Question about Dometic Refrigerators
We purchased a used 2004 Aliner with the Dometic refrigerator. The Dometic refrigerator is a 3-way refrigerator. The refrigerator was never used. Today we turned the refrigerator on set the control (A) to electric, set control (B) to 4 as instructed to do. Nothing happened. (Could not hear anything running at all.) My husband took the outside panel off; unpluged the refrigerator from the receptical; inserted a circuit tester into the outlet and it showed it was getting power and it was wired correctly. Pluged the refrigerator back in and still nothing happened. What do you think could be wrong and what do we need to do next? Your help will be greatly appreciated. Thank you. Margaret
    Top Expert:
  • Dometic Master
  • 7,897 Answers
Bad control board or low voltage 12 volts runs board
Posted on Aug 30, 2017
the dr
  • 447 Answers
SOURCE: Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Posted on Dec 02, 2007
  • 42 Answers
SOURCE: No Cols - Temperature Controls do not respond - LED display shows a dash "-"
pencj,
My honest answer is that I have seen this before and in most cases the board works properly after the reboot.
Although you may not have lost power, you may have gotten a voltage spike. I would cancel the service man coming out, (I am a working service man myself) he probably will give you two options. #1 Wait to see if this happens again and if it does happen again soon, the board should be replaced. #2 replace the board now.
My suggestion is to soon go purchase a surge suppressor to plug into. This does not need to be a power strip style. A good quality suppressor that only has one or 2 plug in's or plugs directly into the wall receptacle should do fine. Your refrigerators maximum amp draw is listed on the model # sticker inside the refrigerator compartment.
I hope this helps, supertechks
Posted on Jan 26, 2008
pankaj_dic
  • 1250 Answers
SOURCE: Dell dimension 3100
remove RAM from the slot then put it again, then start and check
Posted on Nov 02, 2008
SOURCE: LFX 25950TT problem
Just had this same problem. We were away at Disney for four days - turned the icemaker off before we left. We have the LG french door double drawer freezer model. Came home, the ER IF code was displayed. Wouldn't dispense water or ice. Took the icebox out, and it was all frozen in the augers. Then I read on the door something to this effect - "if you turn off the icemaker, it will not continue to cool the ice. This will cause the ice to melt and leak out of the unit, and when it refreezes, the dispenser will not produce ice or water."
So, I took the ice box out, emptied it, reinstalled it, and the unit os making ice and dispensing water as I write.
Again, if you turn off the icemake, empty the ice box, or you will get the error message when you start the ice maker again.
Posted on Dec 25, 2008
frcs68
  • 1605 Answers
SOURCE: Understanding Outlet Circuit Test Results
open ground=ground wire (green) is not connected to the circuit box ground or to the earth ground.
(there should have steel rod place in the ground by the local electric company, and gtound wire is connected to that rod).
Open Neutral= same as open ground. unless you are testing 240V, which have 2 hot (110v) and a neutral (0V).
Open Hot= open 110v line (black)
hot/ground reversed= if you understand the above, then this sould be self explaintory.
same a hot/neu. reverse.
if you don't understand how electric wiring works, My suggestion is to stay out.
Posted on Dec 30, 2008
We purchased a 2013 camper with a dometic refrigerator and today the temperature is up to 48 degrees
move temp sensor in fridge lower or let hang if ok tomorrow replace if not bad sensor
Sep 22, 2012 | Dometic Refrigerators
Frigerator door seal is split,require new one. Were can I purchase one.
http://www.gas-refrigerators.com/pdf/RM2652-parts.pdf is a parts list for your unit. Parts can be purchased directly from Dometic by calling the phone number on the title page.
Aug 06, 2011 | Dometic RM2652 Refrigerator
Our dometic RM 2350caravan fridge smells like amonia when switched on to ac or dc power. It wont get cold. Help please.andrea
Hi, you have a freon leak in your system, with the caravan refrigerators they use amonia as a cooling media. You need to either have a service person the knows this system or purchase a new one. thanks.
May 18, 2011 | Dometic Refrigerators
Our dometic rm2501 is not getting cold at all/was working fine & just quit
if this is a gas absorption refrigerator make sure it's level while operating.
check for heat at the roof vent if no heat check heating element or, gas burner behind the refrigerator accessible through the refrigerator outside hatch; next: check the relay and, inverter it is located under the refrigerator front if all these things check ok and, especially if you find a yellow power on the gas refrigeration unit the tanks behind the refrigerator box; you must replace the gas refrigeration unit by: removing the refrigerator from the cabinet from the front then lay it down and remove the gas refrigeration unit replace it with a new one but, don't forget to remove the 3' long spiral metal strip from the old gas refrigeration unit exhaust vent and, reinstall it in the new gas refrigeration unit the gas refrigeration units can be purchased online.
Jul 17, 2010 | Dometic Refrigerators
Dometic Refrigerator Model RM 2820 Stopped working purchased 5-4-2004 . Tom Collins
Hi Tom,
If your fridge quit working altogether, check your DC fuses in the fuse box, as well as the back of the fridge under the black plastic cover (3 amp). Though the fridge uses LP and 120vac to cool, it is controlled by 12 volts.
Apr 30, 2010 | Dometic RM2620 Refrigerator
Freezer working on gas but not fridge compartment.
Check to see if you have the right gas pressure at the refer
Jan 26, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
94 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
