Question about Toshiba Satellite A50 Keyboard
When I turn my Toshiba Satellite A50 on and Windows tries to boot I get the following: Windows could not start because the following file is missing or corrupt: WindowsSystem32ConfigSystem It then says: You can attempt to repair this file bystarting Windows Setup using the original Setup CD-ROM. Select 'r' at the first screen to start repair. I have put in the CD PROGRAMS AND DRIVERS for Windows 98se/ME/2000/XP and nothing happens. Anything you can suggest?
    President:
  • 1,187 Answers
You need the Toshiba CD that says "Operating System"...
If the CD doesn't boot, then boot to the BIOS setup screen and change the boot order.
CD should be listed first.
Re-boot.
Posted on Sep 25, 2009
Can't get Toshiba Satellite L775 to boot past "windows is loading files" screen
I assume you are doing a System Restore/Recovery? Have you removed the HDD and tested it? Perhaps the Recovery files are corrupt/missing? A bit more info needed.
Jul 03, 2013 | Toshiba Satellite L655-S5160 Laptop PC...
My Toshiba A50 won't start. Just gives a choice between running windows normally and repairing (recommended) on the ground that it either didn't turn off correctly due to power cut or has some
Try going into safemode
After you see the Toshiba logo disappear. Press and hold the F8 button.
You should get a choice. Choose Safemode. If it loads try doing a system restore.
Unfortunately, if it does not load, then your Windows OS is too corrupted and needs to be re-installed. You will need the original disc that came with your laptop to do this.
Oct 26, 2012 | Toshiba Computers>Laptops Satellite A5 PC...
Im on my pc and im wondering where i can find a free download that can help me i get this message on my toshiba satellite a85s107... File missing or corrupt: \windows\system32\config\system\
Assuming you already tried pressing F8 on boot up and trying to get it into safe mode to run a disc check and that did not work?
This is a configuration file that can only be repaired by the use of OS installation CD, which if the laptop is booted with the disc in the drive and the bios is sett o boot from the DVD drive first, will give you the option to carry out a repair of the installation
Jun 21, 2012 | Toshiba Satellite A85-S107 PC Notebook
I can't connect to internet after i format may toshiba satelite a50 psa50L-07mOO2 how can i find land driver of my toshiba satelite a50?
Pls follow the below link to install the LAN driver...
http://drp.su/drivers/notebooks/?v=Toshiba&m=Satellite%20A50&id=41541&l=en
OR
http://driver-toshiba.blogspot.com/2010/02/toshiba-satellite-a50-drivers.html
thank you
Aug 03, 2011 | Computers & Internet
Juatin: toshiba satellite L305 has some problem
It seems this is a windows problem. Try reinstalling windows, or repair it within the boot cd
Jul 29, 2009 | Toshiba Satellite L305-S5907 Laptop
Windows wont boot up when I turn on my Toshiba
You need an antivirus program to be installed after installing your operating system. Do it in safe mode. If problem persists let me know.
Jul 10, 2009 | UltraLast FOR TOSHIBA SATELLITE A50/55...
For Windows won't start problem, I have met the same situation before. It was Windows Boot Genius to fix problem easily!
Jul 03, 2009 | Toshiba Satellite L25-S121 Notebook
When the system boots hit the BIOS key F2 and in the setup select boot from CDROM and press F10 and exit, Insert the bootable CD and boot the system
Jan 06, 2009 | Toshiba Sattelite A105-S2071 Notebook
Trying to start from scratch
Hi Use the following steps to open a command prompt environment and also make sure tht the OS disk is in the drive:
  1. Turn on the PC and press the F8 key repeatedly when the first screen appears. The Windows advanced options menu appears.
  2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
  3. Select Microsoft Windows Recovery Console .
  4. When the login prompt appears, press the number next to the windows version (minint or Windows) and type the logon password. Try pressing Enter if you do not know the password.
  5. At the command prompt, type the following: diskpart
  6. Press Enter , do one the following:
    • If a table of volume names appears, remember the drive letter next to the main drive volume name and press the Esc key.
    • If a diskpart prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name , type exit when done, and then press Enter
  7. Use the following steps to replace the boot.ini file with the backup boot.ini file:
    1. Type the following at the command prompt: X: (where X is the drive letter).
    2. At the prompt, type the following: ren boot.ini boot.in2
    3. Press Enter
    4. At the prompt, type the following: ren boot.bak boot.ini
    5. Press Enter
    6. At the prompt, type the following: exit
    7. Press Enter The system automatically restarts. If Windows XP does not open, continue to the next Step.
    If the above steps doesnt work then you will have to reinstall OS with the disks.
Feb 13, 2008 | Toshiba Satellite A105 Notebook
Missing or corrupt windows\system32\config\system file in XP
sciberteach:
Go in the BIOS, in the boot sequence make your DVD player as the 1st number device to boot from, restart your machine and do follow the article (you should know the admin password to go into the system drive):
http://support.microsoft.com/kb/307545
Note: If you are too overwhelmed then your Product recovery DVD will give you your original OS and all settings back.
Dec 10, 2007 | Toshiba Satellite M40-S417TD Notebook
Toshiba Satellite A50 Keyboard  Logo
175 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
