Question about Frigidaire GLGF386DQ Gas Kitchen Range
The door is locked and i don't know how to unlock it.
  • 1,889 Answers
If you remove the range top screws you can lift up the top and, pull the locking rod attached to the locking lever/relay toward you to unlock
Posted on Sep 25, 2009
Expedition door lock
Replace the battery on the key fob! Also, it may need to be reprogrammed by the Dealer!
Dr. Gene n Landrum
May 19, 2013 | 1999 Ford Expedition
Power locks won't unlock 2006 focus
The power door locks are controlled by a Body computer or GEM module . Do yourself a favor an take it to a qualified repair shop because you don't have a clue .
Mar 01, 2017 | 2006 Ford Focus ZX3
On my 4 x 4, the passenger break lights don't work but the bulbs are good. What do I look for?
When you lock and unlock the doors, this is usually the side light which illuminates, not the brake light.
Remove the brake light bulb, (which also contains the side light filament) and check the filament. It's likely blown, so simply replace it.
Nov 03, 2012 | 2007 Chrysler Aspen 4x2
I don't know the model # but its a kenmore oven and my daughter left her finger on the stop button too long and so the oven door automatically locked us out. I can't find the book for it
According to the eHow website,
"press and hold the stop/clear button for 3 seconds to unlock the door."
(it's the same to lock the door in the first place.)
According to the Just Answer website, either press and hold the stop/clear button for 3 seconds or 5 seconds, (A beep will sound. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked and the lock icon light has cleared.) or you have to press the button 3 times quickly.
Sep 25, 2012 | Kenmore Ovens
Locks set off alarm
Inside the door is a door switch that is called the tamper switch or door ajar switch, each door has one, it may be defective, it is the Ford designed switch and they have had problems. To confirm the next time the system goes off, unlock and lock the passenger door if it has a lock, my new car doesn't and I know many makes don't have any passenger side door lock cylinder. If doing that shuts of the security system the switch is surely defective or the wiring to it is damaged.
Sep 12, 2012 | 2005 Jaguar XK8
Central locking goes on and off whilst driving
Check your master switch on the door panel. If all doors are doing it, the master lock swith is suspect. Don't know if your car has a body control module, or if it has anything to do with the locks. good luck.
Oct 27, 2011 | 1997 Plymouth Grand Voyager
I have a 2007 Toyota RAV 4 I can't get the remote to work after changing the battery does it have to be reset if so what has to be done. I can lock and unlock the doors manualy but not with the remote...
1. get in the car
2. shut the door
3. place the key in the ignition
4. lock the doors, manually
5. turn the ignition to on then off...do this seven times
6. unlock the doors and try your remote
Sep 20, 2011 | 2006 Toyota RAV4
Door locks lock and unlock by themselves even when the truck is off.My ac also comes on when I put on the defroster.
As far as the door locking and unlocking, don't know on that one. Could be a possible battery issue in the key fob and/or a chaffed wire somewhere. The a/c is designed to come on when the defrost is on. Almost all car manufactures do this, it aids in defogging the widows quicker. Good luck on this.
Sep 11, 2011 | 2000 Chevrolet Blazer
A friend of mine has a Lexus 1997 ES and his remote control needs reprogramming. How do I do it for him. Thank you so much.
1. Driver's doo opend and unlocked, all other doors closed and locked
2. Inser Your key in ignition, don not turn, remove key
3. using the manual lock/unlock button on ther dirvers door, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times)
4. Shut door
5 Open door
6. Using the lock/unlock button on the direvers door, slowly press and unlock 5 times (count the lock 5 times and the unlock 5 times)
7. With the door open insert you key into the ignition, turn to ON position (don't start), wait 5 seconds. Trun off and remove key.
8. Locks should cycle once (Car will lock and unlock once). If they don't cycle or they cycle more that once, do stips 1-7 over.
9. Using the remote, push lock button, hold for 1 second, release. The locks should cycle once. If not start over and go slower.
10 Close the door. Open the door. Press the lock button on the remote. The locks should cycle. Close the door. Press the lock button on the remote, the doors should lock. Press again and the doors shoud unlock.
I got this from a site called FixYa (don't have URL). It took me a few tries but it worked like a charm.
Sep 24, 2009 | 1997 Lexus ES 300
The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire GLGF386DQ Gas Kitchen Range Logo
59 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
