Question about Windchaser Freezer ICM15 Portable Ice Cube Maker - Grey
My windchaser ice machine makes ice , but push arm sticks in up position and does not drop to push ice into collection basket. Can this arm be lubricated and with what product since it comes into contact with the water and ice .
The machine will not stop making ice even after the basket is full
The small handle inside your ice tray box push it up.That cuts it off from making ice.
Apr 14, 2016 | Freezers
Igloo model ICE108. Why does the ice full light stay on when there is no ice in the basket?
Because the ice level sensor is stuck in the full or up position. As long as it is there, the ice maker is shut off and will make no ice.
Oct 27, 2015 | Freezers
Ice thickness control
The ice thicknes control is located on the bottom left. it has a wire going
to it and ha a black rubber bottom. depending on the position it is secured.
will determine the ice thickness. loosen the two screws and push it higher
for smaller cubes and lower for bigger. If you are having problems with it.
There is the possibility it is dirty and sticking.
Jan 14, 2013 | Hoshizaki Freezer Commercial Ice Machines...
Find a windchaser portabel ice maker manual, model ICM15S
Believe it or not, this link has the ICM15 manual. Now if I can just get my
dump tray to rotate before the cubes all freeze together ...
Aug 30, 2011 | Windchaser Freezer ICM15 Portable Ice Cube...
My Windchaser ICM12 will not work. The cube size indicator blinks constantly. unplugging the unit to reset does nothing. What is wrong?
What I tried is to manly rotate the water trough that has the swing gate & pushed the Stop button. No results. I then tried rotating it back -n-forth several times, unplugged, replugged, posed Start, AND IT WORKED!!!
Jul 18, 2011 | Windchaser Freezer ICM15 Portable Ice Cube...
I have a older modle of crystal tips ice machine that will drop the first load then it starts to freeze completely up and will not drop any more loads. It becomes almost a solid wall of ice.
Check to see that the sensor that feels when the ice has built up adequately is swinging back to position after it harvests the first time. Check to be sure it's clean too.
lp
Jan 11, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
Water does not seem to be flowing into ice maker.
Hi and I hope this will help. You can manually turn the timer and see if any water is dispensed into the ice cube tray . If no water is dispensed check if the valve is any good . A solenoid in the valve opens to allow water in to the ice maker. Sometimes timers stick too.
Jul 05, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Water leaking onto ice and outside panel on Hoshizaki KM-500MAE
Remove the cover where the persons finger is and check to make sure that it is not covered with ice. Sounds like your machine iced oup and you will need to clean the coils and possibly replace the thermostat
Feb 12, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Freezers Logo
70 people viewed this question
Top Windchaser Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Windchaser Freezer Expert? Answer questions, earn points and help others
