Question about Mitsubishi WT-46805 46" Rear Projection Television
Tv wont power up
Mitsubishi big screen you turn on and the power light comes on and then goes off,so it wont power up
  • toseize Feb 05, 2008
    Same thing here. Worked fine yesterday, with just image convergence issues. Now, you turn on the power (either at the unit or from the remote), and the power light blinks on and off, with 3 or 4 audible clicks inside the TV.
  • pcboards Nov 24, 2008
    Same issue but with model vs60803. My DEFL-MINI Board (#935D400002) does not have same components listed in fix provided for WT46805 model, listed fix as: "CHECK C5A09 AND C5A50 BOTH 33 UFD 50 V OFF OF IC5A01 ON PCB-DEFL MINI." Could some please provide the same relative solution but for vs60803. Thanks!
  • 927 Answers
Good Day, y'all;
Try these:
CHECK CONNECTOR "DR" FOR PROPER CONNECTION, BETWEEN THE DEFL MINI PCB AND THE MAIN PCB. 2. CHECK C5A09 AND C5A50 BOTH 33 UFD 50 V OFF OF IC5A01 ON PCB-DEFL MINI. 3. CHECK FOR LEAKY IC5A03 PART # 270P704010 ON PCB-DEFL MINI 4. SUSPECT THE HIGH VOLTAGE BLOCK PART # 920P016010.
NO POWER. RELAY CLICKS 1. CHECK Q501 (261P071010), Q502 (260P561020) AND Q503 (260P788010). IF ANY OF THESE TRANSISTORS ARE SHORTED OR LEAKY REPLACE IT INSURE THE FOLLOWING CIRCUIT CHANGE HAS BEEN DONE. REMOVE J58 FROM THE PCB-MAIN. USING AN INSULATED JUMPER WIRE, SOLDER A 22 OHM 1/4W RESISTOR BETWEEN PIN 4 OF THE RELAY K9A30 AND THE J58 HOLE NEXT TO PIN 1 OF CONNECTOR DQ. DRESS AND INSULATE THE JUMPER AND RESISTOR TO PROTECT AGAINST SHORT CIRCUITS. INSTALL A .01 UF 50V CERAMIC CAPACITOR BETWEEN THE COLLECTOR OF Q510 AND THE GROUND LEAD OF R502. NO POWER. NO RELAY CLICK 1. CHECK FOR 5 VDC AT PIN 9 OF IC700 (AC-OFF) IF MISSING CHECK PC901 PART # 268P058020, ON THE POWER PCB. Good Luck, big IRISH. tv wont power up - back.gif back.gif
Posted on Jul 25, 2008
Why wont my mitsubishi big screen tv turn on? the green light comes on but then shuts right back off.
Model number given indicates it should be a 2000 year model.
If so, it should have the self check feature; try to turn the set on and when the green light goes off: On the front of the set press and hold both the menu and input buttons for at least five seconds and then release both buttons.
Power light will blink a two digit error code like: 2 blinks,pause and 2 blinks (2,2 error code is most common one). It will repeat the error code several times.
Let me know what error code you find and I will tell you what it may mean.
if this told you something you did not know rate this solution as "very helpful" as I do this here for free.
You can post a comment on this page.
Regards, SD TECH
Aug 11, 2010 | Mitsubishi VS-60607 TV
MITSUBISHI TV VS-60607
HI there,
Check for any bad solder on the mainboard of the TV, and also check for any burn fuse on the powersupply area... BAd solder was very common problem on Mitsubishi TV..
micro
Jun 07, 2008 | Mitsubishi VS-60607 TV
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
Feb 17, 2010 | Mitsubishi WS-55819 55" Rear Projection...
I have a mitsubishi 1080 series wt-42311 model. When I turn on the TV the green lite comes on then goes off? The TV wont turn on.
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
Sep 18, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Problems w my mitsubishi hdtv big screen
Typically this is a indication you have a Power Supply problem and not something you can fix with out a repairman unless you have knowledge of the Power supply Circuits in these models . Play it safe. Get a repairman who is authorize by Mitsubishi to look at it.
Hope this Helps,
Skyassoc
Jun 28, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi Big Screen Digital 65 inch
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
Feb 16, 2009 | Mitsubishi WS-55807 TV
Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Tv wont turn on
your power supply is bad and needs replaced
Oct 26, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Mitsubishi ws65869 big screen tv
Does the LED power light come on? Have you checked the fuses?
Feb 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
