Question about Packard Bell iMedia SL 9553 (P660401806) PC Desktop
Continuous beeping sound
my computer emits a continuous beeping sound once I turn it on. The handbook states that this is due to mouse/keyboard detection failure or a stuck button on the mouse/keyboard. I have checked the mouse/keyboard connections and ensured that there are no stuck buttons but my computer still emits a continuous beeping noise.
Any suggestions would be much appreciated...
    Problem Solver:
  • 14 Answers
You can see out put in screen if no you must chek ram's
else you should remove your keyboard and mouse in test ather
Posted on Dec 16, 2007
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Dell xps 9100 constant beeps upon startup
    Beep Codes
    Your computer might emit a series of beeps
    during start-up if the monitor cannot display
    errors or problems. The following repetitive
    beep codes help you troubleshoot problems
    with your computer.
    NOTE: To replace parts, see the Service
    Manual on the Dell Support website at
    support.dell.com.
    One beep - BIOS ROM checksum failure;
    possible motherboard failure
    Contact Dell (see "Contacting Dell" on page 53).
    Two beeps - No RAM detected
    Remove the memory modules, reinstall
    one module and restart the computer. If
    the computer starts normally, reinstall anadditional module. Continue until you have
    identified a faulty module or reinstalled all
    modules without an error.
    If available, install memory modules of the
    same type in your computer.
    Three beeps - Possible motherboard failure
    Contact Dell (see "Contacting Dell' on page 53).
    Four beeps - RAM read/write failure
    Ensure that no special memory module/
    memory connector placement requirements
    exist (see the Service Manual on the Dell
    Support website at support.dell.com).
    Verify that the memory modules that you are
    installing are compatible with your computer.
    Five beeps - Real Time Clock failure
    Replace the battery.
    Six beeps - Video BIOS test failure
    May 22, 2014 | Dell Studio Xps 9100 Desktop Computer
    My desktop sounds like its on but the monitor, keyboard & mouse don't seem to also when I press the power on button after a little while it beeps about 4 times.
    DELL BEEP CODES
    Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
    Feb 02, 2013 | Dell Alienware Area-51 Gaming Desktop...
    Optiplex 330, fails to POST and locks
    When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer.
    Aug 28, 2012 | Dell Optiplex 330 Desktop Computer Pentium...
    Inspiron 531s will not boot up, keeps beeping, saying it is in power save mode. How do I fix the problem
    System Beep Codes The Inspiron™ 531 / 531s system can emit a series of beeps during start-up if the display cannot show errors or problems. These series of beeps, called beep codes, identify various problems. One possible beep code consists of repetitive three short beeps. This beep code indicates the computer encountered a possible system board failure.
    The series of beeps has a 3-second delay before it repeats. The series and delays continually loop until you press the power button.
    Code Description Suggested Remedy 1 BIOS ROM checksum in progress or failure System board failure; covers BIOS corruption or ROM error 2 No memory modules detected
    1. If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
    2. If available, install a good memory module of the same type into the computer.
    3. If the problem persists, contact Dell.
    3 Chipset error (North and Southbridge chipset, DMA/IMR/Timer Error for Intel® platform); chipset error System board failure. Power LED is blinking amber. Time-Of-Day Clock test failure Gate A20 failure Super I/O chip failure Keyboard controller test failure 4 RAM read/write failure
    1. Ensure no special memory module/memory connector placement requirements exist.
    2. Verify the memory modules you are installing are compatible with the computer.
    5 Real time clock failure. Possible battery failure or system board failure.
    1. Replace the battery.
    2. If the problem persists, contact Dell.
    6 Video BIOS test failure Video card failure 7 CPU cache test failure Processor failure
    Oct 06, 2010 | Dell Inspiron 531s Desktop Computer
    My Computer Beeping when star-up. The Beeping sound is continue such as Beep...Bee...Beep...Beep..until I force it by pressing the start up button to stop it total. I think due to the new mouse and...
    Beeps always indicate error excluding a one single beep only which indicate process.Every manufacturer has its own beep setting. it comprises on short and long beeps. If previously it working good, then your idea may be correct. replace both the keyboard and mouse with existing. start computer if now it not giving beeps it meant that one of them is causing problem. connect one by one and start computer you will reach. AND if even after replacing keyboard and mouse it gave beeps then shut down your system. Open casing remove processor and memory chip out and connect them again it will work now INSHALLAH.
    Sep 24, 2010 | Computers & Internet
    I have a E-Machine desktop that will be 3 yrs old this November, ( black Friday). It's operating system is windows X.P. When I turn on the tower the yellow lite stays solid on, and the tower emits...
    ok cammy there are several ways to solve this puzzle of yours.... first off here is a link that will explain the multiple beeps from your computer as follows!
    http://www.d-a-l.com/help/general-hardware-issues/12347-beep-code-list.html
    and being that your computer beeps 6 times could possibly mean that
    6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
    Generally, six beeps means a keyboard controller error. Unplug and replug
    your keyboard when computer is off. If that doesn't work, you may have a bad
    controller on the motherboard .
    Aug 08, 2010 | E-Machines Computers & Internet
    Computer when turned on will not boot and makes a long beep continuously and then makes like a siren sound
    The long beeps probably mean a problem with RAM. So try replacing it. Check whether the CPU Cooler (the fan on top of the processor) is working. If the fan is not working, the processor gets hot, and a siren sound is emitted. Also check whether power unit fan (at the back) is working. If RAMs are replaced and you still get the beeps, the problem may be with the VGA. (The beep sounds help to identify the problem, but the sounds differ with different BIOS models).
    Jul 30, 2009 | Computers & Internet
    Long beep continously
    One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU OverheatingOR Continuous beep Power supply, system board, or keyboard problem
    Jul 13, 2009 | Soltek SL-75FRN2-L Motherboard
    Computer beeps when first turning on
    If your computer is still under warranty, the company should replace them. If not, you can buy them really cheap.
    Or you could just return the computer. This is what I would do, because it might not be the mouse/keyboard that is causing this. It could be that you just have a bad motherboard.
    May 20, 2008 | Compaq Presario 5000 PC Desktop
    Packard Bell iMedia SL 9553 (P660401806) PC Desktop Logo
    1,237 people viewed this question
    Top Packard Bell Computers & Internet Experts
    Alun Cox
    carey w mason
    carey w mason
    Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
