Question about GE Refrigerators
I have freezor on the bottom working fine. Fridge on tp is not cooling
    President:
  • 744 Answers
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using fixya! Mike
Posted on Sep 25, 2009
Freezor frosts up in side a lot snow flaky and ice build up
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Refrigerators
The freezor is cold but the refrigerator part is not cold.
heatman101
Apr 30, 2011 | Whirlpool Refrigerators
Water running from underneath the freezor onto the floor. Water pooling in the bottom of the freezor.
heatman101
Mar 30, 2011 | Amana ABB1927DE Bottom Freezer...
The water dispenser keeps freezing. The Ice Maker is fine. This is happening everyday.; We thaw it out and then is does it again. Fridge is set at 37 and freezer is a 5
if this is a side by side frige the water tube that runs inside freezor door pulls away from insulation causing it to have no insulation between the freezor and the tube alot of then you can thaw one time and there fine. disconnecting the water line at bottom of frige behind toe kickin front and usually is a push in an d release tab connectors or plastic threaded nuts blowing air through can use air compressor not at full blast works great and then once you have it flowing run gallions if possible though to make sure no water deposits no debrie to slow water down to give more chance to freeze oh and if it hasa filter make sure its update and replaced this will help also if still problem persists may need new door they foam insullat these things at the factory cant just move it or put more insulation inside door , door are spending too
Mar 03, 2011 | Kenmore Refrigerators
Freezor works but refrigerator doesn't stay cool
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 25, 2010 | Kenmore 74262 / 74264 / 74269 Top Freezer...
Not cooling at all
Either the compressor has seized or refrigerant gas has all leaked away are the two most likely and expensive reasons!
Mar 21, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My freezor work good but the fridge does not cool
There is ice blocking the passage which allows cold air from the freezer to pass into the refrigerator compartment. Turn the refrigerator off. Find where the cold air passes into the refrigerator and remove/melt the ice. You may need to remove some panels to access this passage.
Oct 02, 2009 | LG LSC26905TT Side by Side Refrigerator
Refrigerator hot and freezor cold
heatman101
Apr 14, 2009 | Frigidaire FRT17G4B Top Freezer...
Freezor barely freezing, fridge barely cooling
After the electricity came on what setting did you use? I would start out at 4 or 5.When a unit sits too long without running the coolant will settle to the bottom it can be hard on it because it is trying to push it threw the system.After it defrosts all the lines should be clear. From there it could be as simple as the fan in the freezer is slowing down or your compressor is on its way out. Also check the vent from the freezer to the fridge for blockage.
Len
Feb 19, 2009 | Kenmore Refrigerators
Refrigerator
You need a qualified technician for the leak repair and recharging of refrigerant. All of the refrigerant in the system are gone, next time do not use sharp object when cleaning your fridge.
Jan 11, 2008 | Refrigerators
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
