I need a replacement remote control for Everfocus EDVR16D1-250 Digital Video Recorder DVR DVD can any one help
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 92 Answers
You can purchase a programable universal remote at most electronic stores, if your looking for a factory replacement I would check out this web site. I hope this helps.
http://www.geminicomputersinc.com/security-everfocus-electronics-corp-.html
Posted on Sep 25, 2009
Cannot remember password need to rest it on ECOR264-4D2
On some DVR's you can reset the password by downloading .bin files from the manufactures website onto a thumb drive. I've done it for other models just not Everfocus. It's pretty simple if you can get access to those files. After you have them on the thumb drive you power down the device, plug in the thumb drive, the device scans the thumb drive and resets your password back to default, hope that helps!
Dec 21, 2013 | EverFocus ECOR264-D2 ECOR264-8D2 8 Channel...
I have an ever focus video recorder but it will no longer let me watch it live from my lap top i have to go in the search mode
Check your firm ware and make sure it is up to date. Also look at pc settings on activeX to allow. Make sure that the ip adddress is listed as trusted
Jun 28, 2011 | EverFocus Ecor264-16x1/1t Dvr Digital...
How to record from DVR on Centrios EDW8020 Digital recorder
am new I dont have the manual I need to know how to record I bought the dvr+r disc but its not doing any thing
Mar 12, 2009 | Centrios EDW8020 DVD Recorder
Formatting disks for EDSR1600
The EverFocus EDSR Security DVRs use standard PC Parallel (PATA) hard drives. I have used ATA100 and ATA133 speeds with no problems. There are no PC-type settings required except as below. The DVR has it's own internal firmware and will format the drive to its requirements.
If you are using a SINGLE drive tray, the largest hard drive I know will work is 500 GB. Set the drive to Master and you are done with the hardware setup. (CS Select would also probably work.)
If you are using BOTH drive trays, the largest hard drive EverFocus says will work on the EDSR100 or EDSR110 is 320 GB. Set both drives to Master and you are done with the hardware setup. (CS-Select on both would also probably work.)
Do NOT set any drive to Slave!
Lock the drive trays; if you don't the DVR will not go into record.
Press the STOP key and then press the MENU button. Go into the SYSTEM menu and do a DISK RENEW. This will erase the hard drive and also prepare it for DVR recording.
Do this by using ► or ◄ to select DISK RENEW. Change NO to YES (by using ▼ or ▲) and press the ENTER button. Highlight YES again by using ► or ◄ and again press the ENTER button.
Press the MENU button to exit and reboot the DVR. Then press RECord and you should be recording.
Aug 09, 2008 | EverFocus EDSR1600 16 CHANNEL 160GB...
PioneerDVR-225 recorder
A lot of the functionality you are wanting is tied to the remote that you have misplaced. You can go to the Pioneer support site and order a new remote, though it is like $30.
As for wiring options to record, it depends on the inputs and outputs that are available on your television.
- Ideally, connect VCR to TV input "1", connect DVR output to TV input "2", and conect TV output to DVR. This will help you avoid any copy protection issues you run into, but not all TV sets have both audio and video output.
- If you don't have TV outputs, connect VCR out to DVR in, and then DVR out to TV in. This will definitely work, but you will have to have the DVR turned on to watch a VCR tape.
Nov 24, 2007 | Pioneer DVR-225 DVD Recorder
Camara
how get backup of HDD dvr EDSR1600?
Oct 29, 2007 | EverFocus EDSR1600 16 CHANNEL 160GB...
Remote control will not work?
Hi Quad, recently I also got same recorder and faced the same problem with the remote controller. today i tried to solve this. i opened it up. it turned out the battery connections are not proper. The battery connection are in the form of a spring coil which touches the outerside of the battery which is not touching properly. I bent and slight lift it with a plier and it started working. The other connection is touching front side of the battery(on backside you see label cr2025 printed) and this is alright. I hope it works for you too. with best regards
Nov 26, 2006 | Cyberhome DVR 1600 DVD Recorder
Open Questions:
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
