Question about Maytag Ovens
The oven of maytag range mgr5775qdw poorly
The oven of maytag range mgr5775qdw only lights with a large gas build up and explosive action
  • 334 Answers
The ignitors/burners need to be cleaned properly.
Build up of grease, dirt, rust, mineral deposits, etc can cause improper gas flow resulting in a delayed ignition. That causes a build up of gas and the delayed ignition ignites it all at once, and you have your WHOOMP mini explosion.
Posted on Sep 25, 2009
A tenant of ours is saying that their Maytag 27" single oven of: Every time we turn on the oven, there's a very strong gas smell for at least the first few minutes. The oven is heating ok.
you should probably go over or send someone ASAP to pull it out and check the lines are connected properly and haven't become damaged.
Could you imagine the lawsuit and property damage if their was a gas leak. This is the very reason gas has an odor added, it is the only warning sign of a potential leak and explosion.
I would take this very serious and give immediate attention.
Nov 15, 2016 | Maytag Ovens
Maytag Oven will not heat up
sounds like the gas valve may not be opening up
Mar 29, 2008 | Ovens
I have a Whirlpool Stove, model SF367PEYQ3. When we turn the oven to 'BAKE', it takes 1-2 minutes to light. When it does light, it lights with a small explosion and we can smell gas. I took up...
We're sorry to hear about your Range. Can you please email your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com so we may look into this?
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
I have a maytag model # mgr5775qdw and the oven will not ignite. I know it is not the gas line as the burners all light, and the broiler lights as well. It is only the oven that does not heat. . .what...
This could be two possible problems. The igniter maybe bad, but doubt it. The igniter works both the oven and broiler, I believe on this model. The first thing I suspect is the switch in your wiring harness. The harness has a switch attached to it for each manifold. The switch for your oven maybe out.
Go to this site for diagram of parts: https://www.maytag.com/digitalassets/MLPDF/Repair%20Part%20List%20-%20W10282172.pdf
Jun 18, 2011 | Maytag Ovens
Maytag gas oven has an F1 code. Model # CGR3740ADW.
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Feb 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
I just bought a Maytag build in oven cwg3100aaae29. It dose not have a cover around the light bulb, what happen?
some new types of bulbs do not require a cover as they can withstand the heat,if in doubt ring your supplier.adrian,,,,
Sep 03, 2010 | Maytag CWG3100A Gas Single Oven
Gas Maytag range taking too long to preheat, sometimes there is a stong gas smell
It is likely that the lower ignitor needs to be replaced. The range switches the gas valve on and off because it is not sensing the proper amount of resistance in the ignitor.
Jul 06, 2009 | Maytag CWG3100A Gas Single Oven
Maytag gas oven slow to ignite,makes poof sound
sounds like the safety valve gas regulator (its where the main gas line attaches in the bottom back)
Mar 25, 2009 | Maytag CWG3100A Gas Single Oven
Maytag MGR5775QDW-TOP works ,broiler and oven don't
If you have lp makes sure the tanks are fill and unit is converted to lp.Same goes for natural gas
Nov 06, 2008 | Maytag CWG3100A Gas Single Oven
Burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Nov 19, 2007 | Maytag CWG3100A Gas Single Oven
Ovens Logo
382 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Mack Baxter
ashburton
Are you a Maytag Oven Expert? Answer questions, earn points and help others
