Question about Philips Televison & Video
My dvdr has 985 an error code ab f09977 then turn's off
2 Suggested Answers
Check engine light is on and diagnatics show the error codes, P0722 and U2108
Definition of Diagnostic Trouble Code U2108 Buick: CAN Bus Error ABS Cadillac: CAN Bus Error ABS Chevrolet: CAN Bus Error ABS GMC: CAN Bus Error ABS Oldsmobile: CAN Bus Error ABS Pontiac: CAN Bus Error ABS Saturn: CAN Bus Error ABS
Definition of Diagnostic Trouble Code P0722 Category: Powertrain Definition: Output Speed Sensor Circuit No SignalNote: This definition of P0722 is applied to all manufacturers
Jun 27, 2015 | Cars & Trucks
HOW DO I TURN OFF MY ABS LIGHT
your abs light is on because the abs module has detected an error in its system. Found out what codes are in the abs module. This will help narrow down the many possibilities. Once you get the codes, figure out what is wrong, and make a repair you can then clear the codes which will turn off the light.
Posting a year, make, model, and engine size will help make things more specific for you problem!
Feb 10, 2012 | Cars & Trucks
Hi, bought dvd ntsc format from US but can't play at our player. Are you able to assist ? Player type - Philips HTS3011/98
your dvd has regional code..only play dvd from where your purchase it.
you can do some hack.
try this
To convert this player for multi-region playback
This hack should work on all Philips DVD players with any firmware version, and other similar models by manufacturers such as Grundig, Marantz and Yamaha
Please note that if you experience problems with this hack you can obtain firmware version 7.03 and later by visiting the PhilipsSyndicate to obtain files that you can burn to a CD-R and flash your unit to the new version.
1a.
The following uses the machines own remote control:
We have heard reports that hacking some players using the units own remote control incurs a 25 change limit after which it will lock the machine in the last set region
We have heard other reports that hacking some players such as the DVDR-880 using the units own remote control can result in an inoperable unit, we recommend you use the OneForAll remote only and consult our Region Hacks forum for more information
  • Press the Play button on the player
    NB: You may need to press this button on the remote control instead
  • Press the 1 button on the remote control
  • Press the 5 button on the remote control
  • Press the 9 button on the remote control
Although the above may appear to work on many units, showing the correct display as indicated in Step 2, the hack may still not work. In which case you WILL need to use Step 1b instead! 1b.
If the above does not work, you will have to send the infra-red code RC6 (aka Codeset 4, Key 235 in nerd-speak) to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital with the following instructions:
  • Configure your remote using the setup code 0 5 3 9
  • Press the Magic button
  • Enter the code 0 8 5, or if your unit requires a five digit code, enter 0 0 0 8 5
If you own a Palm Pilot, you may also use Pacific Neo-Tek's OmniRemote software to generate the RC6 code using a downloadable .pdb file.
  • Download the .pdb file into your Palm Pilot
  • Press the OmniRemote key marked as 955 Multizone
If you do not own either of the above units, it is possible to construct a cheap DIY solution by following instructions at the following website.
NB: Sending these codes to some players, such as the Philips DVDR-980, requires you to select a DVD player remote on the unit as the default IR device, as opposed to the DVD recorder remote it is factory set to. Please consult your player documentation to find out how to do this.
2. The onscreen display should show 11 spaces like this: '-----------'
NB: The actual display may differ slightly depending on the model of your player, may be shown on the unit itself, or may even not be visible on some models at all.
3. Using the number keys on your DVD player's remote control, enter the code 222 222 005 255. Note that this is 12 digits and the last digit will not show on the on-screen display.
NB: For players such as the Philips DVDR-980, DVDR-985 and DVDR-1000 units, you may need to use the code 121 212 005 255 instead. For players such as the Philips DVDR-880 you may need to use the code 121 212 005 00x instead, where x is the desired region, however this also works on other units including the DVDR-985 for setting a specific region. 4. Press the Play button on your DVD player's remote control 5. The onscreen display should now show the words No Disc 6. Power off your DVD player, wait 10 seconds and then power back on
Aug 24, 2011 | Televison & Video
My dell laser printer 1320c has printer error code 091-935 come up what does this mean?
this error means
Replace DrumCart
091-935
Drum Full of
Waste Toner
The drum cartridge needs to be replaced. fro more information about how to remove it you can got to following link
http://support.dell.com/support/edocs/systems/3100cn/en/UG/section22.html#172399
Sep 09, 2009 | Dell 1320c Laser Printer
User manual for Philips dvdr985recorder
CLICK HERE
Thanks for using FixYA - a 4 THUMB rating is appreciated for answering your FREE question.
Aug 23, 2009 | Philips Televison & Video
Trac Off and ABS Lights came on, won't go off
trac control & abs light staying on in dash on pt cruiser 2001 limited
well had same problem with my pt cruiser 2001, firstly there is no need to plug in computer under the dash for pulling abs error codes,
because the problem can be the cracked abs ring on the drive shaft/cv joint,
turn your steering all the way to left and ask your colleague to see if behind the tyre the abs ring is broken or cracked,
it is circular like a bracelete with grooves, then turn the steering to the right and repeat the inpesction,
if the abs ring is cracked then look on ebay or web for pt cruiser abs ring or kia abs ring, should cost about £5-£10 each
and a garage could heat it up with gas and hammer it into the drive shaft/cv joint for you for about £20-£30,
takes about 30min to 45mins, make sure the garage dont heat the cv booth kit rubber next to the abs ring when heating it up.
i heard you can only buy abs ring for front wheels and its not available separately for rear wheels,
so for rear you may need to buy the whole part it comes on
the front abs rings are easily visible when you turn the wheel to one side, the rear ones may not be visible as i have not seen them
so if the abs ring are good then it wil probably be one of the wheel sensors, in this case you you may look for a garage who will hook up
the computer and pull the code for you, be carefull if the say there are no abs error codes it means the sensors are ok and most of it
there is no need to buy abs sensor for any wheel when there are no error codes
on pt cruiser you can pull engine error codes yourself without a computer, just do the key dance on the ignition,
turn key until dash lights come on then switch off and then again turn key until dash lights come on then swithch off,
then turn key for third time again until dash lights come on , you will see engine error codes displayed then says done,
if there are no error codes it will say done, howevere these are engine error codes only not abs error codes,
abs error codes are pulled using abs diagnostic tool
incase its a faulty wheel sensor, will cost £45 at dealer or £20 from scrap, then a garage can removed the tyre and plug out the old sensor cable
and replace it with a new one, one end is easy to plug in but the other end has to be pushed in at an angle,
its about 30min job and garage can charge £20 or so
my pt cruiser is back on the road with just one abs ring replaced and it all cost me £30 alltogether
Apr 11, 2009 | 2002 Chrysler PT Cruiser
Code for remote control of philips DVDR 3360D Hard disk / DVD Recorder
Also need to know what is the make and model of the universal remote you are using. Codes vary from one to the next.
If by chance your remote is Philips, the code for Philips DVDR's is one of the following:
0599, 0699, 1211
I have a Philips URC US2-PH5DSS and I use the code 0599 to control my Philips 3355 DVDR.
Apr 15, 2008 | Philips DVDR 3355 DVD Recorder
Televison & Video Logo
104 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
