Question about Rockford Fosgate T10001 bd Car Audio Amplifier
Hi my amp keeps clipping at high volume......i know is not the wiring...can u help me
    Problem Solver:
  • 14 Answers
Turn the volume down or the gains on the amp (should be around 3/4 and no more) or get a bigger amp so you do have this problem
Posted on Sep 25, 2009
Sub static at low volume fine at high volume
Prob always there just can't hear it at higher volumes. Check the grounds of the amps an the Caps if you have them. Then check the preamp wires from the head unti to the amp. Keep it as shielded from power wires as you can. Some times tying a ground from the amp back to the head unit ground can fix a hiss or static
Dec 25, 2013 | Kicker 02S10L74 Car Subwoofer
MY amp is going into clip mode. what is clip mode on an infinity car audio amp?
either your pushing your subs to hard and its creating a backsurge of resistance, or the spider wires are touching the frame causing them to foul out. It honestly sounds like you are trying to run too low of an impedance subwoofer, and your amp infinitys clip to keep from distorting, distortion played through a subwoofer at high volumes is damaging to the subwoofer and the amplifier. reduce your gain, and check your wires, the clipping should stop, a good rule of thumb always have an amplifer that will do rms what your speakers can do peak, so that way you can keep the amp turned up only 1/4 of the way and be pushing your subs at a decent rms volume with 0 distortion.
Aug 09, 2010 | Car Audio & Video
Hi my name is David i have a 900 watt punch amp in
Hi, If you mean clipping on/off to be cutting out, then there are a few causes for this.
1) overloading the output circuits.
2) speaker wires shorting to earth/each other.
Try running 1 set of speakers at a time.
P.S. giving us a little more information will help profusely i.e amplifier capabilities, how you have the speakers connected. etc.
Jul 13, 2010 | Alpine MRD-M605 Car Audio Amplifier
I have amp hooked up and at high volumes my amp cuts out until I lower the volume.What do I have to do to maximize volume limits?
You need to add a capacitor to your system or you can shorten your ground wire which works some of the time time or you can increase your wire gauge going to your amp. Any or all of these things can help. Another very important thing to remember is you need good air flow around your amp to prevent from heat overload.
Nov 12, 2009 | 2009 Toyota Camry
How to turn off the clip light is on red it does not turn off?
You can't, the clip light is just that...the signal is being clipped/distorted and the clip light comes on to protect the amp/speakers from blowing. You need to check your signal and then cables and wiring to see where the problem lies, chances are your volume is too high and your over working your amp....(turning the volume too high when the amp doesn't put out enough power for your speakers and this distorts the signal causing it to clip)...Try turnig the amp down, should not be any higher then 1/2-3/4 of the way never max. And if that doesn't work check your signal from the radio as well. If it works fine with the volume down and doesn't clip then your amp is too small for your needs and your need to invest in a larger amp for more power...Look for RMS watt ratings at 12-14 volts not max watts at like 16-18volts (those are fictious #'s and those amps should be avoided)
Nov 02, 2009 | Crest Audio CA9 Car Audio Amplifier
I want to know how to tune my car audio system without making my woofer clip
Start by turning the amp volume down, clipping is not from tuning its from too small and amp then turning the volume too high or a very distorted signal, this then causes the amp to produce high levels of distortion which cases damage to amps/speakers. Make sure the sub frequency is around 60-80hz and the volume is no more then 3/4 of the way up. You may also have a bad signal from your radio or bad RCA cables but I would start with the amp gain first...
Nov 02, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
ZX700.5 cutting out at 60% volume
I figured out the problem, the front right tweeter wire was pinched behind the mounting bracket. everything is now working perfectly.
Sep 22, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Amp Turns of when i put the volume up to 20
if it only happens when you turn it up, you could be sending it too hot of a signal and its clipping so the amp is protecting it self and shutting off. Try lowering the input gain on the amp and see if that helps. It's also possible that your speakers are pulling to much power when you have it turned up that high and the amp is shutting down to keep from overheating. I don't know what or how many speakers you have hooked up, but if you have a sub, try it without that and see if you have the same problem. If you don't have a sub, disconnect the largest woofers you have. Different speakers have different ratings for how efficient they are. It's usually measured by how much SPL 1W will produce. You want to disconnect the speakers that are pulling the most power and try it again. If your speaker is pulling more power than your amp can supply, your amp could shut off because of that. As well as cook the voice coils in the speaker and damage the amp. It's always better to have too much power in your amp than not enough. There's an old joke I learned in audio engineering school "I can pass a square wave.....once."
Jun 13, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Amp going into protect mode
If you set the gain too high on the AMP, at loud volume levels some clipping or distortion of the output signal will occur. Most amps have a Circuit inside that detects this clipping or distortion and applies protection to prevent damage to the speakers and the amp. It would help to know if you are driving the speakers with a Line level output or using the speaker output from your deck. There are many things that can cause an amp to go into protect mode, and knowing a little more about your setup will help to solve the problem.
Nov 07, 2007 | Alpine PDX-4.100 Car Audio Amplifier
Rockford Fosgate T10001 bd Car Audio Amplifier Logo
383 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
