Question about Sony Cyber-Shot DSC-S40 Digital Camera
LCD My camera shows only a bright white screen when I switch it on.
  • 3 Answers
Well its a cheap fix, dosnt last too long. In the lower right corner of the LCD, not actually on the LCD but just on the plastic portion of the camera push very hard
Posted on Dec 20, 2007
Canon rebel xsi lcd is faded and doesn't shut off
To eliminate the chance of the screen actually being damaged due to the camera being dropped, here's a little test you can do? Click on the MENU button and scroll to the 5th icon, the first setting you should see is LCD Brightness. Look at the scale and make sure the little top white arrow is in the middle, that setting should give you a normal brightness for the screen, if it is towards the left side that would dim your screen, move it to the middle using the side buttons around the main SET button. If the little white arrow is already set in the middle, then you screen might be damaged after all? Theres not other setting for the LCD brightness other than that one.
As for it not shutting off, do you mean the camera doesn't shut off or the screen doesn't shut off after a few minutes?
Oct 11, 2014 | Canon EOS Rebel XSi Digital Camera
Kodak C513 dark screen
There should be a setting for the brightness. Unfortunately the manual does not show this. You can check step by step all the settings of the camera to search for the setting, or you can take it to a Kodak dealer for repairs and they will show you exactly what is wrong. If the camera is under waranty, go directly to the dealer for exchange, as this could be a camera fault.
Apr 11, 2010 | Kodak EasyShare C513 Digital Camera
White screen on my camera and can take picture picture is black colour
hi
i think the LCD has been set to a very high brightness set the LCD brihtnes lower from the settings..
better more is to reset the camera to the default settings this would set the aperture, shutter, Exposure, LCD brightness and other settings to defaults and this would save from any unwanted changes than required
cheers
pls rate if it was any help
May 17, 2009 | Samsung Digimax L60 Digital Camera
Camera shows white screen when used outdoors
You are having the following problems:
White balance setting incorrect.
images are too bright
ㆍExposure is excessive
→ Reset exposure compensation
● Adjusting LCD Brightness
1. In any mode with the exception of Voice Recording mode,
press the MENU button.
2. Press the LEFT/ RIGHT button and select the [Setup]
menu tab.
3. Select the [LCD] menu by pressing the UP/ DOWN button
and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN
button and press the OK button.
[LCD] sub menu : Dark, Normal, Bright
5. Press the menu button twice and the menu will disappear.
Turn camera off. Try removing the fully charged batteries for 30 seconds, reinsert batteries and turn camera on. Hope this helps.
Dec 10, 2008 | Samsung Digimax i5 Digital Camera
Bright White Screen
Most likely either your LCD has gone bad or the cable has either shifted. Even if the LCD is pure white, the LCD can still fail or be bad.
Here is a link to a guy who does repair and replacement for LCD, and also sells the LCD if you want to replace it yourself.
http://www.darntoothysam.com/servlet/the-228/Canon-SD630-New-LCD/Detail
http://www.darntoothysam.com/servlet/the-227/Canon-SD630-LCD-Repair/Detail
Nov 11, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
LCD screen powers up but is bright white
TRY SEARCING THROUGH ALL YOUR MENU MODES. MY CAMERA IS DIFFERENT THAN YOURS BUT MOST CAMERAS IT HAVE AN ADJUSMENT MODE TO BRIGHTEN OR DARKEN YOUR DISPLAY ... JUST A SUGGESTION NOT A SOLUTION
Jun 19, 2007 | JVC Cybercam GR-DVL120 Mini DV Digital...
White Screen
I have Fuji FinePix 2650 Digital camera with same problem. I can almost guarantee this is not a firmware problem. I went mountain biking a few months ago and take pictures. I take out camera and turn on. I get lines then white screen. I banged on camera and fixed it. Later a few weeks ago I turn it on and white screen. i beat this thing and get bad menu selection screen for a moment then white again. It takes pictures well and talk to computer no problem but no LCD picture. I thinking it is loose connection for LCD. Send it for repair or if you seek adventure try to fix it yourself!
Nov 12, 2006 | Fuji FinePix S5000 Digital Camera
The LCD screen is hard to see. What should I do?
If the LCD screen is too bright or too dark, adjust the LCD Brightness setting in the Setup Menu. If you are shooting photos outdoors in bright light, move the joystick to the icon showing the sun over shaowed area to turn on Outdoor mode and make the LCD screen easier to see in bright light.
Sep 12, 2005 | Epson PhotoPC L410 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
27 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
