Question about Dell Inspiron 1525 Laptop
When I turn on my dell 1525 it says internal no bootable devices
  • 788 Answers
Ok, it sounds like the Hard drive is not being seen by the unit.
Try this, Enter your BIOS setting, some units F-2, some del, some F-9 or 10.
On the last page, choose default settings.
Reboot the unit and see if the Hard drive is seen.
Remove any disks from your CD/DVD drive or floppy and disconnect any external devices.
If that does not fix the problem, remove and reseat the Hard drive and memory.
If you can get into windows, check your device manager for flags and you may need to load your hardware drivers.
Hope this works for you.
Posted on Sep 25, 2009
    President:
  • 2,600 Answers
The BIOS is not reading your hard drive. Take the drive out and reboot into BIOS. Make sure the SATA port is enabled. Turn the laptop off and reinstall the hard drive, make sure it seats all the way and is secure in its caddy. Reboot and see if it reads the drive.
2 Suggested Answers
SOURCE: hello i have a dell
Try....turning it on and try tapping on F8 as it is starting....there it will take you to a system restore area...If you Image restore it will take your computer back to the date of when you first bought it....(as it left the factory).....It will delite everything you have put on it including picture or and other files. But it will give you a clean slate to start with
Posted on Sep 10, 2010
Dell inspiron 1525
It's a bad hard drive. The only solution here is replacing the hard drive.
Feb 05, 2013 | Dell Inspiron 1525 Notebook
I have a Dell Inspiron 1525 and when I turn it on it tells me NO BOOTABLE DEVICE DETECTED This happen one other time and I rebooted my computer and it came back on but it did not work this time what can I...
NO BOOTABLE DEVICE When the PC cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press any key"
There may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the hard drive and also where it connects to the motherboard.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Sep 16, 2012 | Dell Inspiron 1525 Notebook
I turned my computer on and it said NO BOOTABLE DEVICE I had that trouble one other time What can I do?
Remove the hard drive and reseat it back in place, sometimes this will cure the problem. If this fails have the hardware checked for possible replacement.
When my wife boots up her Dell Inspirion 1525 about every third time, she gets a black screen reading "No bootable devices found".
it seems your harddisk connection is not tight enough, you'll have to open your notebook up to check it.
Feb 21, 2011 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 shows black screen after dell logo?
The computer cant find a bootable device. Either your boot sector on your Hard drive is gone/damaged (most likely a virus) or the Hard drive failed. Start with booting with your windows disk and try to do a repair installation.
Nov 03, 2010 | Dell Inspiron 1525 Notebook
Hello i have a dell inspriron 1525 and when i try to turn it on now the black screen comes up and it says "Internal: No Bootable Devices". is there anything i can do?
Sep 09, 2010 | Dell Inspiron 1525 Notebook
Have a Dell Inspiron 1525 laptop and every now and then it is shut down for no reason with this message on the screen: internal hard disk drive not found To resolve this issue, try to reseat the...
The link below is supplied by Dell, for checking Hard drives on Dell machines, try this.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6
Aug 04, 2010 | Dell Inspiron 1525 Notebook
My laptop turns on but it says there is no bootable devices.
Your hard drive is bad and will need to be replaced. Everything, including Windows will need to be re-installed.
Dec 11, 2009 | Dell Inspiron 1525 Laptop
Dell Inspiron 1525 Laptop Logo
160 people viewed this question
Alun Cox
