Where is the bcm located in a 2001 saturnsecurity system
2 Suggested Answers
  • 295 Answers
SOURCE: where is the BCM located on a 2001 T&C
Under the drivers side kickpanel on the firewall.
Posted on Jul 25, 2009
I hsve a 2008 saturn sky base 2.4L. The dealer says I need a new body control module. My question does the new BCM require reprogramming? If it doesn't then I will replace myself. Thanks
Body Control Module (BCM) Replacement and Reprogramming
If the BCM is replaced or requires reprogramming, the following procedures must be performed in the specified order:
BCM Setup -- Using a scan tool, go to Vehicle Control Systems » Computer/Integrating Systems » Module Setup » Body Control Module. Select Setup BCM and follow the on-screen instructions, making sure to select the proper RPOs and input the VIN correctly.
BPP Sensor Calibration--Refer to Brake Pedal Position Sensor Calibration
Program Key Fobs--Refer to Transmitter Programming
Setup SDM Part Number in BCM -- Using a scan tool, go to Vehicle Control Systems » Computer/Integrating Systems » Module Setup » Body Control Module. Select Setup SDM Part Number in BCM and follow the on-screen instructions.
Dec 28, 2016 | Saturn Cars & Trucks
I have a Saturn 2001 4door s series the security light is on and won't start what can I do
Passlock
The passlock system is a vehicle theft deterrent system which deters drive-away vehicle theft by disabling engine operation if the ignition lock cylinder is not rotated with the proper mechanically cut key.
The passlock system is made up of an ignition switch assembly, passlock sensor, body control module (BCM), instrument panel cluster (IPC), and a powertrain control module (PCM).
The ignition switch contains a magnet mounted on the lock cylinder and a passlock sensor assembly which consists of security hall effect sensor, tamper hall effect sensor, and output resistors. A drill proof metal shield is also staked over the sensor housing.
The passlock sensor mounted to the ignition switch assembly is located inside the upper right side of the steering column. The passlock sensor contains two hall effect sensors: a tamper hall effect sensor and a security hall effect sensor. The tamper hall effect sensor is mounted on top of the security hall effect sensor. Should someone attempt to defeat the system by use of magnetic experimentation, the tamper hall effect sensor will activate first.
The BCM has the passlock controller integrated into it which controls the majority of the security systems logic. The BCM reads the data from the passlock sensor continuously. If the data is correct and has been received by the BCM within a specified time, the BCM will send a coded password to the PCM. The PCM will then allow the fuel injectors to operate.
The coded password for the security system is sent from the body control module to the PCM via the class 2 data link. If the password is correct and received within the specified time, the PCM will allow the fuel injectors to operate.
The IPC contains the security telltale. The security telltale has three modes of operation, OFF, FLASHING, and ON.
SECURITY TELLTALE will be off if:
Ignition is in the OFF position
Ignition is in the RUN, START, or ACC position and security system diagnostics have all PASSED
SECURITY TELLTALE will be on if:
The BCM is performing a bulb check at vehicle start
Security system diagnostics have not yet completed at vehicle start
A security system diagnostic trouble code (DTC) is set in the BCM or PCM
SECURITY TELLTALE will be flashing if:
The tamper hall effect sensor has been triggered
Incorrect passlock sensor data to BCM for more than 5 seconds during vehicle start
No passlock sensor data to the BCM for more than 5 seconds during vehicle start
Incorrect password from the BCM to the PCM after 5 seconds during vehicle start
Oct 23, 2015 | Saturn Cars & Trucks
2001 saturn lost keys to it. Got it to crank cut right back off secrity lights on bought a brain box for it and got 2keys with it. Still want crank I need to know what to do t could the box be bad ..
No ,the box is probably not bad , but you need to have it programmed . The dealer is the only one that can do that ? The keys don't matter .
Sorry but you can't just replace parts , you need to know how the system works . You need to take this to a ASE certified repair facility that knows how it works .
Oct 10, 2015 | Saturn Cars & Trucks
Were is the BCM of a Saturn ion 2003 transmission manual
Above the glove box. It's attached above it.
Feb 25, 2015 | 2003 Saturn ION
Where is bcm located
The BCM is located on the passengers side behind the glove box area.It would be just above the PCM.This is for all L series Saturns.Hope this helps.Good luck.
Mar 04, 2011 | 2001 Saturn L-Series
I need to replace a computer brain box for my 2001 Saturn L series Wagon. I'm thinking it is located behind the glove box on the passenger side but how do I get to it?
The ecm is buried under the passenger side windshield cowling. The bcm sits on top of the glove box. Your 4cyl engine uses a timing chain that may have suffered from lack of lubrication due to poor oiling controls. Although you're describing a symptom, ecm's rarely fail ($$$), as your description may have everything to do with the bcm and the factory security system; starting, running then stopping. Have you reviewed your owner's manual for resetting the security system?
Jumping on ecm replacement won't be as easy as you may think as there's a factory security feature that forces all the system computers to communicate with the body control module (computer) before allowing the new kid to work. There's a relearn routine that's part of replacement procedures and unless your ecm find gives you this information, you'll be in more trouble than you can imagine.
May 08, 2010 | 2001 Saturn L-Series
Saturn LW200 2001 will start &run then die.
it needs a new bcm,body control module,thats why everything is freaking out and the car is not starting,must go to dealer say $400
Sep 22, 2009 | 2000 Saturn SL
2003 Saturn Ignition and Security System Troubles
Sorry to say but it's probably the BCM (body control module) that's going in her car. The BCM controls everything inside your car, from the gauges, locks, daytime running lamps, ABS... and yes the security system. I have a 2003 L200 which had the same problem and I had to replace the BCM at some cost ($400-$600) depending on where you go. The L-Series Saturns seem to have a problem with their BCMs and it seems that it's pretty prevalent. Unfortunately it will only get worse as time goes on and it's not something that you can do yourself as it needs to be programmed by the dealer. You also will need to get your remotes reprogrammed as well with the new BCM. Hope this helps.
Nov 24, 2008 | 2003 Saturn L-Series
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
