Question about Nokia 1680 Phone Unlocked FREE 1GB
I cannot recall the restriction code to open line my n1680.
  • sonerfalcuti Sep 25, 2009
    i cannot recall the restriction code to open line.
    Sergeant:
  • 324 Answers
Try 123456 or if you can get the IMEI # or serial number i can generate the Mastercode code. Give me the mastercode so i can generate the mastercode.
Posted on Sep 25, 2009
  • joanne ario Dec 17, 2011
    my IMEI is 356841
    code is 0566420
    please help! thanks!
Restriction code
You can get restriction code for Nokia 2700 Classic from the site Simpleunlocking.com and get free unlocking instructions from the site Mobileunlockguide.com and openline from network lock.
Aug 28, 2013 | Nokia Classic 2700 Cell Phone
Enter restriction code
You can get the restriction code for your Nokia 2600 from Onlinegsmunlock.com and by specifying the country and network to which the mobile is locked to, you can get the network lock easily removed.
May 02, 2013 | Nokia 2600 Classic Cell Phone
My c1-01 have restriction code, how to provide the code?
You can get the restriction code for a Nokia C1-01 from www.mobile-unlocker.com at affordable cost.
Jun 22, 2012 | Nokia C101 Cell Phone
I need the user guide for nokia 1680 ,pocket telephone
Welcome to Fixya.
You may refer to the website below that will take you to the N1680's user guide. You have the options to include the website in your favorites, or save it to your computer - just make sure that you have an Adobe PDF (Acrobat) reader installed :
N1680 Guide
Thanks for using Fixya.
May 12, 2011 | Cell Phones
How do I fix p0441.
A code P0441 could mean one or more of the following has happened:
* Bad vacuum switch
* Broken or damaged EVAP line or canister
* Open in PCM purge command circuit
* Open or short in Voltage feed circuit to Purge Solenoid
* Faulty purge solenoid
* Restriction in EVAP solenoid, line or canister
* Corrosion or resistance in purge connector
* Bad PCM
Possible Solutions: With a P0441 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
* Common Chrysler fix - Replace Leak Detection Pump / LDP
* Repair damaged EVAP lines or canister
* Repair open or short in voltage feed circuit to Purge Solenoid
* Repair open in PCM purge command circuit
* Replace purge Solenoid
* Replace vacuum switch
* Repair restriction in Evap line or canister or soleniod
* Repair resistance in purge connector
* Replace PCM
Hope helps (remember to rate this answer).
Oct 22, 2010 | 2004 Dodge Stratus
What are the carrier 8000ts led error codes?
They are listed inside the front panel of the main unit.
LED CODE
EACH OF THE FOLLOWING STATUS CODES IS A TWO DIGIT NUMBER WITH THE FIRST
DIGIT DETERMINED BY THE NUMBER OF SHORT FLASHES AND THE SECOND DIGIT BY
THE NUMBER OF LONG FLASHES.
STATUS
11 NO PREVIOUS CODE - Stored status code is erased automatically after 72
hours. On RED LED boards stored status codes can also be erased when power
(115 VAC or 24 VAC) to control is interrupted.
12 BLOWER ON AFTER POWER UP (115 VAC or 24 VAC) -Blower runs for 90
seconds, if unit is powered up during a call for heat (R-W closed) or R-W opens
during blower on-delay.
13 LIMIT CIRCUIT LOCKOUT - Lockout occurs if the limit or flame rollout switch is
open longer than 3 minutes.
- Control will auto reset after three hours. - Refer to #33.
14 IGNITION LOCKOUT - Control will auto-reset after three hours. Refer to #34.
21 GAS HEATING LOCKOUT - Control will NOT auto reset.
Check for: - Mis-wired gas valve -Defective control (valve relay)
22 ABNORMAL FLAME-PROVING SIGNAL - Flame is proved while gas valve is
de-energized. Inducer will run until fault is cleared. Check for:
- Leaky gas valve - Stuck-open gas valve
23 PRESSURE SWITCH DID NOT OPEN Check for:
- Obstructed pressure tubing. - Pressure switch stuck closed.
24 SECONDARY VOLTAGE FUSE IS OPEN Check for:
- Short circuit in secondary voltage (24VAC) wiring.
31 PRESSURE SWITCH DID NOT CLOSE OR REOPENED - If open longer than
five minutes, inducer shuts off for 15 minutes before retry. Check for:
- Excessive wind - Proper vent sizing - Defective inducer motor
- Low inducer voltage (115VAC) - Defective pressure switch
- Inadequate combustion air supply - Restricted vent
- Disconnected or obstructed pressure tubing
- Low inlet gas pressure (if LGPS used)
If it opens during blower on-delay period, blower will come on for the selected
blower off-delay.
33 LIMIT CIRCUIT FAULT - Indicates a limit, or flame rollout is open. Blower will
run for 4 minutes or until open switch remakes whichever is longer. If open
longer than 3 minutes, code changes to lockout #13. If open less than 3 minutes
status code #33 continues to flash until blower shuts off. Flame rollout switch
requires manual reset. Check for: - Restricted vent
- Proper vent sizing - Loose blower wheel - Excessive wind
- Dirty filter or restricted duct system.
- Defective blower motor or capacitor. - Defective switch or connections.
- Inadequate combustion air supply (Flame Roll-out Switch open).
34 IGNITION PROVING FAILURE - Control will try three more times before lockout
#14 occurs. If flame signal lost during blower on-delay period, blower will come
on for the selected blower off-delay. Check for: - Control ground continuity
- Flame sensor must not be grounded
- Oxide buildup on flame sensor (clean with fine steel wool).
- Proper flame sense microamps (.5 microamps D.C. min., 4.0 - 6.0 nominal).
- Gas valve defective or gas valve turned off - Manual valve shut-off
- Defective Hot Surface Ignitor
- Inadequate flame carryover or rough ignition
- Green/Yellow wire MUST be connected to furnace sheet metal
45 CONTROL CIRCUITRY LOCKOUT Auto-reset after one hour lockout due to;
- Gas valve relay stuck open - Flame sense circuit failure
- Software check error
Reset power to clear lockout. Replace control if status code repeats.
If status code recall is needed, briefly remove then reconnect one main limit wire to display
stored status code. On RED LED boards do not remove power or blower door before initiating
status code recall. After one status code recall is completed component test will occur.
Thanks for Choosing FixYa.
Kelly
Oct 05, 2010 | Heating & Cooling
PO441 check engine light on v6 99 camry with 99,000 miles . I have done hours of research, what is most likely culprit?
There's no most likely culprit... this code may mean that one of more of the following has occurred:
  • Bad vacuum switch
  • Broken or damaged EVAP line or canister
  • Open in PCM purge command circuit
  • Open or short in Voltage feed circuit to Purge Solenoid
  • Faulty purge solenoid
  • Restriction in EVAP solenoid, line or canister
  • Corrosion or resistance in purge connector
  • Bad PCM
However, this code is tricky to diagnose. Here are some solutions you can try:
  • Replace Leak Detection Pump / LDP
  • Repair damaged EVAP lines or canister
  • Repair open or short in voltage feed circuit to Purge Solenoid
  • Repair open in PCM purge command circuit
  • Replace purge Solenoid
  • Replace vacuum switch
  • Repair restriction in Evap line or canister or soleniod
  • Repair resistance in purge connector
  • Replace PCM
Oct 16, 2009 | 1999 Toyota Camry
Po441
  • Bad vacuum switch
  • Bad PCM
Possible Solutions With a P0441 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
  • Common Chrysler fix - Replace Leak Detection Pump / LDP
  • Replace PCM
Jun 09, 2009 | 1997 Toyota Camry
Trouble codes on a 96 buick riv
evap emission control system fault-po441, po742 is--torque converter curcuit stuck on, for this code, check torque converter clutch switch..
Apr 05, 2009 | 1996 Buick Riviera
Restriction code for nokia 6070
nokia 6070 cellular Phone. IMI NO 351881/01/692838/205398398.MADE IN HUNGARY.PLESE SEND RESTRICTION CODE AT MY ID Nvirk94@yahoo.com.
Mar 12, 2008 | Nokia 6070 Cellular Phone
Nokia 1680 Phone Unlocked FREE 1GB Logo
74 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
