Question about Sony KP-65WV700 65" Rear Projection HDTV
Image problems the picture shows dobule lines and red/green hue. What might be the problem and projected repair cost?
    President:
  • 4,402 Answers
Have you tried doing convergence?
Posted on Jan 23, 2008
PANASONICV that now has a "blurred" screen. We can see the channels but it looks like it's has a shadow around the images. The screen in in a red hue with green blur. TX-51P100H 51"...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 29, 2011 | JVC AV-56WP74 56" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Toshiba 50HX81 TV looks kind of old school 3D with red and green hue. Bad bulb? How involved is this to fix and where do I find parts?
No,not the bulb problems.Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The Toshiba tv have a "HYPER BOARD"known as a convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board,must be replaced to solved the tv convergence pictures problems.U have tools like a soldering iron,desoldering pump or desoldering braids,solders?Can u do basic soldering?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop,will cost u $300-350 for parts and labors.
Oct 21, 2010 | Toshiba 50HX81 50" Rear Projection...
I have a rca 52 wh74 tv and it showing double images with red, green and blue lines at the top of the screen. how can this be repaired?
Replace the FL231, DL231 and CL230 total cost about 12.00 at the following link which includes the parts with free instructions with pictures. They are listed under the RCA Parts category.
http://servicemanuals.vstore.ca/
Jun 13, 2009 | RCA R52WH73 Projection Television
Line red,yellow,green are all over picture and images
No you will need to replace the Convergence Ics and possibly some of the 12 feed resistors. You can get the repair kit for your model at the following link which contains both cinvergence ICs and all 12 resistors plus free instructions with pictures so you can do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
May 25, 2009 | Philips 60PP9202 60" Rear Projection...
Wavy coloured lines on the screen all the time & hue
Tv repairman. the green picture tube has an intermittent short in it. This is an expensive fix.
Mar 30, 2009 | Sony KP-51WS500 51" Rear Projection...
Toshiba 43vj13p
if the people in the pic has red out lines or looks like theres two of them then sounds like convergence problems which you will need to replace the convergence chips which cost around £150 +vat. hope this helps
Feb 10, 2008 | Philips 50P8341 50" Rear Projection...
I have 47 inch with double color in picture, reds and green
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergence amp ic bad
Oct 14, 2007 | Samsung HCL552W 55" Rear Projection...
Problem with color
Yes you have a problem in the red crt driver board. Most likely the driver transistor is failing. This is a component level repair, so if you have no experience with TV repair, play it safe and call in a trained tech to assist you in this matter. Good Luck
Jun 05, 2007 | Mitsubishi VS-50609 50" Rear Projection...
Sony KP-65WV700 65" Rear Projection HDTV Logo
62 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
