Question about Euro-Pro Shark GI490 Iron
Euro-Pro Shark GI468 Iron shut off while I was using it - Now it won't turn on - Is this repairable and if so, how?
SOURCE: Shark Euro Pro Iron turns
I was having the exact same problem. It happened infrequently, then over time it got worse. I would jiggle the cable to get it to turn back on again, and that worked for about six months. Eventually the iron was unusable, I had to hold the cable in one spot and it would go on for about 30 seconds, then die out.
I decided to go on a little adventure inside the iron to see what the problem was. I was convinced the cable was frayed on the inside from rotating so much. After unscrewing the bottom, I found there was plenty of rust inside the iron, which had gotten all over the contact points from the AC cable from the wall connects to the heating element. If I moved the cable back and forth, I could hear it sparking and get a good connection.
It doesn't appear that the rust was from water leakage inside the iron, but rather steam produced while ironing. After cutting the wires and soldering the connection, the iron works fine again. It took about 1/2 hour to do from start to finish.
I would recommend getting a different brand, it only took mine a year from purchase date to fail.
Posted on Oct 02, 2008
SOURCE: Stopped producing steam
Iron not heating up sufficiently to produce steam. Threw it out!
Posted on Jun 25, 2009
SOURCE: Shark Euro-Pro G1490
Our G1490 quit after one year. Just won't come on. Period. I can't get it to open after removing the back screws either.
Posted on Apr 26, 2008
  • 19 Answers
SOURCE: shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Posted on Aug 16, 2009
  • 4 Answers
SOURCE: shark euro pro x
We fixed ours today. Take the iron plate off (bottom of the iron shaped like a triangle). You are looking for a thermal fuse (or thermal-protector fuse) pictured here for less than $2 at Radio Shack(http://www.radioshack.com/product/index.jsp?productId=2102788&CAWELAID=107599331). You will need needlenose pliers to gently remove the old fuse and the wire cutters to trim the long wires to the same length as the old fuse (less than 1/2"). Also, since the old fuse was 240 C and we only could find a 228 C replacement - we cannot use the iron at the same high temp. So we limited the dial by marking out a portion of the dial. The iron stopped working after I kept the iron on high for an extended period of time. My electrician husband explained that I over heated the iron - breaking the fuse. Not time I'll turn the iron off or down when I'm not using it. This was so easy, I'm going to check out our other broken irons.
Posted on Dec 30, 2009
Shark g1468 auto shut off (iron won't come/stay on)
First let me say I HATE AUTO SHUT OFF!!! It sounds like it has wore out. the computer part that tells it when to shut off it not working. It would be cheaper to buy a new one vs fixing yours. If I were you, find an older iron that has LOTS of steam vents and NO AUTO SHUTOFF at your local goodwill, thrift store or garage sale.
Jan 06, 2014 | Shark Euro Pro GI468-FS Rapido...
I have a Shark automatic shut off model G149011 It just shut off and will not come back I have only had the iron for 10 months I purchased at Walmart. How can get the iron fixed or replaced
you prolly have a 1 year warranty, return it to walmart or they will have the address of the local repair depot or contact shark for the local repair depot they use
May 25, 2011 | Euro-Pro Shark GI490 Iron
Was using my Shark x-tended steamburst Euro-pro iron G1490 and it turned off and won't turn on
I had the same problem. The repair took less than 15 min. I opened the bottom of the iron and discovered what appears to be a design flaw on the cord holder/fastener. The holder is wedged so tight that it pinched the cord wire almost in half. I removed the cord, cut it off at the pinched spot and reinstalled. I also put a small piece of rubber onto the part of the holder that is made onto the body of the iron. In addition, I rotated the fastener cap so that the smooth side of it is against the cord.
Jan 12, 2011 | Euro-Pro Shark GI490 Iron
Iron shuts off
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 15, 2010 | Euro-Pro Shark GI490 Iron
Euro Pro Shark Iron
Thank you for taking the time to warn us and others about the euro pro shark iron. I will help spread the word.
Aug 10, 2009 | Irons
Shark euro pro G 1400z
how do you replace the light bulb on a shark euro-pro iron?
Oct 27, 2008 | Euro-Pro Shark GI475 Iron
Euro-Pro Shark GI490 Iron Logo
356 people viewed this question
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
