Question about Keys Fitness Exercise & Fitness
I have a keys Pro 650 Conventional Treadmill It has set in the basement without being used for about two years. Now it won't start
SOURCE: lost key for my weslo cadence 860
We found the key.
Thanx
Posted on Sep 03, 2009
  • 3 Answers
SOURCE: I have no key for my treadmill mot566 carl lewis can't start it
Go to treadmilldoctor.com $10- $15
Posted on Feb 20, 2010
SOURCE: I plugged in my Pro-Form 730cs treadmill and it won't start.
My i FIT treadmill won't turn on. Is there a reset button somewhere?
Posted on Apr 26, 2010
valeantudor
  • 787 Answers
SOURCE: I have a model 297980
You have to put the safety key in if you want to select speed/incline or predefined programs.
It starts and runs at full speed on that occasion because it's part of the maintenance process, that lubricates the inner rollers so that it will continue to work perfectly for as long as possible.
Posted on May 01, 2010
ercupa190
  • 12223 Answers
SOURCE: My treadmill won't start. Help pro firm at 500
Observe carefully and follow the step:
http://www.youtube.com/watch?v=N6Yg5S0WML8&NR=1
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
Of course you must shure the breaker from your house is Not Tripped, reset anyway
and test it.
Posted on Nov 15, 2011
Pro form 635cw stops after 10-12 minutes.
please see the video and fix it .This happen because the lack of maintenance schedule in your equipment,God bless you
Apr 04, 2013 | Treadmill Doctor Proform 635Cw Treadmill...
Sole treadmill won't go in to sleep mode
You need to go into the maintenance menu.
Take out the red safety stop key, hold down the "start", "stop" and "Enter" buttons, keep holding them down while putting the red key back in (a bit tricky), keep holding the keys down until you see "Maintenance menu" scrolling (this will happen as long as you didn't let go of the three keys).
Initially when you put the red key in it'll might show software version etc, after a few seconds it'll change to maintenance menu. Use the speed UP and Down buttons on the console or arm to scroll through menu until you reach "FUNCTIONS" press enter.
In the functions sub-menu, depending on what year model/software version it has, it should have a selection called "Sleep Timer" if so set it using up down keys to "ON". If your model doesn't have "sleep timer" listed (i.e. a newer model) it's now just called "DISPLAY" and in that case set it to "OFF". That should fix it.
Press Stop, to go back. If you want you can disable the key tone/training beeping as well in the "functions" sub-menu of the "maintenance menu".
To exit press stop repeatedly until you're back to the normal display.
Dec 30, 2012 | Sole Fitness F63 Treadmill
Image 935 treadmill wont turn on
see the video and proceed for fix it. God bless you
Nov 25, 2012 | Exercise & Fitness
'07 klr 650 won't run without choke on
Hi, Lance and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Won run without choke
KLR won idle without choke backfires on decel
Kawasaki KLR650 Service Manual
OEM Parts for Kawasaki
Kawasaki KLR650 Owner Manual
Jul 01, 2017 | 2007 kawasaki KLR 650
Error 100 won't connect to network anymore to use ifit live
Check the power cord to ensure it is connected to the power supply and the treadmill if the power does not stay on or does not turn on. Look at the circuit breaker, located near the base of the unit, to see if the circuit was tripped. Push the switch back in to reset the circuit.
  • 2 Take the key out of the console, wait a minute and place it back in the console to resolve issues with the power turning on and off during use or if the console displays are not functioning properly.
  • 3 Remove the console key and press the "Stop" button to turn off the "Demo" mode, which is often the default setting when the treadmill is first purchased.
  • 4 Reset the incline by holding down the "Stop" and "Speed increase" buttons and putting in the console key. Release the buttons and then press the "Stop" button, followed by the down or up arrows for the incline. This step can be taken if errors are occurring with the incline function.
  • 5 Turn the treadmill "Off" and unplug the unit if errors continue. Wait five minutes and then plug the unit back on, insert the console key, and turn the treadmill "On." This will reset the treadmill and should return to normal funcTION
  • Oct 04, 2011 | Nordic Track NordicTrack Elite 9500 PRO...
    Is it possible to operate a Nordic track A2550 treadmill without the key? If so, how?
    First thing I'd try is just using any magnet. I'm sure that's all the key is normally. If that doesn't work, no you cannot use a treadmill without a key. It's a safety measure created by the company.
    Here's the key for sale on amazon that goes to your treadmill.
    http://www.amazon.com/Pro-Form-Treadmill-Safety-Key/dp/B002YP4KQE
    Hope this helped!
    Jun 18, 2011 | Exercise & Fitness
    Ifit treadmill will not incline but everything else works, how do I fix the incline
    You may need to calibrate the incline. Do this with the following procedure.
    Safety key out
    press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
    press the stop button one time only.
    now press the incline up button (incline motor should start moving up)
    incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
    Good luck Tim
    Nov 23, 2009 | Proform Quick Burn Pro Treadmill with 12...
    Aug 28, 2009 | Proform Quick Burn Pro Treadmill with 12...
    Exercise & Fitness Logo
    170 people viewed this question
    Top Keys Fitness Exercise & Fitness Experts
    Electro Med Services...
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you a Keys Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
