Question about Sony Ericsson K850i Mobile Phone
Screen keeps blacking out
I noticed the area around the digits 4, 5 and left scroll button on the dial pad makes my screen go black. Everything is okay until I press 4 or scroll left and that's when the screen will go black and the other buttons just light up. I can still call out and receive calls.
I have the same problem. anybody know how to fix.. please help
Posted on Oct 05, 2009
Can't remove the RAW Setting to keep just the JPEG option without RAW. It is set to RAW and the dial only scrolls through JPEG options. How do I get access to the RAW options to turn off RAW??
When on the image recording quality setting screen, use the main dial to select RAW (go all the way to the - sign on the left to turn off RAW), and use the multicontroller left/right to select JPEG settings. See page 116 in the manual.
Jun 20, 2015 | Canon EOS 70D Digital SLR Camera Body Kit,...
I want to clear my zune. master reset
Hit the Back and Up buttons then when the screen goes black press the Back button, left touch pad, and center touch pad. That should clear everything off the Zune. :)
Oct 29, 2010 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
I wanna send a fax
Sending Faxes.
* Flow of Sending Faxes.
The operation flow of sending faxes is as follows.
Step 1:
Load the original to send on the Platen Glass or the ADF.
Step 2 :
Adjust the fax quality and scan contrast.
Step 3 :
Dial the receipent' s number.
Step 4 :
Send Faxes
- Using the Platen Glass
1) Press the Color or Black button.
If you have two or more pages of the original, load the next page on the Platen Glass and press the Color or Black button
2) After scanning all the pages of the original, press the OK button to send the fax.
- Using ADF
The fax is sent automatically.
* Before sending Faxes
- Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
** Adjusting the Scan Contrast
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among the 3 contrast levels.
1) Press the FAX button, then press the FAX Quality button.
2) Press right or left arrow ot select the contrast.
Pressing the left arrow button decreases the contrast, and pressing the right arrow button increases the contrast.
3) Press the OK button.
** Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
1) PRess the FAX button, then press the FAX Quality button two times.
2) Press the right and left arrow keys to select the resolution.
FAX RESOLUTION - STANDARD
Standard : Suitable for text-only documents.
FINE : Suitable for fine-print documents.
PHOTO : Suitable for photographs.
*Sending Faxes - There are 4 methods for sending functions
a) Memory sending
b) Manual sending
c) Dialing the coded speed dial
d) Redial
a) Memory sending
1) Prepare for faxing
a) Turn on the machine,
b) Load the original on the Platen Glass or the ADF.
Note : You cannot scan double-sided documents from the ADF.
c) Press the FAX bitton.
d) Adjust fax settings as necessary.
2) Start faxing.
a) Dial the receipient's number using the Numeric buttons or coded speed dialing.
b) Press the Color button for color sending, or the Black button for black and white sending. I
c) When the following message is displayed, lad the next page on the PLaten Glass.
Scan Next -> Start
Transmit-> OK
If only one document go to step f).
d) Press the same button as you pressed in step b).
e) Repeat step c) and d) to scan in all pages of the document.
f) Press the OK button.
Manual Sending
1) Connect a telephone to the machine.
2) Prepare for faxing.
a) Turn on the machine.
b) Load the original in the ADF,
c) Press the FAX button.
d) Adjust the fax settings as necessary.
3) Lift the handset of the telephone connected to the machine.
4) Dial the receipient's number on the telephone.
5) Talk through the handset to the recipient.
If you hear a high-pitched signal instead of the recipient's voice, go to step g),
6) Ask the recipient to set recipient's fax machine to receive faxes.
7) When you hear a high-pitched signal, press the Color button for sending color sending, or the Black button for black & white sending. Then hang up the handset.
Dialling The Coded Speed Dial
1) Prepare for faxing.
2) Press the Coded Dial button.
3) Press the Numeric buttons to enter the two-digit code (00-19) assigned to the number you want to dial.
4) Press the Color button for color sending, or the Black button for black & white sending.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Nov 27, 2009 | Canon PIXMA MX310 All-In-One Printer
There is a black 2 1/2inch bar on leftside of screen how do i adjust is?
if your lucky it's just your H-center is off tilt. to check this Press the menu button on your monitor. scroll through the options till you see Horizontal-center option. select this setting and move the screen to the left. The entire screen should start shifting to the left and fill in the screen. now if you do this and you get a black bar on the right. Center the screen where you have the same amount of black on both sides of the screen. scroll through your menu till you see the H-size. increasing this will fill in the black area. Hope this helps.
Sep 13, 2009 | X2Gen MG19MY 19" LCD Monitor
DROPPED PHONE NOT SURE WHAT I NEED
You can replace the lcd screen and digitizer.
Its about $40 US on ebay. Try searching treo 750wx screen/digitizer/touch screen, etc. Also i tried searching treo 750wx but it didn't work, I suspect the 750 to be the same as the wx, but you might wanna make sure with the seller incase (Ask seller a question link is on the listing, or click their username and go to their profile and click on contact)
Feb 27, 2009 | Palm Cell Phones
What are the function of the buttons on gear shifter
Buttons for the G25 wheel and PS3
Top 4 The Black ones
Top-triangle-cancel-reverse(gear to back car up)
Left-square-cancel
Right-circle-E_brake
Bottom-X-enter You can also use the gas pedal for enter
Bottom 4 buttons The Red ones
Far left-no function
Second button-Change view
Third button-Pause-quick exit replay at the end of race-This button will also speed up the winnings (to keep from waiting with the cup spinning around so you can get back to racing)
Fourth button-best race line for license test
Buttons on wheel
Left-look back (default)
Right-nitro (default)
I change these two buttons around myself so I have the nitro on the left.
D-pad-same as the controller up,down,left,right. For menue use.
Also for (during race)
Look back-bottom pad
Look left-left pad
Look right-right pad
To change any of the button functions use the DFP settings in the options menue.
I have not used the wheel in photo mode. The only thing you can't do with the wheel is "exit" game. I also never have my controller on during gameplay I only turn it on to exit the game. If anyone needs anymore help with this wheel give me a shout-back and I'll try my best to help.
One last thing make sure your wheel is in the far left port(port 1) or port 3
Jan 13, 2009 | Logitech G25 Wheel And Pedals Set
How do you take black and white photos?
open camera, set dial to 'i', press 'set' button on the menu, in recording options (REC), scroll the menu to COL.MODE, press left button on the menu and select 'b/w"
Jan 04, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Froze up magellan maestro 4250
I think there is reset somewhere on the unit. Look around. Mine has a slide switch to reset. Try everything. It already doesn't work. Can't hurt it anymore than it is.
Mar 24, 2017 | GPS
How to take black and white pictures with the EOS 20D
1. Press the Menu button, and make sure you are on the Shooting menu (red)
2. Use the Quick Control Dial to scroll down to Parameters
3. Press Set, Press Set again
4. Scroll to B/W
5. Press Set
6. (Change sharpness, contrast, etc if desired)
7. Press the Menu button to exit
You should see the B/W icon to the right of center in the top LCD.
Apr 22, 2008 | Cameras
Camer scrolls through modes all on its own! sony DSC W100 digital camera
very good poss that camera needs mode dial switch assembly.Especially if unit was subject to liquids near the mode dial .part # 147966811 for silver and 147966821 for black model..First reset camera by pushing reset switch should be around batt compartment and or memory stick area.
Dec 03, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Sony Ericsson K850i  Mobile Phone Logo
246 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
