Question about HP LaserJet 4350 Printer
Whenever i change paper size from A4 to letter,
Whenever i change paper size A4 to letter from my PC, it goes back to A4 as default in printer settings.
    President:
  • 1,187 Answers
Don't set by using the "Print" option.
Go to [Start]
[Printers and Faxes]
right-click on the HP printer entry
! Don't select "Printing Preferences"! from there
Select [properties]
Select [Advanced] tab
Select [Printing Defaults]
[Advanced}
(I know, the screen looks the same, but it functions differently this way)
Change paper size to "Letter"
[OK, OK, OK]
*done*
Posted on Sep 25, 2009
Code PC Load A4
This means that the printer is expecting A4 paper rather than letter size or whatever you are trying to use. Check your "Printer Options" on your computer and make sure that the appropriate paper size is selected. A4 is an international standard paper size that is 210 mm (8.27 inches) x 297 mm (11.7 inches) and therefore is just a bit narrower and longer than the American "letter" paper size.
To correct this, cancel the print job currently in the printer's memory, change the computer to the proper paper size, and send the print job again.
Jan 26, 2014 | HP LaserJet 4 plus Printer
Paper size
check default setting with bypass try
usually it is letter size change into the a4
Apr 21, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How do I change the default paper size from Letter to A4 in my HP Officejet Pro 8500 Wireless?
Go to [Start]
right-click on the HP Printer entry
Select [properties]
[Advanced}
[OK, OK, OK]
*done*
Sep 25, 2009 | Office Equipment & Supplies
Pc load letter
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
May 28, 2009 | HP LaserJet 4 plus Printer
HP Laserjet 3050, need to press ok each time printing
did it work before? check paper size for trays - suspect it is set for a4, change to letter size
Mar 12, 2009 | HP LaserJet 3050 All-In-One Printer
HP6110 default paper size for copying
Yes, manually set your paper size using A4 or begin with A4 and leave it on auto (default) it will try and match it.
Instructions...
  • Press Menu
  • Option 1
  • Option 2
  • Select copy Setup
  • Select paper size
  • Hit the black triangle until the size you want displays
  • Then hit enter.
Dec 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
When I print my letter, I set my defaults on my computer with Letter size. But pn the printer, I can't figure out how to change the cassette from A4 to letter. It's driving me crazy. Please help me default...
Go through the following
Start=Settings=printers and faxes=right click on the isatalled printer=printing preferences=change paper size from A4 to Letter. This will now remain as default.
Regards,
Manoj Joseph
+91 9352008418
Jun 18, 2008 | Canon Office Equipment & Supplies
Changing Paper Size
If the blue guide in the back of the tray (called the length plate adjuster) is broken or dislodged, the machine may not recognize what size paper is installed. When the guide is moved, three arms on the right side of the paper tray change configuration. Those arms push against sensors in the machine to tell the printer what size paper is in the tray. You can temporarily resolve this by taping the guide in the A4 position, however you should consider replacing the tray or replacing the guide soon to avoid tape getting into the printer.
Hope this helps!
Mar 20, 2008 | HP LaserJet 4050 Printer
Canon MF3240 printer error message.........
I think I solved my printer problem: Chang the paper size to LTR in the printer panel. then go to compter printer setup and choose printing preferences and choose page setup and chang the paper size to Letter (LTR) also. hope this is helpful.
Nov 13, 2007 | Office Equipment & Supplies
HP LaserJet 4350 Printer Logo
504 people viewed this question
Seeker5211
Seeker5211
