Question about Logitech Wireless DJ Music System (966194) Headphones
Logitech soundbridge wont sync
Logitech Wireless DJ Music System wont sync transmitter and receiver
    Novelist:
    Champion:
  • 250 Answers
Hi, I suggest you to contact the Logitech support for a replacement this is an hardware failure and it's covered by warranty terms.
If you are not under warranty you still can contact them as I know for instance in Europe they can offer you some good deal on nowadays products.
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Posted on Jun 08, 2010
I have an emachine and installed airlink 101 ,,keeps kicking me off line..what do i do? i am online for 5 minutes then it kicks me off IE. says i am still connected.. HELP!! thanks
The following wireless access points/routers have been tested for use with the SoundBridge and SoundBridge Radio. While Roku is unable to provide testing results for all available wireless access point and routers, the vast majority will work fine with your SoundBridge product. We encourage you to try using your SoundBridge with your existing wireless equipment, regardless of published result before replacing your current hardware.
The current SoundBridge models, M1001 (connections on the back) and SoundBridge Radio R1000, use different wireless hardware than the older M1000, M500 and M2000 models (connections under the endcaps). This newer hardware has proven considerably more reliable than the older wireless hardware and should work out-of-the-box with virtually any 802.11b-compatible wireless equipment you may have. Compatibility of the older hardware has been improved over time and we recommend that you upgrade your SoundBridge's software to the latest version as soon as possible, particularly if your SoundBridge was delivered with software older than version 2.3.44. Upgrading older software may require using a wired ethernet connection or even taking your SoundBridge to a neighbors house or your office to sucessfully perform the upgrade.
To check your software version and perform an upgrade, use your SoundBridge remote control to navigate to the menu Change Library or Configuration -> System Configuration -> Software Version and Updates and follow the on-screen instructions.
If you still experience Wi-Fi connection problems, check the following items:
  • Make sure your access point/router is configured to allow 802.11b devices to connect. This may be phrased as "Mixed mode" or "802.11b +802.11g".
  • If you have wireless security enabled, make sure it is a supported protocol, and make sure you are using the "Hex" key. See your SoundBridge manual for more information.
If, after checking these items, you still cannot get your SoundBridge to connect to your wireless network, we encourage you to contact support or visit our Roku Community Forums where other customers and Roku employees will attempt to help you.
Bold = recommended by Roku for use with the latest version of SoundBridge software.
Red = poor performance or incompatible with SoundBridge
* = customer tested - your results may differ.
Model M1001,
R1000
M1000,M500,
M2000
Notes Airlink101 AR410W Yes Yes Fast! Apple Airport Extreme (Snow) Yes Yes Buffalo WBR-G54 Yes Yes Very reliable Buffalo WBR2-G54 Yes Yes
D-Link DI-514 B1 Yes Yes
D-Link DI 624 Yes Yes D-Link DI 784 Yes Yes D-Link DIR-655 * Yes Yes Set to b/g or b only. Problems reported in b/g/n mode. Linksys WAG300N * Yes Yes Disable wireless AP isolation. Linksys WRT51AB Yes Yes
Linksys WRT54G Yes Yes
Linksys WRT54GC Yes Yes Linksys WRT54GS Yes Yes Works great Motorola WA840G Yes Yes Works great Motorola WR850G * Yes Yes Wireless mode should be set to Compatibility. Problems have been reported with using Performance wireless mode. Netgear DG834Gv3 * Yes Yes Firmware v4.01.06 may be required for internet connectivity and WPA. Netgear DG834G Yes Yes Netgear WGR614 v5 Yes Yes Netgear WGT624 (all hardware revisions) Yes Yes Netgear RangeMax WPN824 Yes Yes Works great. Siemens GigaSet SE361 * Yes Yes SMC SMC2804WBRP-G Yes Yes Needs firmware v 1.956 or greater SMC SMC2804WBR Yes Yes
USR 8054 Yes Yes Needs firmware v 1.64 or greater XRouter Aero WSR-5000 Yes Yes ZyXEL Prestige 335WT * Yes Yes AirLink AR315W Yes Yes Poor performance Airlink AR420W * AP/Router/Switch No
AVM 3070 * AP/Router/Switch No
D-Link DI-524 AP/Router/Switch No Some users report this router works fine for them. Linksys BEFW11S4 No No. Performance is unacceptable Linksys WRT54GL * No No Downgrading to original firmware fixes rebuffering issues. Linksys WRT54GP2 Yes Yes Very slow performance Linksys WRT55AG Yes Yes Works, but some customers have reported issues with accessing the Internet through this device Netgear FVM318 Yes Yes May work for some, does not properly route UPnP discovery packets between wired and wifi Netgear MR814V2 Yes Yes Poor performance Netgear WGR614 v4 Yes Yes May require B-only mode . SpeedTouch 716G * Yes Yes Can connect wirelessly and stream locally, but no internet access. USR 5462 Yes No
Note: If your wireless access point does not work well with the SoundBridge, please make sure that both the SoundBridge and the access point are using the latest firmware available.
Apr 20, 2013 | Computers & Internet
How do i connect a roku soundbridge to TX-NR509? I have tried optical, coaxial, and rca connectors. I have tried every inout.
The Soundbridge only has Audio OUTputs, so they would only work with INputs on a downstream device. Did it not come with a manual?
http://soundbridge.roku.com/support/userguide.php
http://soundbridge.roku.com/soundbridge/features.php
The Soundbridge is for all intents and purposes an external digital or analog source, not unlike a CD player, from the TX-NR509's perspective. ANY digital input must be assigned internally at the TX-509, which also has documentation here...
http://www.onkyousa.com/download/own_manuals.cfm
Jul 09, 2011 | Audio Players & Recorders
When I connect the USB for headset into system it messes up my internet wireless connection. when I take USB out my internet will work fine again
The wireless transmitter for your headset is causing interference with your wireless network.
If you can move your wireless networking equipment away from the USB transmitter then this may lessen the problem.
Perhaps using a usb cable extender will allow you to move your USB transmitter away from your computer?
Hope this helps,
Chris
Mar 02, 2011 | Logitech H760 Wireless Headset
My logitech wireless PS3 controller model number G-X5C11A will not sync to my PS3. It has no USB plug on the controller. Only the Ps button. And it refuses to sync!
Same problem, same model. It is a simple fix, there is a small reset button on the transmitter. Plug the transmitter in, restart the ps3 and press the button once it has been fully started.
Nov 07, 2010 | Logitech Cordless Precision Controller for...
What type of reciver do I need to logitech y-rj20 keyboard and mouse?
the receiver transmitter should have came with the mouse and keyboard if it was purchased as a packeged set. receiver transmitter should be small with two cords or one cord for usb if not, goto logitech and look for that model for item.
Oct 31, 2010 | Logitech Wireless Access Duo Optical...
How can i install my cordless mouse with no instalation cd
Hello
place batteries in mouse.
connect The Transmitter/reciever to the pc ( probably USB) and then press the sync button under the sender if there is one, and then press the sync button under the mouse.
windows should recognize it.
To get the driver search for your model on the manufacturer's website
and download the driver ....install driver and plug mouse in.
If this does not work let me now what OS ( operating system ) you are running.
and what you are plugging the mouse into.
Feb 24, 2010 | Logitech Cordless Mouse
Hi, I purchased two units of logitech cordless
Your friend should be able to use the headset if your friend's computer has Bluetooth feature. THe computer will send and receive the Bluetooth signals with one transmitter/receiver like your computer does and then connect to the wireless lan with a different transmitter/receiver system on a different frequency. Just make sure your friend's computer has Bluetooth feature turned on and then setup the headset by the "pairing" process.
Jun 15, 2009 | Logitech Cordless Headset for PC & Mobile...
Need manual and installation cd
The software to run the DJ system is available to download from the logitech website - you can also download online radio stations from here. Once you have the software, part if it is an interactive manual. The link you need is http://www.logitech.com/index.cfm/439/216&cl=gb,en?WT.ac=sc|downloads||dd
Hope this helps?
Marc
Jan 14, 2009 | Logitech Wireless DJ Music System (966194)...
Logitech wireless headphones
Trying re-syncing the transmitter and the headphones. Hold down the power buttons on both until they alternate red and blue blinking, worked for me and now they work just fine. Got that from the Logitech FAQ website.
Feb 27, 2008 | Logitech (980361-0403) Headphones
Logitech Wireless DJ Music System (966194) Headphones Logo
113 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
