Question about LG 50PY3D Plasma TV
Vertical color lines show up and don't go away
  • beehappy45 Nov 03, 2009
    There is green lines in the middle of the screen anyone know how to fix this
  • LG Master
  • 458 Answers
If they are thin vertical lines then I'm afraid there is a fault within the plasma screen & this would need replaced which is a very costly repair.
Posted on Sep 25, 2009
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: vertical flickering color lines instead of pictures
Soory man there is no deflection yoke or vertical output IC in a plasma TV set.LOL This person has a problem with whats called the substain power supply or bad caoacitors in the main supply. there is also a possibility that the set has a bad tuner. Only performing test on the set will determine the problem.
Posted on Mar 23, 2007
  • 12 Answers
SOURCE: colored vertical lines on half the screen
yeah get a new tv, and not a mitsubishi, they all seem to have the same prob over time. the lines mean that your picture is on its way out
Posted on Apr 25, 2009
  • 23 Answers
SOURCE: plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
Posted on May 02, 2009
info33
  • 72 Answers
SOURCE: Colored "snow" vertical line an inch thick on Samsung plasma
That is the sustain and buffer boards. Try to find a repair shop to repair on the component/board level because the cost of new boards out weighs the replacement cost.
Best Regards,
Beach TV Repair
Posted on Jul 04, 2010
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
No picture, only colored vertical lines
Settings. It sounds like the convergence. It needs to be adjusted. Have had this problem before. A lot of people actually throw there TVA away because they have this problem and they think its broken, when its usually just a simple fix of adjusting the convergence. You have to make sure the little box, on the convergence settings is in the middle. Hope it fixes ur problem. :)
Dec 30, 2012 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
When switching tv on it shows vertical lines and fades away
This can be an indcation two things 1: a defective focus/screen block or 2: a defective CRT if the lines are of one color then it is that color CRT. in any event you will need to have a tech work on this, doing this repair yourself can be very dangerous for you and the set.
Jan 19, 2011 | Sony KP-57WV600 57" Rear Projection...
My 52ince LCD Sony Bravia TV is started showing 2 vertical lines on each side, but they go away 20 minutes after starting TV. What is wrong?
The tv board call the T-CON decoders board have problems,that why colors vertical lines are showing up in the tv LCD screen panel.The T-CON decoders board,this board sit wright at middle bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Oct 29, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My Sony KDL-32XBR4 has vertical lines for 5-15 minutes on startup
I have a 46 inch , Sony XBR 4 tv . The past week there has colored vertical lines that appear on the screen for about 10 minutes . Then they go away . What is the problem and solution?
Jul 10, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Vertical white line near the left end of the screen.
Usually when there are colored lines on the LCD its because the screen is going bad. Quick way to verify this, try a different monitor on your computer and if the line goes away then you know for sure the monitor is bad.
If you try a different monitor and the line remains then you know that the video card is bad.
Jun 03, 2009 | Mitsubishi Power Adapter for DiamondPoint...
Plasma TV with vertical lines
Mar 23, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Mitsubishi WD52527 Pinstripe vertical red lines
Is the set blurry with pinkish color and white lines?
Dec 21, 2007 | Mitsubishi WD52527 52" Projection HDTV
Vertical flickering color lines instead of pictures
Take your set to a qualified tech you have a bad vertical ic or some cap around the vertical section is not filtering the voltage properly and your deflection yoke could also be bad.good luck.
Mar 16, 2007 | Sony PFM-42X1 Plasma TV
LG 50PY3D Plasma TV Logo
832 people viewed this question
Computer Repairing
Computer Repairing
