain.
So don't overbuy the stain. And pick up 2 plastic bucket for mixing.
Empty gallon of stain into mixing bucket > put water into empty gallon > put lid on gallon and shake up > pour water into mixing bucket with stain > to mix: pour mixing bucket of stain back and forth between other mixing bucket until stain is mixed. Do this work on the grass where it won't run out onto concrete surface.
Put roller and frame on a wood pole that you took off the push broom. Now roll that stain onto every surface the roller can touch. Think of it like picking up quarters. If it was money, could you get the roller on that spot >> the answer is yes. Don't try to smooth it out and make pretty. Throw the stain on any way the roller can turn. Customers used to call that 'slapping it on' and I used to say, 'that's how it works, lady.'
Use a piece of masonite at the bottom. If you get stain on anything, wash it off immediately and use a wire brush on concrete surface or towel on smooth surface.
Wait for a day, because stain looks 100% better next day. And then go back with a brush and hit the spots you couldn't get with the roller. It will be faster and cheaper and fewer headaches than trying to spray latex stain with a HVLP cup gun.
To clean the roller: Leave it on the roller frame and wood stick. Turn on water hose and get the roller spinning until it's clean. Do this away from everything you don't want stain on.
Dec 13, 2010 | Garden
We purchased our refrigerator new in Jan 09. Worked fine until today. Today I emptied the ice bucket into a cooler and reinstalled the ice bucket,holder/dispenser. It has been 6 hours and no ice has yet to...
ck the elect eye the door may be covering the opening . also hold the lid on the left side in the closed pos and see if light on the right is solid. if blinking the sensor has failed. hope this helps mm
Oct 11, 2010 | Whirlpool Gold Series GB2SHTXTS (219 cu...
I will have low water pressure supply from source. how do i adjust for this? model GX200 with model Annovi Reverberi xtv 3g.22 pump
Low water pressure from source is generally not a problem unless water hose to washer collapses when use. You only need to supply the pump just 3 to 5 gallons of water per minute. Easy to check. Just open water supply to hose and capture water flowing out of hose into 5 gallon bucket (capture water in bucket for 1 min., should pretty much fill it ). Just use as normal. Good luck
Sep 06, 2010 | Honda Pressure Washer PSI 3000
If you have a five gallon bucket and a three gallon bucket and there are no measurement marks how do you calculate a perfect four gallons
Hello! Fill the five gallon bucket...Dump its contents into the three gallon bucket until it is full...leaving two gallons in the five gallon bucket...fill the five gallon bucket...Pour the five gallon bucket into the three, filling it...Tthis leaves exactly four gallons in the five gallon bucket...
Guru.......saailer
Mar 22, 2010 | Garden
Graco DuoGlider 7951 - G Collection Twin Seat Stroller Logo
450 people viewed this question
Top Graco Baby Gear Experts
Greg Cann
Greg Cann
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
