Hp pavilion ze4900 charging but dead
When pressing power button. no activity, system dead but at the same time battery charges (charging led ligths) i removed keyboard tochpad dvd still no activity
  • dennis levaughn Jul 24, 2008
    HI, I was working my hp one late nite, I heard a funny sound that I need heard before, also it feels hot then it shut off . My hp is my first laptop and it is the love my heart and now she's not working .I need help with my hp. Thank you for help . The hp laptop heart broken man. ( smile ) dlevaughn1@yahoo.com
  • 22 Answers
Follow the below check list
Check1 : is power cable connected properly to computer
try checking all the cables are fixed properly
Check2 : Are you listining to Beep sound when your computer is poweron
IF yes then Ram is working properly
IF no then remove and fix your ram chipset again
Steps to do so..
switch of computer ..
open cabinet
You will find ram slot...press bars at both the ends ram will comeup directly..insert the chip again (donot press forcibly ) press gently untill you hear a click sound...
Switch on computer you should hear beep sound and computer will boot.
Thanks.....
Posted on Dec 16, 2007
My Pavilion g6-1b79dx notebook will not charge even with a new battery and charger. The light indicating the charger is plugged in is blinking white
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/replacement-hp-pavilion-g6-ac-adapter-19v-90w.html
Dec 09, 2012 | Plantronics Hp - Pavilion G6-1B79Dx Laptop...
My HP Pavilion Dv 5000 notebook stop working: no power and the power Led is off. I opened it and tested the power cable which is OK; I checked all over the motherboard looking for some damaged or burnt...
Of the two LEDs at the left front of the notebook, if the left-most one is blinking, then the notebook is in standby. If the left-most one is off and the one to the right of it is blinking, then the notebook is in a low battery condition and quite likely the notebook had initiated hibernation. If you had the AC adapter plugged-in for some time and the low-battery condition persists, then likely the adapter has failed. Normally you would just press the power button to restore from hibernation but if the system had initiated hibernation due to a critical low-battery condition, the system may not respond unless you have inserted a fully-charged battery pack. Here is an excerpt from page 38 (Chapter 3 Power) of the HP Pavilion DV5000 User Manual....
*If the system initiated hibernation because of a critical low-battery condition, connect external power or insert a
charged battery pack before you press the power button. (The system may not respond if the discharged battery pack
is the only power source.)
Jul 27, 2011 | HP Pavilion dv4000 Notebook
Hi i need help plz, i've my laptop do not power when i plug the ac adapter ther' is no ligth
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 23, 2011 | Dell Inspiron 2200 Notebook
My hp pavillion dv6700 will not power up all of the blue lights will flicker as i press the power button for a few seconds then it will power off. ive tried taking the battery out and running it strictly...
Your DC jack may be loose or broken off the system board.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it's still under warranty, it would be fixed at no charge to you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Jan 19, 2011 | HP Pavilion dv6000z Notebook
My HP dv7 laptop wont turn on I purchased a new battery and a new cord it worked for an hour then shut off again!!!!!!!!!!
Your DC connector is loose from the system board:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it's still under warranty, it would be fixed at no charge to you.
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv7-notebook/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 01, 2010 | HP Pavilion dv6000z Notebook
My HP dv2000 shuts down and does not turn back on. The power cord is connected but the charging light is not on.
Your DC connector on the system board is loose:
Problem symptoms:
If it is under warranty, HP will repair it. If not , read this:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Thanks, Joe
Nov 30, 2010 | HP Pavilion dv2000t Notebook
Hi There, I have a HP Pavilion ZE4900 and recently the AC plug in won't work. I have taken the battery out and put it in another comuter that is the exact same and it charges fine, I put my battery in the...
If your computer won't charge the battery, but the battery charges fine in another computer, and you are sure that the charger is good, then your problem is probably the DC power jack. If you wiggle the end of the power cord where it attaches to you laptop, and it starts charging properly, then the DC power jack is broken.
Apr 26, 2010 | HP Pavilion Ze4900 Notebook
HP ZD8000 won't power on
have you tried this with the battery removed from the laptop?
Oct 02, 2009 | HP Pavilion zd8000 Notebook
The Battery in my Hp Laptop Pavilion ze4900 is
using the wrong ac adapter the e500 adapter is not the same voltage or watts!
Feb 26, 2009 | HP Computers & Internet
Computers & Internet Logo
580 people viewed this question
Alun Cox
David Payne
David Payne
