Question about Baby Gear
I need the 2 plastic pieces that attach the drop rails
The small plastic pieces that are on the bottom of the drop down rails that actually hold the rails on track for Delta Luv Crib Model 4750 Manufactured mar 20 1998
  • 164 Answers
Certain parts are available only by calling Delta Customer Service directly at 1-800-377-3777 EXT 6221 Monday- Friday 9:00a.m.-5:00 p.m EST.
Or I can send you the ones I have just taken off my crib, when I converted it to a toddler bed. If you want me to please email me kristy.mahar@charter.net
Posted on Sep 25, 2009
Drivers side window off track on 99 monte carlo
take off inside panel roll down window while you hold window with hand if you look on bottom rail you will see a plastic piece that holds window on bottom rail that broken part will let your window move off bottom rail that lifts window thus it will come off track its a cheap part that you can buy and fix your window
Feb 15, 2013 | 1999 Chevrolet Monte Carlo
Show assembly for Bassett crib model 5918-505
I have a 5918-505 mI put it togehter for the first time since 1980 I had no problems once I located all of the parts: 4 metal guide rails, 2 wooden ends with 2 wheels in each, 2 wooden drop sides (or front and back that go up and down.) 2 metal toe kick rails that hold the sides up, 1 mattress springs, 4 metal mattress spring supports. attached to the inside of the wooden ends are 4 hanger pieces for the mattress spring support to hang on.
I could supply photos if needed.
Oct 23, 2011 | Bassett Mission Crib
I have an older FR350 nailer. The coil return spring broke. I have the replacement and want to fix it. Do I have to take the whole nail guid assembly off to replace this part!
The best way to replace the spring is to remove the rails entirely. Take closeup photos of the gun from all sides with your digital camera or camera phone to help you with placement of all screws. You will need small clamp, small vicegrips and paperclip or piece of soft wire with small hook bent on one end to temp hold spring in place. With rails in hand check if pusher will slide out front of rails (some rails have a small casting preventing pusher from coming out front ~ remove tailpiece and slide out back ). Locate small screw /nut holding spring in place (keep this side of rails facing you). With new spring in place slide pusher into rails until you can catch the eye of the spring with bent wire at front of rails. While holding wire with vicegrip pull back pusher a few inches and clamp in place with c-clamp. Pull or let in bent wire to align eye of spring to attachment hole and install screw (you can leave bent wire in eye and just break off later. With screw attached break off wire and install rails to gun. Check sliding action of pusher before installing bolts at rear of rails. The pusher on some porter cable guns have plastic sliders that easily break with normal use and should be replaced as needed. Good luck.
Feb 08, 2011 | Porter Cable Air Tools & Compressors
How to I take apart the drop down side of this crib. I had it installed and can't figure it out
This is tricky but I have put it together and taken it apart countless times (3 kids, 2 houses and everyone switching rooms). All of the screws keeping the crib together need to be as loose as possible without the crib coming apart. I found it easiest to have someone help so they can help hold the crib. It's important not to pull the drop side apart as it will break the plastic slides (I've done this and had to replace them). Have your helper hold one side of the drop crib right against the side piece of the crib and slide the drop side down to detach it from the side your helper isn't on. once this side is detached do the same for the opposite side. On the crib side that attaches to the drop side is a "screw" that slides down the plastic slide and a "peg" at the bottom. I always get the peg out of the track and then you can slide the screw all the way down the slide to get it out.
Jan 04, 2011 | Cara Mia Louise Crib
Broke the flimsy support plastic ring - Need to order new one
i would do a tack together job on it,,
get some thick fuse wire and tiy it round inside the grill holes on the out side edge tiy each one together at about every inch apart around the grill that will hold the two grill's tight, then if you still have the broken plastic bits glue them back on using supper glue its cheeper that trying to get part that you may never find?
Oct 27, 2009 | Minka Aire F602-BNCH Gyro? Fan
I disassembled to clean and can't put it together again. Please help
I will describe how to re-assemble a 5886xl, it should be similar...but maybe not. If you mean just the shaving head, not the whole shaver, skip to the bottom here.
There are 2 circuit boards within the 5886xl, the bottom one with display snaps into the top board's multi pin connector, but before, there is a nylon spacer that goes between the boards, alignment is simple, note the cutout for the beeper. If replacing the batteries, you can solder new leads onto the old areas, either by poking wires through, or if having broken off the old battery, onto the flat thin areas left. These may break or come loose during soldering however, so the through-way may be better. Now you can reassemble. There are 2 screws holding the head on, the black plastic piece with the motor attached and the 3 rotating driver sections. The bottom circuit board should fit into the display containing side piece fairly easily. Snap the plug connector into the hole. Screw the 2 screws that hold the motor/head assembly to the display side. There is a retaining piece for the battery in this model, which has a snap that goes into the 2nd circuit board, and the v-wedge holds the battery in place.If using a prebound pack, you can leave this out, and use the small piece of neoprene foam that prevents shaking, that will work. Ok, there are 2 more pieces in this model here...you place a piece that has a hole in the middle (to accept a screw) and 2 clasps...this goes right behind the motor, and over the battery posts. Should snap in. There is another piece that goes over the charge connector, it has 2 holes middle, and 2 to the sides, those at the sides get 2 more silver screws. In this model, there are 2 black pieces, slide them into the sides appropriately. Now place the top section into the shaving head assembly, drop it down onto the back with the connector...should line up just right. There is a screw hidden in the popup shaver section, open that, apply a brown/black screw. The last screw goes at bottom. Attach the head, and you are done.
Now if you removed the retaining clip that holds the individual heads on...place the head assembly on a desk, shaving side down, with any cutout for release button at bottom. You will have 3 screen pieces (which apply to your face)...each has a blade inside. So, if re-assembling, place the screens inside the head assembly. Then insert a blade into each. Apply the tri-circular blade retaining clip piece into the assembly, push gently, and rotate the little round gear piece in the middle while doing so, clockwise to set. Pop the head back onto the razor. The heads should auto-seat once you turn it on. Voila? :)
Jul 14, 2009 | Norelco 7610X Electric Shaver
Can not get crib together...need instructions
called the people we got it from and they came and put it together. It would have been impossible without them or instructions
Sep 16, 2008 | Cosco 2 in 1 10-185-WHO Crib
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
Delta Luv Dutchess 2 in 1 crib
The front rail(drop rail) has a little plastic piece attached to it that reads "push".  This will be on the bottom.
Sep 01, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Baby Gear Logo
129 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
