Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Maytag MZD2665HEW Fridge not cool enough
I have a Maytag MZD2665HEW wide by side refrigerator; about a month ago the fresh food side stopped cooling, so I replaced the adaptive defrost control board. Everything was fine for a couple of weeks, but now the fresh food side is not cooling enough. What do you suggest I replace next? Thanks!!
fridgetech
  • 473 Answers
SOURCE: Maytag MSD2356 Freezer frosts up quickly, fridge warm
If you jumped the defrost board and it went into defrost then that board is bad. I assume by "freezes up" you are talking about the evaporator is frosting up? That defrost board puts it into defrost automatically. If you have to jump it to get it go into defrost then the board is not doing its job.
Posted on Nov 16, 2007
SOURCE: 5 year old Maytag Wide by Side Refrigerator side not cooling
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
TR
Posted on Mar 18, 2008
swami nathan
  • 208 Answers
SOURCE: After many repairs to my maytag mzd2766ges, my fridge side cools for a while and then it stops until a new repairs
If either door is open, the airflow will be wrong. Do you see a lot of "snow" or frost building up at the bottom of the freezer rear wall?
Do you hear a fan running in the freezer compartment?
Where are your controls set?
Is the fan back by the compressor running?
Have you checked the air duct at the bottom behind the lower crisper drawers?
The main reason for this type of problem is that the (evaporator) coils below the fan would be iced up.
So, i need you to do this,
1.unscrew the back panels on the freezer side and note whether the evaporator coils were all iced up.
2. If it is iced up, then defrost the coils and then replace the defrost board in the refrigerator.
Regrigerator will be back to normal . Defrost board is located on top of refrigertor side underneath the temp control unit.
Easy repair once you remove the temp control cover. Unscrew the defrost board and plug new connection in.
Post your comments about how things turned up.
Thanx for using fixya,
Cheers.
you can also mail your comments: mailmeswami@yahoo.co.in
Posted on Sep 27, 2008
jmgldsmth
  • 2005 Answers
SOURCE: refrigerator freezes fresh food section and always runs
Please read it appears that there are two defrost timers for your refrigerator one for the freezer one for the refrigerator
http://www.partselect.com/PartDetail.aspx?Inventory=310858&SourceCode=4#RepairStory
Posted on May 04, 2009
  • 4 Answers
SOURCE: fridge is not cooling
You probably need an adaptive defrost control which is located in the back right hand corner of your fresh food compartment. You have to dismantle the overhead controls to get to it. If you had to defrost your coils, and the heaters test good, then you probably need the above control.
Posted on Jun 09, 2009
FRESH FOOD SECTION OF SIDE BY SIDE FRIDGE NOT COOLING ENOUGH. TEMP SET @ 9. FREEZER SECTION WORKING FINE
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 20, 2010 | Hotpoint HSS25GFP Side by Side...
Lights on, fan on freezer and refrigerator not- maytag mzd2665hew
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 11, 2010 | Maytag MSD2655HE Side by Side Refrigerator
Refrig side not cooling....freezer side operating fine
Check that the damper vent that sends cold air from the freezer into the fresh food side is not blocked by contents. Check that the damper is opening to allow cool air to transfer. Put the fridge into diagnostic mode to check the thermistors.
Jun 25, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refregirator fresh food compartment not cooling off
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sjf
Sep 20, 2009 | Maytag MZD2766GES Side by Side...
Coils keep freezing up its 4 years old
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bough a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 30, 2009 | GE GSS20IEP Side by Side Refrigerator
The fridge and freezer stopped cooling. we defrosted it. There was frost in the freezer. Before that the ice on the door had stopped and now it works too.
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me,the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signaled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week).Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
I bought a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Top refrigerator not cooling--freezer icy
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
Jul 28, 2009 | Refrigerators
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Fridge is not cooling
Apr 06, 2009 | Maytag MSD2454G Side by Side Refrigerator
Maytag Fridge (Model # MZD2766GEW) not cooling
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
245 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
